Question about Craftsman 8.50 Torque Rating Rear Tine Tiller
What is the valve lash adjustment settings on a craftsman 6.5hp tiller
    Novelist:
  • 144 Answers
Hi bbg713,
I hope I can help you out. The valve lash (tappet clearance) on engines of approx this size should be 0.005-0.007 inches (0.13-0.18 mm) for intake valve and 0.007-0.009 inch 0.18-0.23 mm for exhaust valve (cold engine). Adjust tappet clearance by grinding end of valve stem to increase clearance or grind valve seat deeper to decrease clearance. I hope I have helped you a bit. Any more questions are welcome. Regards and good luck. Denis.
Posted on Mar 31, 2011
Valve clearance Briggs model# 331877 1371b1
Danny, I set lash at .004" / intake and exhaust clearance. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www4.briggsandstratton.com/miscpdfs/RNT/Engine%20Specifications%20Chart_ms3992.pdf
briggs and stratton 21HP backfires like cannon
YTS3000 Craftsman model 917 289213 valve gap setting 331877 1371 B1 Briggs...
Lawn Mower Repair Valve Adjustment
Jul 08, 2016 | Garden
How to adjustvalves on kohler22 on craftsman
Gary, they may be hydraulic and not require adjustment, check the attached links, they will help determine and show how to.
http://outdoorpowerinfo.com/engine_specs/kohler_valve_clearances.asp
How to Adjust the Valves or Valve Lash on Kohler Courage XT Lawn Mower...
Work on the Cub Cadet i1046 Kohler twin setting the valves
Owners Service Manuals
Apr 14, 2016 | Cars & Trucks
How do i adjust valve lash on tecumseh 18hp OV490EA OHV140-180 ? where can I find the correct gap setting
You will remove the valve cover and adjust the lash on the valves using the rocker arm set screws. The lash should be .004 inches on all valves.
May 25, 2014 | Briggs & Stratton Garden
How to adjust valve lash on a 1990 Geo Storm
its an Isuzu engine.
there are 3 engines.
4XE1, SOHC 1.6L (base)12valves
4XE1, DOHC , 1.6L same as above but now with 16valves.
4XE1, DOHC, 1.8L bends valves if belt snaps...
note the bad idea of ISUZU calling all 3 engine same name.
a horrid idea.
which one? the second was in USA and Canada only.
the second one was offered as the GSI. is yours that?
so I will attempt to guess for you, its the base engine.
(odds of coin toss)
toss #2, USA, SOHC
guess 3: did a new belt and want to do lash next. Cam belt>
No job stated so i guess 3 times.
Just lash.
SOHC 1.6L only (FSM book quote)
Check the valve lash between the rocker arm and valve stem on both the intake and exhaust valves on the number 1 cylinder, the intake valve(s) on the number 2 cylinder and the exhaust valve on the number 3 cylinder. If the valve lash on the intake valves is not 0.006 in. (0.15mm), adjust the valve lash. If the valve lash on the exhaust valve is not 0.010 in. (0.25mm), adjust the valve lash.
1.6L twin cam has shims.
1.8L has HLA , no lash to set.
HLA= Hydraulic Lash adjusters.
I posted this before, search for it. Im only doing 1 engine.
Apr 12, 2014 | 1990 Geo Storm
How much should the valve lash be
most briggs motors i set to .006
Apr 28, 2012 | Craftsman Garden
Easy way to adjust valve lash on ford 262?
Hot Intake Valve Lash: 0.019"
Hot Exhaust Valve Lash: 0.019"
Cold Intake Valve Lash: 0.019"
Cold Exhaust Valve Lash: 0.019"
Setting valve lash while HOT is the preferred method.
This was from a 1963 Ford manual,,
Sep 26, 2011 | Ford F-100 Cars & Trucks
Overhead valves making noise like they need ajusting
Valve Lash ADJUSTMENT 1.6L Engines NOTE: Measure valve clearance with the engine cold.
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Remove the valve cover.
  3. Set the engine to Top Dead Center (TDC) of the compression stroke for the cylinder to be adjusted.
  4. Check the valve clearance. The valve clearance specifications are as follows:
    • Intake valves: 0.005-0.007 inches (0.13-0.17mm)
    • Exhaust valves: 0.005-0.007 inches (0.13-0.17mm)
  5. After adjustment, tighten the locknuts to 11-14 ft. lbs. (15-19 Nm).
  6. Repeat for each valve to be adjusted.
1.8L, 2.0L and 2.5L Engines The 1.8L, 2.0L and 2.5L engines utilize automatic hydraulic lash adjusters to maintain proper valve lash at all times. Periodic valve lash inspection and adjustment is not necessary or possible. prev.gif next.gif
Sep 14, 2010 | 2000 Chevrolet Tracker
Valve adjustment
tiburon uses hydrolic lash adjusters there are no valve lash adjusting If you hearing a pecking sound on the top of the mtr try some oil additive or replace the hydrolic lash adjusters
Jun 15, 2009 | 2001 Mitsubishi Eclipse
Craftsman 8.50 Torque Rating  Rear Tine Tiller Logo
613 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
