Question about JVC GR-DVL320 Mini DV Digital Camcorder
Unit in safeguard mode. ( EO3), EJECT AND REINSERT TAPE
magic seadog
  • 38 Answers
SOURCE: safegaurd mode
Unfortunately this is a repair issue. There are several failures that can occur, none of which will be resolved without service, that create this safeguard situation. Often the fpc cable which carries sensor information to the micro has been injured and that requires repair. Good luck, magic seadog
Posted on Aug 12, 2007
SOURCE: unit in safeguard mode
I have a DVL520U,
I may be lucky from what I have read, but this is what I did.  I took out the tape, released the tension on it by pressing the small tab between the wheels (I observed a slight wheel movement).  I took the eraser end of a pencil, and while holding the tab, rotated the spindles of the tape 10-15 rotations back and forth (this from the vcr days and tracking problems).  I put the tape back in and the problem went away.  I thought of this after reading post after post and then finding the definitions of the error codes on a french website.  Codes 4-6 seemed to be with the mechanical aspects of the drive, codes 1-3 with the sensors etc.  All in all it was a guess on my part.  If any of this works for you, pass it along.
Posted on Oct 12, 2007
ctf1800
  • 4402 Answers
SOURCE: error code EO3
· http://www.camcorderinfo.com/bbs/index.php
· JVC camcorders
· Tap o the side to fix your problems
-only, only, only use the more expensive JVC tapes. They keep their tension far better than cheaper brands. Also, they won't rub off their oxide coatings on the heads as easily, avoiding the 'clogging' of the heads (which thereby requires constant cleaning-further damaging the heads).
-when and if you do get E- errors do a complete rewind or fast forward to the end of the tape in order to pull out tape slack. Then remove battery and tape for a while. If still screwed, then yes, sharply tap (not hard!) on the closed tape door. That may reposition those tiny switches that I mentioned earlier and get you going again.
-NEVER, EVER, EVER, leave tapes in the machine when not in use....it creates problems for the heads and the mechanisms.
-Don't leave the battery on the camera when not in use for extended periods of time. It can create problems with respect to resetting the computer controlled logic.
-there are little switches and interlocks that provide electrical feedback about the mechanical status of things to the main processor of the camera (ie. tape/no tape in camera, door open/closed etc). Over time, the mechanics get out of adjustment because of usage, humidity and certainly rough handling. So: treat the mechanisms very, very, very delicately. Don't use/store the camera in humid conditions, hot conditions or very cold conditions. Certainly don't leave it in your car---ever!
-get the camera "cleaned and ajusted" regularly to avoid these problems. (I know...more $$$$)
· -I keep bags of dessicant in an insulated camera bag with the camera to maintain dryness and optimal temperatures during storage.
Posted on Feb 07, 2008
welcomejee
  • 10594 Answers
Please remove and reattach battery and hope this will resolve 03 error issue in your JVC camera.
Posted on Dec 06, 2008
SOURCE: unit stuck in safeguard mode
I can't find e setup for sony
camcorder
Posted on Dec 30, 2008
It keeps saying it in safeguard mode
my jvc camcorder kep.s saying unit is in safeguard mode eject and reinsert tape have done this a dozen time still show,s same thing on screen would appreciate help thank you larryd i
Feb 13, 2011 | JVC Video Cameras
It is writing: unit in safeguard more eject and reinsert tape. However after reinserting tape it does not correct. Please help.
Safeguard mode follows a numeric code, go further down and you will see. In case "02" you need a service personel (something to be done/parts need to change with the mechanism)
Feb 28, 2010 | JVC GRD250 MiniDV Digital Camcorder
I am recieving error E04 "safeguard mode"
An excerpt from http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/:
"JVC notes that you are also given a malfunction code when the unit is placed into safeguard. If it displays code 01, 02, or 06 you should remove
the battery and powersupply and wait for a while. Code 03 and 04 indicate that you should eject and reinsert the tape.
If neither of these solutions work, your only alternative is to bring it to a shop or send it to JVC for diagnosis or repair. Unfortunately, there is no other way to clear the condition."
According to this, E04 denotes a problem with the recording media or the mechanical bits that deal with the tape. Hopefully trying another tape helps.
Mar 09, 2009 | JVC 580136 Camcorder
My camcorder goes into safeguard mode EO3 when I try to clean it.
I have had the same problem with a different model JVC. I haven't been able to fix it yet, but there were a bunch of people on a different forum that were able to fix that error code quite simply. With a tape in the machine, flip the lever to eject the tape, then as soon as you hear the motor start to whir, quickly close the door.
It didn't help me, but like I said, several people reported that that action fixed the EO3 error.
Feb 01, 2009 | JVC GR-DVL505 Mini DV Digital Camcorder
Unit stuck in safeguard mode
camcorder
Dec 30, 2008 | JVC GR-D270 Mini DV Digital Camcorder
Safegaurd mode
Aug 07, 2007 | JVC GR-D240 Mini DV Digital Camcorder
You mix te info with Write protected tapes.
Safe guard mode is caused by the motor that takes the tape out of it's case, through the mechanics and past the video head.
If for some reason the electronics detect that it's been done by too much force, the safe guard issue promts.
Mar 29, 2007 | JVC GR-D290 Mini DV Digital Camcorder
JVC GR-DVL320 Mini DV Digital Camcorder Logo
77 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
