Question about Tefal Pro Express GV 8120 Iron
While ironing with the steam it will give a burst of brown dirty marks all over the garment. This is my second iron because of the same reason. The store which I purchased the iron recommended that I use equal parts of tap and filtered water. I am not very happy because It was not a cheap iron, and because you never know when it is going to happen. Tonight I was ironing white shirts and it happened to 3 of them. What am I doing wrong.
My steam isnt working on my pro express steam generator, but the water in the tank still gets low
Posted on Apr 18, 2011
  • 17,129 Answers
It seems quite possible that the brown marks are from rust from tap water. so if you can to get this straight , remove the water from the iron-- even if stored within for some time , some water can change- flush out the water using water filtered from the tap to a clean vessel to see if there are no stains or colour change. Now once the iron was used to stem off the water which was poured into repeatedly , then check on to see if there is any stains coming on. Make sure that the base is clean or use a cotton hard cloth as a wiper before you iron .
If the fault comes back there are some issues within that is staining the water.
Posted on Mar 31, 2011
SAND LIKE SUBSTANCE COMING OUT OF IRON
Yes, there is a "Solution" you could use in the reservoir to remove the crud. First of all, STOP using tap water. What you have is mineral deposits inside your iron from using tap water. Use ONLY steam distilled water. I usually find this at my grocery store.
To clean out your iron, use white vinegar in your iron instead of water. This is to CLEAN the iron ONLY! Do NOT use to press cloths! And make sure the steam and/or water flow very clear (free from "sand", dirty water/steam or any other contaminates BEFORE using iron to press your cloths. You may need to flush the iron with water (remember, steam distilled ONLY) more than once to get all of the vinegar out.
Hope this helps...
Jun 29, 2012 | Rowenta Perfect Iron
Russell hobbs steam glide iron no 14125
I had to empty water out of iron and clean surface to get the marks to stop. After putting new water I let the iron heat up and ran it over and over on a white sheet until marks were gone. Maybe that will help you.
Nov 13, 2011 | Irons
Brown coming through holes and there is a funny odor.
Tell us what water you have been adding to the iron over the years?
Often times our household drinking water is 'hard' or has iron in trace amounts in it- While it may not be toxic to our bodies-- when you boil it off in the steaming process, the minerals remain behind, and make a brown or dirty residue in the chamber. That residue will often 'bleed' out into the passages of the steam holes.
Have you ever used Vinegar to try to clean out the chamber?
Tho this might helb get rid of the residue-- it does tend to move the debris into the steam passageway-
So-- unless you have some way of spending considerable time and effort cleaning it out-- It may ruin more white shirts in the process than it is worth.
Note: Using distilled water will extend the life of a steaming iron-- but eventually, even the best treated Steam iron will need to be replaced!
Mack B
Dec 27, 2010 | Krups V70 Iron
Dirty water spraying from iron
Here is a tip that will help you see why you are getting dirty water from your steam iron...
Cleaning a Steam Iron White Scale and Brown Water
http://www.fixya.com/support/r5300985-cleaning_steam_iron_white_scale_brown
heatman101
Jun 06, 2010 | Euro-Pro Shark GI490 Iron
Dirty water in my iron
The dirty water coming out of your iron steam holes is caused by the accumulation of 'dirty' tap water: if you look inside an eletric kettle, you will see the same 'dirty' muddy brown mineral residue on the inside. In addition, if your iron is old, it can also be rust. It is a pretty common problem that can be minimized by using distilled water. You can get commercial steam iron cleaning fluid to clean the inside of your steam iron or you an simply use vinegar: 1) with a cold iron, fill the reservoir with straight vinegar 2) Place your iron on top of a metal kitchen rack above your kitchen sink, turn iron on and let it steam out all the vinegar: it should spit out the whitish mineral and muddy brown deposity. 3) Refill iron reservoir with clean water and repeat as of step 2. 4) Refill iron reservoir with clean water, wipe any dirty from the sole plate and this time on full steam, iron on clean layers of Kitchen paper to ensure that all dirt has been removed from the inside of the iron reservoir, if not, repeat from step 1 again.
In the future, try to use distilled or at least filtered water.
Hope it helps: let me know how you go!
Feb 24, 2010 | Bosch TDA8340 Iron
Brown dirt coming out of steam iron
You're seeing hard water deposits and maybe a little rust. Use some CLR and pour in the iron and let it sit with it off. Shake it a bit and let it clean it all out, then rinse with clean water. (Vinegar will work too)
Jul 01, 2009 | Sunbeam 4214 Iron
Brown steam bursts coming out of my G1490 Shark iron
make sure you do a self clean as often as possible to remove debris and scale from iron
Jun 12, 2009 | Euro-Pro Shark GI490 Iron
Tefal Pro Express GV 8120 Iron Logo
1,680 people viewed this question
Top Tefal Irons Experts
Henry  Thomas
Henry Thomas
Are you a Tefal Iron Expert? Answer questions, earn points and help others
