Ricoh Cl4000DN- Reset Consumable Counters/Chip ID History
How can I access the Service Technician Menu to reset/clear the consumable counters and toner ID (smart chip) history?
Any help appreciated.
Thank you for your time.
-Greg
[email protected]
  • Anonymous Jan 12, 2009
    Under service menu when reset, and back to regular mode it still shows the number of pages printed anyway. Is there a way to reset the main page counter back to 0?
To Enter Service Mode:
Hold down the Online and Escape buttons while turning on the power. Hold down buttons till "Please Wait" comes up. It will start in Service Mode.
Go to Engine, then Data Log, then PM Counter Reset, then the counter that needs resetting.
~RReuter
Posted on Nov 04, 2008
SOURCE:
How to reset this error :Fusing belt unit must be replaced now ricoh mpc 2503 SP
These machines have a internal counters to keep track of consumable parts. The part has reached its mark. it needs replaced. you can cheat the system by reseting the fuser counter to zero. It is just that cheating the system. You will encounter problems if you do such. Copy quality will be effected maybe not right away but it will happen. Offsetting print from one page to the other. It will be real noticeable on the edges of the paper. replace the fixing assembly.
Apr 09, 2017 | Ricoh Office Equipment & Supplies
I replaced the Ozone Filter, now how to I reset the the machine?
go to service mode, counters life and clear the ozone one
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Oct 28, 2015 | Konica Minolta Bizhub C451...
Ricoh CL2000, How do I enter service mode, and reset (CMY page counters)?
What are you trying to do? Some counters do not reset. Only those for consumable items can be reset.
Jan 17, 2015 | Ricoh Aficio Office Equipment & Supplies
How do youfind scan count
If the scan count of your fi-6130 scanner exceeded 2,00,000 scans, then you may have to replace the consumable parts. After replacement of the consumables, you need to rest the consumable counters. To check/reset the Pick/Brake Roller Counter, please follow the steps provided below:
1.Turn on the scanner, and confirm if it is connected correctly to your computer.
2.From the "start" menu, select "All Programs", then select "Scanner Utility for Microsoft Windows", then click on "Software Operation Panel"
3.In the dialog box displayed, from the list on the left of the panel, select "Device Setting"
4.Click the "Clear" button beside the replaced consumable under "Page Counter"
5.Click the "OK" button on the displayed confirmation message. The counter is reset to 0
6.Click the "OK" button to close the "Software Operation Panel" dialog box
Hope the above information is helpful.
Thanks & regards,
ScanCare
Jun 04, 2014 | Fujitsu fi-6130 duplex scanner
Code DS42003 PAD ASY IN PAPER FEEDER
After you've been scanning for a while with your Fujitsu 6110 or 6130 scanner, you will get a message from the scanner recommending that you replace some of the scanner's consumable parts, such as the pick roller and pad assembly. Although you can ignore these messages, they will keep showing up, even after you have replaced the parts, until you also clear the scanner's page counters in the Software Operation Panel.
http://www.scan123.com/blog/index.cfm/2013/3/15/How-To-Reset-Page-Counters-for-Fujitsu-6110--6130-Scanners
Sep 30, 2010 | Fujitsu fi-5120C
How to restore to factory default settings ricoh
enter service mode then execute these service programs I would do an sp print
5990- 2 out first just in case
5801 Memory Clear
Resets software counters and returns modes and settings to their defaults.
All clear: Clears all data
Engine clear: Clears the printer engine settings
SCS: Clears the systems settings
PRT: Clears user mode system settings
NCS: Network control systems - Clears the items listed in the “Host Interface”
section of the Configuration page.
DCS: Delivery control system (e-mail settings)
MIRS: E-mail addresses
5801 1 Memory all clear
5801 2 Engine memory clear
Resets the following user tool settings:
Maintenance menu: Main scan registration, sub scan registration, image
density, curl control
Resets the settings of the following SPs: 1003, 1104, 1105, 1902, 1910, 2001,
2112, 2113, 2201, 2213, 2301, 2910, 3921, 3922, 3923, 3924, 5930
5801 3 SCS memory clear
Paper Input menu: Paper type, paper size, tray lock,
System menu: Energy saver timer
Resets the settings of the following SPs: 5009, 5812
Also resets the user code counters.
Nov 10, 2009 | Ricoh Aficio SP C410DN Laser Printer
How to reset black drum counter OKI C3300 ?
Buy a pack of 10 x .062A (1/16A) pico fuse RS part No 738-3062. Switch off printer. Remove the drum and toner together from the drum slot to be reset. Carefully crimp the legs of the fuse around the contact wires on the right side of the drum slot. Make sure fuse legs are making a good connection to the wires and aren't touching the frame. switch on printer and allow it to detect the absence of the drum. Switch off printer and carefully remove the now blown fuse. Re-install the toner and drum assemnbly. Drum life is now reset. see pic:
Sep 15, 2009 | OKI C3400n Laser Printer
EP4000. Have maintenance soon: M2
The M2 code is associated with one of the maintenance counters, these counters track the life of key consumables in your machine.
The counter needs to be reset, but in doing that you may cause a problem for yourself down the road. It would be preferable to have a Tech check the counter vs the condition of the consumable it is tracking.
As for looking for a Tech, you didn't say what part of the world you are in.
I am in western Canada, so I would like to help you but travel costs might be prohibitive.
Have a great day.
Ed
May 05, 2009 | Minolta EP4000/5000 CS/PRO Copier
How do I reset the drum and PM counters on a Sharp SF-2214? The red drum and technician lights are on on the control panel, even though the drum has recently been replaced.
To get into service mode press the following keys one after the other "clear" "interupt" "0" "interupt"
To clear the drum counter : enter "24" then "start key" "7" then "start" key.
To clear maintenance counter : enter " "20" then "start" key then "1" then start" key.
restart copier and the flashy thing should be history.
Mar 20, 2009 | Office Equipment & Supplies
How to remove Assembly pad message after replacement
you can reset this message in the scanner controll panel.
Please call windows <start>
<settings>
<system control>
<scanner and cameras>
open <scanner and cameras>
inside you will find your fujitsu scanner fi-5120C
now call <attributes>
-- in WIN2000 there is a button, in XP use the right mouse button--
in <device settings> you see the ADF counter, an the consumable counters for pad and pick roller.
Reset the changed parts, confirm the EEPROM writing
and the message will be cleared.
Jun 24, 2008 | Fujitsu fi-5120C
881 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
