Question about Krups 408-75 Electric Blades Grinder
How to remove blades from Krups 75 grinder so as to clean underneath
5 Suggested Answers
SOURCE: Krups 203-42 Electric Blades coffee grinder
i HAVE THE SAME QUESTION.
Posted on Feb 07, 2008
z34aga
  • 137 Answers
SOURCE: cleaning grinding blades
mazzers have 3 springs in grinder body, each one support for upper burr holder. check for them , if it is not the case than consider that the spring could come with coffee. often we see stones and metal parts geting between burrs.
clean it again and look good for 3 springs , if they are in their place, close the burrs to finest than go back for half of circle and grind coffee.
Posted on Apr 04, 2009
  • 3 Answers
SOURCE: Removing the blade on the Krups 203-45 coffee grinder
There are four little opening on the bottom through which you can see the clips. To get to the clips insert a screwdriver on the side and push one the clips inwards. Simultaneously, pull the bottom out. Repeat for other three clips. The process is not easy, I broke two of the clips. However, bottom seemed to go back on ok.
Posted on Sep 21, 2010
  • 474 Answers
SOURCE: how to remove blade 0f
On the bottom of the Grinder, You will find several Rectangular holes. With a flat screwdriver push tangs to release bottom. In main shaft, there is a small slot for a flat screw driver. Inseret proper dcrewdriver in slot and turn blades counter clockwise. This should remove blades..
Posted on Feb 20, 2011
Motor turns but rotating knife remains stationary
It appears that the top portion of the blade needs to be tightened to the motor shaft. You could easily do it yourself, but a shop would probably, and more safely, do it for free, as it would take less than 15 seconds to do that. Call around and see if any shop will do it for you, and ak if they will charge.......they shouldn't.
Feb 06, 2014 | Krups 408-75 Electric Blades Grinder
Tip
Krups 203 Blade Replacement Procedure
<span>Krups is among one of the foremost names in coffeemakers, espresso machines, blenders and toaster ovens. Krups also makes coffee bean grinders, such as the Krups 203a. This portable, plug-in grinder has a removable lid and bean grinder chamber. The blade on the Krups bean grinder is fastened to the bottom of the grinder chamber. You may need to replace the blade on your Krups 203. The Krups 203 comes with a limited 1-year warranty, but the company recommends you send your grinder to the company to make repairs. Order replacement parts for your grinder by calling the Krups customer service department at 1-800-526-5377.<br /><br />Unplug your Krups grinder from the wall.<br /><br />Remove the grinder's lid, and use a cloth to wipe out the inside of the grinder chamber.<br /><br />Put your safety gloves on and then grasp the blade of the grinder with your channel locks.<br /><br />Use the pliers to turn the plastic fastening nut to the left as you continue to hold the blade with the channel locks. Once the plastic nut comes loose, twist it off by hand and remove it, along with the plastic washer beneath it and the old blade.<br /><br />Set the new blade in place, and replace the washer and nut. You will have to hold the new blade in place with the channel locks as you tighten the securing nut. <br /><br />Things You'll Need<br /><br /> Cloth<br /> Safety gloves<br /> Channel locks<br /> Pliers<br /></span>
on Jun 02, 2011 | Krups 203-42 Electric Blades Grinder
How do I clean the Black 3-oz. Coffee Grinder by Krups? Remnants of all the spices I used are stuck in the blade.
The best idea is to grind some rice to remove the spice pieces that are stuck. After doing this, wipe it clean with a paper towel or a cloth towel. Try not to get it wet, this makes all the spices get clumpy and it will be even harder to clean.
Jan 24, 2013 | Kitchen Appliances - Others
How do i take out blades for cleaning
this should help
www.ehow.com/how_7968590_replace-krups-203a-grinder-blade.htm
Sep 27, 2012 | Krups Coffee Makers & Espresso Machines
Krups grinder 223
what problem do you have?
If the grinder does not run when turned on, make sure power is on to the outlet, then check the electrical cord.
If the grinder runs intermittently or doesn't stop, the switch may be clogged or damaged. Unplug the grinder and brush any grounds from the switch with a fine brush. Depress the switch several times with a toothpick. If the problem persists, disassemble the grinder to clean it and inspect the switch for breaks that you can fix.
If the grinder does not run, the motor shaft may be frozen. Disassemble the grinder, clean the shaft and lubricate each bearing point with one or two drops of lightweight machine oil. Rotate the shaft to evenly distribute the oil.
coffeegrinder1_1.jpgMost coffee grinders are accessed by removing fasteners on the base of the device.If the grinder still does not operate, the thermal limiter may be burned out. If you can't readily find a replacement thermal limiter, it may be more cost effective to replace the grinder.
If the grinder vibrates, the blade may be bent. Inspect the blade and replace if it is damaged or dull. Another cause of vibration could be a worn motor bearing. Unplug the grinder and remove the access plate. The bearing is bad if the motor shaft moves when pushed back and forth; replace the grinder.
Sep 25, 2012 | Krups Coffee Makers & Espresso Machines
Krups grinder mod 233
see this causes and proceed .God bless you
How do you change the blade? I bought a new one but can't get the old one off. Thanks
    • 1 Unplug your Krups grinder from the wall.
    • 2 Remove the grinder's lid, and use a cloth to wipe out the inside of the grinder chamber.
    • 3 Put your safety gloves on and then grasp the blade of the grinder with your channel locks.
    • 4 Use the pliers to turn the plastic fastening nut to the left as you continue to hold the blade with the channel locks. Once the plastic nut comes loose, twist it off by hand and remove it, along with the plastic washer beneath it and the old blade.
    • 5 Set the new blade in place, and replace the washer and nut. You will have to hold the new blade in place with the channel locks as you tighten the securing nut.
Things You'll Need
  • Cloth
  • Safety gloves
  • Channel locks
  • Pliers
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 02, 2011 | Krups 203 Grinder
How to remove blade 0f krupps 203 coffee grinder and clean the motor
Jan 25, 2011 | Krups Burr Coffee Grinder
Mar 25, 2009 | Krups 203-45 Grinder
Krups 408-75 Electric Blades Grinder Logo
94 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
