Question about KitchenAid (KSRD22FKST) Side by Side Refrigerator
Kitchenaid side by side freezer doesn't work.
  • KitchenAid Master
  • 43,501 Answers
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 31, 2011
I have problem with my freezer. Doesn't freeze up? The model is ksrl25f side by side kitchen aid.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Aug 02, 2011 | KitchenAid Refrigerators
Freezer doesn't make ice but water still works on front dispencer
HI,
I looked up your unit and the only problem I can see would be the full tube to the ice maker could be clogged with Ice not allow water to enter the ice maker, or a bad water valve which is located behind the unit on the back right side (freezer bottom). I would look at the fill tube start as this was more common.
I hope this helps
Water valve part number is you need is 4389177
Jul 23, 2011 | KitchenAid KSRA25ILSS Side by Side...
KitchenAid Refridgerator won't get cool - freezer works great - Ice maker won't run either. What's up? Also, the model wasn't listed below - it is a KitchenAid with Freezer on top/ fridge below.
when this happens in a side by side, the first thing i look for is frost on the back wall op fht e freezer, if its there, your not geting proper air circulation
unplug the machine for 24 hours this will clear the ice
\check your freezer fan for proper ops, if its working you may need service to determine whats wrong with your defrost
Oct 13, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Freezer works fine, fridge is not cooling. Side by Side KitchenAid Superba - KSRS25C
sounds like fridge fan is out,sometimes they stick and do not send cold air to otherside,replace or repair.
Apr 24, 2009 | Refrigerators
Warm refrigerator
Check the freezer fan.
Is it running?
If not, replace fan motor.
Check the damper doors in the fresh food side.
Does air flow through?
Mar 08, 2009 | KitchenAid Refrigerators
Ktichenaid, freezer on top
make sure your compressor is running if is not and and is just humming then is just your overload since you had a power outage it might off tripped it just repl and try that
Nov 01, 2008 | KitchenAid Superba Architect KSCS25INSS...
Freezer Door Stuck Shut
The refrigerator with 2 doors, the freeze has a electronic magnetite automatic close system, I think your electronic relay got problem, it doesn’t automatic relieve, you can try to unplug the electrical plug see if you can open it, after you open it and plug the plug back and try to close it again, if it is works, that’s great otherwise you have to fix it .
Good luck.
Frank
Jul 02, 2008 | KitchenAid KSRS25IL Side by Side...
KitchenAid (KSRD22FKST) Side by Side Refrigerator Logo
142 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
