I attach my usb to board for the installation of window from usb. but after enable the option of usb boot first. my system not pick the usb boot for installing the window through it.
    Brigadier General:
  • 8,909 Answers
If the USB device has not been formatted as a system or bootable drive before the systen disc was copied on to it won't.
In that case it can only be used to upgrade or repair a system that is installed on the desktop.
Posted on Mar 31, 2011
Keyboard doesn't work after boot
Try booting up with the ps2 keyboard.Once in Win 8.1, unplug ps2 and plug in usb keyboard. See if windows will recognize the usb keyboard and if so it should install software and drivers
Nov 19, 2013 | Gigabyte Computers & Internet
Tip
Installing Windows from flash drive-part II
Follow the next steps:
1. This step is mandatory. Through all the following process do not close the application. Close them if specified;
2. Create a folder and copy the 3 archives from above in that folder. (it is preferably to be close to the root; e.g. c:\XP USB);
3. Extract the content of USB_prep8.zip and PeToUSB.zip archives to the folder you just created;
4. Copy PeToUSB exe file to USB_prep8 folder
5. Enter the USB_prep8 folder, look for the usb_prep8.cmd and run it;
6. A black and ugly window will pop up. Press any key to continue. Here is the window that will pop up:
7. The result is the opening of the PetoUSB application:
8. All the settings are made. You only have to press Start. The application will format the USB stick and made it bootable. After completing the process do not close the application;
9. Extract the content of bootsect.zip archive;
10. Open the Command prompt (CMD). To enter the cmd, enter the Start menu- Run- type cmd. Or press Win key + R to open the Run window;
11. In the console use the CD command (Change Directory). Go to the folder that contains bootsect.exe file. If you followed step 1 the command is much more simple: c:\XP USB\bootsect;
12. Now you are in the specified folder. Type “bootsect.exe /nt52 I:”, where I: is the drive letter of the USB stick. Open a Windows Explorer or My Computer and check the drive letter of your USB flash and replace the “I:” letter with your drive letter. If it's not working close the window where you checked the letter of the drive.
af0fc89.jpg13. The result will be the update of Fat file system necessary for the boot from the USB stick. Now you finally transformed the USB stick into a Bootable USB Stick. Now you can close the following window and PeToUSB application.
9e151ee.jpg14. You will have in front of your eyes the following windows. If not press Enter. After the option list appeared, choose the following in the order:
a) Choose option no. 1 than browse the installation CD of Windows
b) Option 2- pick an unallocated drive letter. For example you can pick T (it is unlikely to be already chosen)
c) Option 3- pick the letter assigned for your USB Stick (in my case I)
d) Option 4 starts the process. When asked if you want to format the drive choose”Yes”, than “Press any key to continue”. The process needs some more confirmations, so stay close to your computer. It takes 10-15 minutes. It depends on transfer rate of the flash drive and the speed of the optical drive.
dc74600.jpg15. The worse passed. Now you have to confirm the deactivation of the temporary drive T: and to close all the windows. The XP USB stick is ready for use. You just have to install the operating system on your desktop or laptop PC
Now here are the steps for installing Windows from your fresh USB Boot Stick.
· Plug in the flash drive
· Check the Boot Order from the Setup(Bios) and set the Removable drive as first and the Hard Disk as second.
· Even so, there are cases when you have to enter the Boot Menu as soon you turn on your computer. (for EEE PC is ESC, for Toshiba is F12). From now on select Removable Drive or USB and the proper device.
· You will see that the menu is slightly different from the classic Windows XP installation menu, but it is not complicated.
· Pick option 1: “TXT Mode Setup Windows XP...”.Now the first part of the installation process is completed, the one in text mode. After the file copying process completes, the computer restarts, but you have to boot again from your Bootable USB flash drive. Now you have to choose option 2: “GUI Mode Setup Windows XP...”. From now on until the final steps of the installation process you have to choose Option 2.
And this is it
on Apr 16, 2010 | Computers & Internet
Toshiba portege m100. lost windows xp. how do I clean install windows. no cd drive only usb ports. will not boot pxe.tried windows on formated flash drive, still no result.
