Question about Lite On Laars Lite 2 Heaters: 250,000BTU MV Heater
Laars Lite 2 Spa Heater
Pilot light will not stay lit.
I appreciate any suggestions you may have.
Thanks,
Denby
  • Anonymous Aug 23, 2008
    We have the same problem. Pilot light will not stay lit. Sometimes it will stay in for a few days then it stops and we can't relight the pilot. We finally get the pilot lit & it going again when it stops again. We've had new parts but I think the engineer has now just about given up.
It might be the hot surface ignitor. a common problem with gas furnaces also. also, check if there is an code on your screen. it will be called an FL code. call the manufacturer.
Posted on Aug 13, 2008
Pilot light will not stay lit. Can i light it manuly?
Posted on Dec 25, 2008
SOURCE:
Pilot light stays on but burners will not come on.
open safety within circuit, poor electrical connection or tstat issue
Oct 21, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
Laars lite 2 pilot
make sure gas pressure is correct if ok see if the silver tube has a cobweb also make sure all connections are good
Sep 04, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
Teledyne laars xe pool and spa heater
look inside on panel directions if not turn to pilot setting hold down button light under where small silver line goes under while holding down button when lit keep holding for about a minute then turn to on should stay lit if wont stay lit need new pilot generator
Jun 09, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
Laars Lite 2 LG - pilot light will not stay lit. As long as you hold down the pilot light once it is lit it stays lit but when I turn the nob to the "on" position (release the pilot light button) the flame...
It sounds like a thermocouple has gone bad. this is a very common problem with gas powered things ie; water heaters, furnaces, hot tubs. The telltale sign is when you release the pilot light button it won't stay lit. This is a safety feature and is relatively inexpensive and easy to repair.
Aug 08, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
I have a natural gas pool heater. When I release
Replace the pilot generator. For a quote on the part, send us your heater make and model using the contact form at www.arrowpools.net
Jul 16, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot stays lit, but burners underneathe do not light up or burn.
Check pump is working, if so could be stuck flow switch or gas valve fault get unit serviced
Aug 31, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Heating & Cooling Logo
229 people viewed this question
Top Lite On Heating & Cooling Experts
Paul Carew
Keith Bowers
Sheldon Dedek
Are you a Lite On Heating and Cooling Expert? Answer questions, earn points and help others
