Question about LG 32LG30 32 in. LCD HDTV
Gday guys, my 32lg30d wont turn on, red light flashes and then turns blue as normal but screen wont turn on, i have checked the capacitors but none are swallen or damaged HELP???????
  • 197 Answers
SOURCE: Everything is working perfectly fine, the only
probably bad power supply call lg
Posted on Jun 09, 2009
dave1645
  • 834 Answers
SOURCE: lg 26lg30 light blinks red blue wont turn on.
you have a bad cap in the power supply
these are can shaped device thet if bad will vent anf put up on the top the valoue is wrtten on the side trplace them and you should be good to go
Posted on Nov 06, 2009
  • 8457 Answers
SOURCE: LG plasma just turned off for no reason,
Try unplug,replug for reset that all could do,same prob.must change tha Main backlight Vivdeo board.
Posted on Nov 17, 2009
SOURCE: LG 26LG30 screen suddently went blank. Light flashing blue/red
IN POWER SUPPLY SECONDRY SIDE ( 5V,12V,&24V) ALL CAPASITER REPLACED SET OK
Posted on May 25, 2010
budmrtn
  • 11361 Answers
SOURCE: MY SCREEN DOSE NOT TURN ON, AND THE RED LIGHT WILL
It went into shutdown due to short circuits in the power supply or in the backlight inverter board, you will need to do in-depth troubleshooting.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Please post back what you find.
Posted on Aug 20, 2010
Tv wont power on red light continuously flashes
Hi,you need to have the capacitors in the powersupply replaced
Oct 15, 2013 | Samsung UN46D6400 46 Inch 3D 1080p Smart...
I have a GOODMANS LD3261HDFVT TV. It has been perfect up until now. Problem is that when i switch on I usually get a flashing red light instead of a solid red standby light. Sometimes if I get the solid...
Good day!!!!
Commonly that trouble is cause of faulty capacitors on power supply board...
Please follow this step on how to fix that problem on your own..
  1. Open the back cover of your TV.
  2. Look at the power supply board..Its normally connected to the power cord..
  3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
  4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
  5. Some of the capacitors not bulged so its better if have a capacitance meter..
I hope this solution will be helpful...
Thanks for using fixya...
This is the sample image of bulged capacitors
Dec 10, 2011 | Televison & Video
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Hi, my tv wont come on. the stand by light turns on and off (as if it were not turned on, just on stand by mode) in red, then it turns blue/white as if it was going to come on and it simply turns off...
The power supply is dead,Theres a leak capacitor,you can identify those capacitor if leak of deffect when the top is round shape and usaully the normal capacitor is flated at the top.Try to replace capacitor at the power supply.
Jul 12, 2011 | LG 37 37LV3500 LCD TV
Flashing screen when i first turn on my SamsungSyncMaster 2232 bw
I had a similar problem with my LCD computer screen. I took it apart and noticed a capacitor that was raised up on the flat end and appeared to be leaking a substance. Replaced it with a similar capacitor and works fine, for three years now.
Jul 05, 2017 | Samsung SyncMaster 2233BW 22" LCD Monitor
Screen went dark
Ur video ic inverter board is dead.
U need a new one.
Aug 25, 2009 | Televison & Video
42 plastma problem
Bad Capacitors in Power supply. IF doesnt help changing Capacitors Replace Power Supply Board
Feb 28, 2009 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
1flashing red light
one red light is also the E71 error as well.
Aug 04, 2008 | Microsoft Xbox 360 Console
Samsung flat screen wont turn on red light just flashes..
wont turn on red light just flashes?
On my samsung flat screen tv when you are watching the televison there is no red light on the power button but when you turn the television off the red light stays on all the time? what can I do to turn this light off?
Jul 20, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
TV turns on for a split second then back to standyby
i think your capacitor is blown, do a google search for insignia, lcd, capacitor...
you can buy another one for about $2 but its a pain to install, you can also instead buy a new powerboard for about $80, its an east install and you wont blow more capacitors
bestbuy.partssearch.com
May 09, 2008 | Insignia IS-LCDTV32 32 in. Television
LG 32LG30 32 in. LCD HDTV Logo
114 people viewed this question
Computer Repairing
Computer Repairing
