Question about Westinghouse Refrigerators
HOW TO REPLACE DOOR SEALS IN RJ532 IT HAS NO SCREWS FRIDGE SECTION
  • 57 Answers
The model number you posted isn't coming up. But if there are no screws behind gasket and it is 5yr. or newer then it is a plug in gasket. Just pulls out.
Posted on Mar 31, 2011
How do I repalace a door seal on the Kenmore refrigerator?
Remove the door makes the job easier. Using a table lay the door with door seal in the upright position. Pinch and pull the door seal over to one side to expose the door seal screws. Remove screws and gasket/ seal and install the new door seal in the reverse order.
Feb 07, 2014 | Refrigerators
The water line in my Kenmore side by side fridge broke in the door how do i remove the inside panel to replace the line??
It's a shot...but if I recall correctly the rubber seal thats between the door and the fridge can be peeled back or removed, and underneath are the screws that hold the inside panels on...
I would peel the seal back a little at a time until I actually locate a screw...then once located... I would feel more confident about the removal of the entire seal. Keep in mind the seal is much easier to remove than to replace...I used baby oil in some place to replace the seal...Good Luck!
Dec 20, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Changing a door seal how do you replace the door seal ?
  1. Check the door seal size. Measure your door or doors, and take down the make and model number. Ads by Google
    '; for(i = 0; i '+ '' + google_ads[i].line1 + ' ' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
    ' + '' + google_ads[i].visible_url + ''; } s += ""; document.write(s); return; } google_ad_channel = '+7733764704+1640266093+5860073694+9911500640+9665908481+9016233241+8388126455+8941458308+8509902424+8509902424+9683278076+7122150828' + xchannels + gchans; google_ad_client = "pub-9543332082073187"; google_ad_output = 'js'; google_ad_type = 'text'; google_feedback = 'on'; google_ad_region = "test"; google_ad_format = '250x250_as'; //--> google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
  2. 2Order a replacement door seal. It's easy to find them online. Make sure to check the model number for your refrigerator when you order it. When it arrives, hold the new door seal up against the old door seal to compare the size. The sizes are rarely incorrect, but it will save you the trouble of doing the job twice if you happened to receive the wrong door seal.
  3. 3Locate the screws. Lift the edges of the seal and find the screws underneath that are holding in the plastic liner and door seal. Often, the screws hold in a plastic liner, which in turn clamps the door seal to the door.
  4. 4Loosen the screws. Begin to loosen the screws that hold in the door seal. DO NOT take the screws all of the way out. It is unnecessary and will create more of a job for you. If at all possible, loosen only a few screws at a time, as you go.
  5. 5Remove the old seal. Once all of the screws are loose, the door seal should easily slide out from behind the plastic liner. Don't be too forceful when doing this step, since some plastic liners can be quite brittle and crumble if you are too rough. If the plastic is old, replace it.
  6. 6Insert the new seal. Begin slipping the small lip of the new door seal behind the plastic liner of the fridge. The best method is to start in the top corners and work your way around the door.
  7. 7Tighten the screws. Once the door seal is in a certain section, you can begin tightening the screws. Begin with the 8 corner screws, and then check the alignment of the door while closed. Also check that the seal is even and straight. If the door is twisted, you can easily manipulate the door to twist back into shape whilst the screws are loose. Then tighten the remaining screws.
  8. 8Apply powder. Use a bit of baby powder or talcum powder to prevent sticking. Rub some powder around the hinge side corners of the door seal, and where the seal slides. This will help to prevent the door seal from twisting as it meets the metal of the fridge. If this still doesn't prevent twisting, then wedge a screwdriver under the seal as you close the door and leave it shut for an hour.
  9. 9Check for gaps. Look for any gaps in the door seal, especially at the top on the opening side. These can form due to the door dropping or being out of alignment. One way to check is to turn on a flashlight and place it inside, then close the door and look for light.
  10. 10Fix any gaps in the door seal. Pack out the seal underneath the areas where the door seal has the gaps. This can be done with a small strip of weather stripping, as shown here, or a bit of tightly rolled up paper under the door seal. Alternatively, you can heat the door seal up with a hair dryer to fix the gaps. This softens the door seal and allows you to stretch it.
  11. 11Check the corners. If the application of powder hasn't prevented the door seal twisting, then wedge a screwdriver under the seal as you close the door and leave it shut for an hour. The door seal will then have enough time to mould into the correct shape.
Aug 29, 2010 | Refrigerators
Hi my Asko fridge has a freezer compartment - I
not sure why the seal is faulty but yes you can buy a rubber seal for the door go to your local hardware store you might have to look in the section that stops drafts from entering a room or rubber flex material with a adhesive tape that can be formed into any shape eg around a outlet pipe or to seal a window etc and you can always trim some rubber sealer to fit if its a little large . I used a foam roll with adhesive tape to seal my freezer door on a mini bar fridge and its still in use today
Oct 26, 2017 | Refrigerators
My fridge door doesn't seem to close completely - No suction?
if you peel back the seal from inside out you should find some screws. losen the screws and replace the part that came out. to set the seal just heat it with a hair dryer with the door closed and hold the seal with a putty knife until it cools
Aug 11, 2009 | Frigidaire 14 cu. ft. / 396 liter Upright...
The door seems to be warped or tweaked in some way
Your fridge is not level. If you level it you will find that the door was fine , it was the fridge that was tweaked because it was not level and sitting correctly. Use a level, shims, and/or the adjustment screws on the bottom.
Jul 01, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
How to fit a Zanussi fridge door seal
You mean you have a door gasket. A good, step-by-step article on this pesky concept of "panel-screw" gasket installation is found on this handy page:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Appliance_Zone_Refrigerator_Install_A_Refrigerator_Door_Gasket.htm
This should help!
Brad
May 21, 2009 | Refrigerators
How to replace the door seal on a frigidare upright freezer
most fridge door seals are attached to the door by screws. If you flap the seal up from the bottom you should see some screws. if you go to the site below it gives your guidance on replacing the seals on fridges, as all fridge seals are pretty generic you should find it useful
http://www.wikihow.com/Replace-a-Refrigerator-Door-Seal
I hope this helps
Dec 08, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
How do I replace the door seal
like much refrigeration, the door seal is near impossible to replace - it is foamed in. you are faced with a new door at vast cost.
Apr 29, 2007 | Candy CPC220 Bottom Freezer Refrigerator
Refrigerators Logo
197 people viewed this question
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
