Question about Bosch Washing Machines
Machine set on programme, start button pressed, water flows in but but drum does not turn (motor not starting) with the result clothes unwashed!
  • Bosch Master
  • 17,130 Answers
Once the inlet valve opens and thewater flows into the drum then there is a water level sensor- a pressure sensor switch- that works to activate according to the quantity of clothes you have chosen. This switch must work and teh program controller will then switch on the motor. so the fault can be related to the program controller or to the water level sensor.
Posted on Mar 31, 2011
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
Two programme lights come on the D/W starts and it stops immediately
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
check for friction on the motor and drive.
Feb 28, 2013 | Hoover Washing Machines
Bosch Axxis WFL 2060 Front Load Washer - DRUM DOESN'T CYCLE
This seems to be a fault with the program controller unit or the water level sensor. The program does not advance further after the inlet is filled but operates the drain to exit water. Now the water level sensor must be checked as if this is not working in the stipulated time it will drain out. Also unless the water level sensor contacts on reaching of set level the motor must start.http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Mar 14, 2012 | Washing Machines
Program ends before full cycle leaving clothes in loads of soapy water, happened twice after once I had pushed end button while red with door lock in red
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect. If the inlet valve water pressure is low then the program might take more time and so result in a error. so check inlet valve flow. Also the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally check the drain pump, if choked the drain cycle will extend and result in error.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Thank you for using fixya.
Sep 17, 2011 | Hotpoint First Edition WMA22 Front Load...
I have a beko washing machine model wma 652s and the start/cancel button keeps flashing. It happened when I started a programme when I pressed the start button the machine failed to start. I've...
In this case the machine must start up to open the inlet and let the water in. If not this must be checked,If possible swap a board and check to confirm.
Once the inlett opens then the water flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Aug 18, 2011 | Washing Machines
I set my washing machine on the wrong programme and quickly turned it to a s;in cycle. Took a while before I could open the door but now to do another wash programme it is showing no power whatsoever. ...
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. REMOVe the power from the washer for few hours tto reset the processor as it could have hung up while it was interuppted.For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Jul 07, 2011 | Thomson Washing Machines
I have an Electrolux EWD1477. I have been away for four months and I'm having problems with it. I set to do the quickwash30 program and press start, you hear the clicks, it might put some water in then...
My EWD1477 was doing this a year ago and I fixed it. Then it started doing it again a month ago and I seem to have cleared it again.
Firstly, remove the drain hose from where it is inserted into a laundry sink hole to make sure it is not blocked or sealed in with sludge.
Secondly, make sure the machine is empty of water and clothes and then turn the machine to off with the Program Selector Dial. Then turn off the power at the socket and remove the power plug and leave for five minutes.
Step 1: put the plug back in and turn the power back on.
Step 2: turn the selector switch to the right (Whites/Intensive). The green light of the Start/Pause button should be flashing and the green lights on for Prewash/wash, Rinses and Spinning. Don't press any other buttons or change any other settings.
Step 3: press the Start/Pause button and wait for the machine to empty any excess water. Press it again immediately after you hear water flowing into the machine OR two audible clicks. The machine is now in pause mode with the green light of the Start/Pause button flashing. Only the green light on the Prewash/Wash button should be on. Leave it in pause mode for 30 minutes and then press the Start/Pause button to recommence the cycle.
Step 4: If the Start/Pause button begins flashing, water stops flowing into the machine and the three green lights mentioned above are back on, turn the Program Selector Dial back to off, wait 10 seconds, and repeat the process above.
Step 5: If when you then turn the Program Selector Dial to Whites/Intensive and hear the two audible clicks, immediately press the Start/Pause button to set the machine in pause mode. Wait 30 minutes. Then press the Start/Pause button to recommence the cycle.
Hopefully the cycle will run without a problem.
Mar 26, 2011 | Electrolux Washing Machines
The motor on my Miele washing machine is running constantly even when not set on a programme. The water seems to empty out as soon as it comes in. I Have to release the Stop /Start button to stop motor.
what motor do you mean the motor that spins the drum or the pump motor if its the pump motor i would check the programmer as it tells the pump when to run, on a rinse water evacuate cycle it would seem that you are stuck in that mode call a loacl engineer
Jan 16, 2010 | Miele Novotronic Premier 500 Front Load...
Whirlpool washing machine (model LLR 9245 B) does not work
If it's a top loader, the coupler is broken. It's located between the motor and the gearcase. If you put it in spin and hear the motor run, this is your problem. It drains because the pump is mounted on the opposite side of the coupler and will be un-affected
Mar 25, 2009 | Whirlpool Washing Machines
Zanussi washing machine will not start cycle.
check water level device,must have in manual,or water pump filter.
Feb 16, 2009 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
103 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
