Question about Salter Stainless Steel Electronic Bathroom Scale
I have Salter Bodywise Stainless Steel Analyser Scales. They are only 14 months old. With new batteries, the weight is displayed as 00 only, and with my height and age, again the weight does not register when I stand on the scales, and no other information such as BMI etc shows up.
5 Suggested Answers
kristineluci
  • 30 Answers
SOURCE: Negative weight on Salter Stainless Steel Kitchen Scale
make sure the battery your getting is a good one longlastig and if that doesnt work then how nout the motor
Posted on Aug 21, 2009
SOURCE: Reset digital bathroom scales
I cannot reset my digital scale to lbs. it is a conair ww body mass scale
Posted on Oct 18, 2009
SOURCE: setting the clock on salter scale model 5007
Hold down the g-oz key and the off key at the same time for about 5 sec's
The hour digit will flash
press the ml-floz key to move the hours.
then press the g-oz key again to move to the minutes.
press the ml-floz key again to set the minutes.
press the g-oz key and it moves to setting the cloak to 12h or 24h option.press the g-oz key to set the time.
And your done.
Posted on May 23, 2010
  • 5370 Answers
SOURCE: I bought the scales yesterday
Weight Reading Only If you just want to know your weight, follow this sequence: 1. Press and release platform to turn scale on. 2. Wait until display shows zero. 3. To change to st, kg or lb press button on underside of scale. 4. Stand on platform. 5. Weight is displayed. -------------- Weight & Body Analysis Readings Each user can save up to 30 sets of results to the scale.The bar chart icon on the scale display indicates the user memory status. Position the Salter scale on a flat level surface. 1. Press ON/SET button. 2. Select your user number using UP and DOWN buttons. 3. Press START button. 4. Wait while scale confirms user settings (and if applicable displays your previous results). 5. Zero is displayed.To change to st, kg or lb press button on underside of scale. 6. Step on to scale with BARE FEET. 7. Your weight is displayed. 8. Wait.Your weight is displayed again (you can step off the scale now) followed by your BMI, body fat, body water, muscle mass, visceral fat and BMR. 9. Your results are repeated (to toggle between results press the UP, DOWN, ON/SET or START buttons). 10. Your results are saved to the scale memory. 11. The scale returns to clock mode. -------------- This is the procedure.It shows weight,then dont step down.It will show the weight again,now step down,so it will show all other readings.------------- keep updated.Thanks.Helpmech.'
Posted on Feb 17, 2011
The scales show the wrong weight, why?
it could be that it isnt on level ground keep getting on in different places to see when you find the spot where it shows your right weight..
Feb 07, 2011 | Salter Stainless Steel Electronic Bathroom...
I have a Salter bathroom scales purchased about a year ago in Tesco. I no longer have the receipt so I no not have any come back from Tesco. When you get on the scales it will give you one weight reading...
I would contact the Company that makes the scales and inform them of their defaulty scale that you paid your hard earned money and see what they say, They may replace it if you send them the defaulty one! Good luck.
Nov 23, 2009 | Salter Stainless Steel Electronic Bathroom...
Aug 21, 2009 | Salter 2001 electronic kitchen scale
How do i contact salter scale customer service i have a waranty issue with a scale
you can contact our customer service by this email address
sales@accurate-scales.com
Aug 04, 2009 | Salter Stainless Steel Electronic Bathroom...
I changed the battery on bathroom scale Salter 987
I had the same problem with my Salter 987 scale. Pull the battery out for about 10 seconds and put it back in. Then push the scale once so it turns on. After the blinking stops, push it once more. The scale will now zero itself. After the scale has zero'd itself it may turn off after a brief moment. It's now ready to use normally. If you're standing on the scale when it's trying to calibrate to zero, it will assume your weight is zero. Don't stand on the scale after replacing the battery untill you first complete the steps listed above.
Jul 21, 2009 | Salter Stainless Steel Electronic Bathroom...
I have lost my instructions for my Salter glass bathroom scales 9103. I have a EE on the digital mode what does this mean and what can I do to fix it so the correct weight shows
The scales display EE as they are reading a negative weight.
With the scales switched OFF place 2 glass plates on the scales and press ON.
The scales should now display 0g.
If this doesn't work add more weight and try again.
There is also 4 screws on the underside of the scales which hold the weighing bar in place, if you loosen the 2 smaller screws this should relieve some of the stress so less weight is needed to zero the scales.
Jan 26, 2009 | Salter Stainless Steel Electronic Bathroom...
Salter Stainless Steel Electronic Bathroom Scale Logo
197 people viewed this question
Top Salter Health & Beauty Experts
traccie
Level 1 Expert
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Salter Health and Beauty Expert? Answer questions, earn points and help others
