Question about Vacuums
My triton electric shower keeps dripping when turned off
Will I have to get a new Roomba?
Take it apart look on u tube to do that and let it dry for several more days. BE very careful of the wires. Screws are easy. Don't disect it. I've had mine since 2007
Jan 26, 2016 | Roomba iRobot 780 Series Vacuum Cleaning...
Blows out mist when sucking up water
You have to keep the sponge like filter in, it collects that mist and drips inside.
Apr 15, 2014 | Shop Vac Vacuums
Condensation dripping from ceiling in all electric home with no basement
The wall of the daughter's bedroom is NOT insulated. Moisture from normal activities (showering and cooking) within the house are causing the realtive humidity to be above 50%. When that moisture enters the wall or ceiling, the temperature drops below the dewpoint and condenses out. The moisture that condenses makes a nice environment for the growth of black mold which is highly toxic. The mold will spread by airborne spores. If you have return air ducts for your HVAC system in the room, the spores might be dispersed throughout the entire house, depending on how good you HVAC filter is. Note that if you have a swamp cooler on the roof, it could be leaking water through the ceiling and causing the problem.
You need to immediately move you daughter to another room and remediate the situation -- tear out all the drywall and anything that is damp or has signs of visible mold. Get the humidity in ther house below 50% with a dehumidifier. I would recommend the Winix 50-pint model (refer to link below). This will condition 1500 square feet, which is a lot, but you will need one on each floor.
Amazon com Home Kitchen
Jan 29, 2014 | Kirby Shampooer Shampoo Hose G3 Ultimate...
6 yr old Aqualisa shower working perfectly well. But turned itself on last night. No light showing on dial/on switch. Wouldn't turn "off" for me. Ran for 15mins and then switched off!
Good Aternoon lrmulholland,
Do you know what model Aqualisa shower you have or are you able to take a photo of it for us? That would be very useful.
Kind Regards,
The Aqualisa Team
Sep 07, 2011 | Vacuums
We have the water hooked up at the back of machine. there is a spout for the water to come in and fill the ice tray.but is does not. If we turn the water on it fills up the space under the ice basket. I...
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
With the fill tube blocked with ice the water can drip down the back wall or drip into the ice bin or just stop up. You can use a hairdryer to thaw the tube out.
Feb 18, 2011 | Vacuums
I have a galaxy obsession deluxe 9.5 kw shower which will run for a little while but then trips the fuse, what could be causing this to happen?
your cable supplying power is not correctly sized for the shower causeing it to overheat and trip the fuse, or your main board fuse isnt matched to the power of the shower
Dec 19, 2010 | Galaxy Vacuums
Do I keep the filter in when sucking up water?
you dont have to but its a good idea to leave it and dry it afterwards by letting it drip dry in sun after shaking it out. They should offer a foam sleeve part similar to what is used in canister steam cleaners...keeping an extra filter on hand is a good idea
Oct 02, 2010 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Bissell Pro Heat 9200 dirty water dripping out
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
rujr
Mar 20, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Keeps turning off during use
Sounds like poor electrical contact between the base and the bag compartment. If you separate the base from the bag compartment (press the button at bottom front of bag compartment, then pull or lever the two apart) you will see the electrical contacts - they may need cleaning, or perhaps bending VERY SLIGHTLY to help make proper contact. Otherwise, something in that same area may be damaged and need repair. Good luck!
Jan 23, 2010 | Sebo Automatic X1 Bagged Upright Vacuum
Vacuums Logo
121 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
