Question about Ryobi Garden
My RBC30SET brushcutter keeps loosing fuel from tank not from cap as its always left at the top,so must be from tank or lines? it looses it ie over night or when left for a day?
    Novelist:
  • 144 Answers
Hi golffymm2,
This problem can be from many things. I will give a few suggestions, inspect the bottom of the tank itself for any small punctures and where the fuel line exits the tank for proper sealing. Check all fuel lines for proper sealing and cracks where they connect and check for punctures or if the lines are brittle or discolored to a yellowish color, if so they should be replaced. Check the carburetor for loose screws on the carb itself or loose bolts attaching the carb to the intake manifold. Also the gaskets might have some leaks. You might have to overhaul the carburetor itself.
How do you store your grass trimmer, is it flat on the floor, stood up against a wall or hung up upside down like many people do? This would be easier to pinpoint where your leak is. Have the fuel lines been replaced? If so, it might not be the proper size, and where they enter the gas tank might leak fuel out slowly. From what you say by leaving the tank cap facing up, you store it horizontally. I think you might have a small puncture on the bottom of the tank or maybe from around where the fuel line enters the tank. Another thing that might be helpful is how much and how fast you lose fuel? Those are a few suggestions that might help. If you wish to ask more questions I will by happy to answer them. I hope this is helpful in some small way. Regards and good luck. Denis.
Posted on Mar 31, 2011
Testimonial: "thanks for that will try"
I have husqvarna yth1542xp runs about 5 minutes then shuts off. iblew thru gas line towards tank seemed like something was in line or tank. started and it ran another 5 minytes or so and same thing...
Try it with the fuel cap loose ( not off just loose). This will see if the tank is venting properly. You may also have a bad fuel filter, fuel lines or trash in the tank.
Jul 01, 2014 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Blocked overflow on fuel tank
I don't know what vehicle/equipment you're referencing here. With that in mind, can you drill a hole or holes through the chassis just below the gas cap to allow water to escape?
Jul 28, 2017 | Moto Guzzi Motorcycles
FUEL CAP LOOSE LIGHT
The fuel system is is a closed-loop system for emissions purposes. There will normally be a slight amount of pressure in the system when in use. If the ECM does not detect that pressure, the most likely suspect is the fuel cap. Check the rubber o-ring seal on the gas cap. If there are many cracks, or a section that has broken out of it, this can cause the error. An OEM approved replacement cap will fix this. Otherwise, you will need to inspect the fuels system lines, as well as the vent lines from the tank for cracks or leaks.
Jan 01, 2014 | 2009 Ford Mustang
2000 vauxhall vectra 2ltrdiesel will not start when left parked on hill for more 3 hours will start no problem on the flat or facing down hill
check for a fuel leak along the line. some where you have a loose fitting ie at the fuel filter, fuel line that is allowing the fuel to drain back to the tank The angle of the vehicle shows that airis being sucked into the system somewhere
Jan 05, 2013 | Cars & Trucks
Obd code p0457 fuel cap replaced mil reset defect not cleared connection checked ok
The code is for a large leak in the EVAP system such as a loose or missing gas cap. But it could also mean a loose or missing hose to the canister or other leak in the tank.
The computer vents the tank several times an hour while the engine is running, and it checks the system by pressurizing the gas tank. If the tank will not hold pressure the code is set.
You may have to check the top of the tank where the fuel pump gasket is, as well as the vent lines to the front of the car.
A mechanic would perform a smoke test to look for leaks.
Jul 23, 2012 | Honda Accord Cars & Trucks
Internal line in gas tank came loose
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, ``
Jan 23, 2012 | Homelite Mighty Lite Lawn Trimmer
What is code 455 (Check engine soon light) on my 2004 Chevy Trailblazer, 4.2l
CODE PO455 - EVAP SYSTEM LARGE LEAK DETECTED CONDITIONS.POSSIBLE CAUSES FUEL CAP LOOSE MISSING,FUEL TANK FULLER NECK OR FUEL SENDING UNIT O - RING IS LEAKING, FUEL TANK PRESSURE SENSOR IS DAMAGED,FUEL TANK VAPOR LINES,CLOGGED,DAMAGED,OR DISCONNECTED,PURGE VALVE VAPOR LINE IS CLOGGED,DAMAGED,OR DISCONNECTED,PURGE SOLENOID IS NOT OPENING,IT MAY BE DAMAGED OR STICKING,VENT SOLENOID IS NOT CLOSING,MAY BE DAMAGED OR STICKING,PCM HAS FAILED.
Sep 20, 2010 | Chevrolet TrailBlazer Cars & Trucks
I was trying to smog my caravan and the fault code P0456 No Description Available came up. What is that?
small leak on fuel system get down by gas tank check hoses check filler hoses pos bad gas cap loose or broken fuel vapor vacume line lines go from radiater to gas tank loose line or clampo or tank to float seal
Jun 18, 2010 | 2003 Dodge Caravan
Where does the duck valve go in a Poulan 2150 chainsaw? Iam trying to replace the fuel lines . Does it go in the fuel tank? I need a diagram of the fuel lines.
is your fuel cap missing the hold down that keeps it from falling out of the tank.if the keeper is missing from fuel cap, the valve goes in the cap.if the cap is together then it just sticks in the fuel tank hole in the top...... hope this helps,let me know.................
Jun 03, 2009 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
315 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