Making a bootable flash drive involves a few tricks. I have had much better success using a utility to do the setup on those. Doing it manually works but not all the time.
I'd beg borrow or buy a usb dvd drive and boot off the install cd if nothing else. These have really dropped in price and are handy to have around.
I'm assuming you have set the bios to boot from the flash drive before it hits the hard drive? You would also have to set it to hit the usb dvd drive prior to the hd as well if you go that way.
When you get it booted it will ask if you want to format the drive before installing. You can also just pick a new directory to put windows in as well.
Don't forget to download all the drivers from Toshiba. You will need system info, video, and a network at the very least to get running and able to download the rest. These are very handy on a flash drive to plug in when you get xp started.
Sep 02, 2011 | Toshiba Portege M100 Notebook
Trying to reinstall windows XP on Dell Dimension 8300....cant' start up using the CD drive...
Inpect the computers preexisting operating systems to ascertain compartibility to windows XP. Only XP computers would recognise XP operatign systems. Attemptign to install windows XP onto alternate system either windows 98, 2000, mellanuim or Vista XP or 7 is least achieveable unless the old system were erased or new empty storage disk drive were acquired and replaced.
Feb 03, 2011 | Compaq Presario 5000 PC Desktop
I turn my laptop on and it comes up with the sony vaio screen then it goes blank with a curser at the top of the screen for 5 mins then nothing else happens why
It can't find your OS.
Is there any usb devices attached?
Is there a disc in the drive?
If so take them out.
If not, and pressing F8 to boot into safe mode wont work.
You may need to re-install windows.
Another option is to download a LIVE linux distro, this will enable you to boot your pc up into linux, without installing anything, you may then be able to run a virus/malware scan and get windows working again, or as a last resort, enable to save any files before you re install windows
Jul 18, 2010 | Sony VAIO Notebook
In my computer the device of usb is not installed so How i can install it from Net
admin,
If you are running Windows*, you will not need to download anytrhing.
The USB ports may be disabled. Try this:
1. Go to the BIOS Setup screen (F2 when booting-up)
2. Arrow-down to [Onboard Devices]
3. Right-Arrow
4. Down-Arrow to [External USB Ports]
5. Press [ENTER]
6. Select [Enabled] and [ENTER]
7. Press [ESCAPE] and choose [Exit]
Your USB ports will be enabled.
Nov 05, 2009 | Dell Computers & Internet
Can't enable boot devices on ASUS eee 900 netbook
For less hassle you can install ubuntu within windows and it will work perfectly if your windows is operational...
Aug 19, 2009 | ASUS Eee PC 900 PC Notebook
Install WinXP from USB in Toshiba NB100
Depending upon your CMOS you will get the option of going to CMOS setup by pressing a particular key. I don't know yours wether it is Del key or Alt plus F12 or something else just look closely for it on the first black startup screen. Once you are inside your CMOS setup just go to the Advanced chipset settings and select first boot device as your USB. Now your main worry is which USB you are connecting your pen drive to. So if in CMOS you get many USB options then select one of any and keep on changing till you get the line boot through usb or boot through external media. Also keep in mind boot through other devices shall be enabled. Now save the settings and exit. If you require any further assistance just ask for it.
Thankyou for using free utlity at fixya.
Jul 19, 2009 | Computers & Internet
USB mouse won't work under XP in a dual boot Ubuntu GRUB 1.5
It has the latest mouse driver (logitech setpoint 4.0). Before installing Ubuntu the setup worked w/ SUSE/XP using GRUB dual boot. After installing Ubuntu XP does not see the usb mouse. Even Logitech setpoint does not have the mouse setup/configuration option. It appears that at boot it does not recognize the mouse or disables it. The BIOS has the usb keyboard and mouse enabled. Currently, I have two mices one for xp and either mouse will work under Ubuntu.
Sep 03, 2008 | Canonical Ltd. Ubuntu
Computers & Internet Logo
148 people viewed this question
David Payne
David Payne
