Question about Hummingbird Exceed 9 (exmpi550305m0900u) for PC, Unix
Hello, I'm using Exceed 10.0.0.0 with AIX Version 5.3 TL10 SP1. The Exceed session closes unexpectedly, even while working in the session. In the Exceed log, I can only find the message Connection read error at xxxx (= different number each time). Do you have any idea where the problem could come from? We asked our network teams to inspect firewalls and network equipment, but they don't know what to look for? Any hints for us? Thanks in advance, Ursula Delort EURIWARE
2 Suggested Answers
  • 45 Answers
SOURCE: Exceed not working on office network
Well, first, what is your internet connection bandwidth?
Most of the vpns drop the connections when the speed is not good enough, and that means your application won't work fine.
Also, when you use WiFi you can transmit upto 54megabits per second only (the wired network speed is 100MBPS), unless you have wifi N.
Anyway, first I would check the internet speed/bandwidth, test with a faster one, and if everything goes fine, then you know what the problem was :D.
Posted on Mar 19, 2009
Why does your last browing session closed unexpetedly pop up when i login to enternet
if you shut down the computer and the browser closes unexpectedly, this will cause the browser to try to recover the last browsing session.
Mar 08, 2013 | Computers & Internet
Hello i have installed Internet exporer 9 and when i opened it, it is closed and when i try to open again, the next message come on screen that your last session closed unexpectedly. it's too much to...
Remove it then re-install it again if you wish. to remove it go to "Control Panel" >> "Programs and Features" >> "Installed Updates" >> you should find it listed there, and by removing it you should be downgraded back to IE 8, from there you may reinstall it again, or just use IE8
I hope this helps
Jun 25, 2011 | Dell Vostro 1500 Notebook
Low disk space winsxs is 10 gb how do I delete this file pls
The bad news are that i don’t recommend doing any manual removals on winsxs folder. Such a step could probably make your applications non-workable or even break your system!
If you have Vista sp1 installed use the vsp1cln.exe : The utility removes all Vista SP1 uninstall files and by using it you can reduce few gigs.
To run vsp1cln.exe:
  • Press on vista start button type cmd.exe and hit on enter.
  • hen enter the following command:Vsp1cln.exe and press enter key
  • You will be asked to confirm your action , just press “Y” and after few minutes your winsxs will be smaller.
Other ways to reduce the winsxs folder:
  • You can uninstall non needed application
  • If you have office 2007 installed , and you can get later distribution like with sp1 included – uninstall your entire office, and install the version that includes sp files.
Apr 13, 2010 | Microsoft Windows? Vista Home Basic...
Cannot write onto CD or DVD
try updating! Nero version 7 is old and cannot work in XP with any upgrade past sp1 If you have Vista now that is another reason to upgrade Nero There is a version 8 now
Jul 28, 2009 | Sony NEC Optiarc AD-7200A IDE Internal DVD...
How can I mount an IBM AIX hard drive in Windows?
AIX uses a file system that is not supported by Microsoft Windows. Most likely you will need another AIX system to read the file system. I recommend that you contact a hard drive recovery service like Ontrack Data Recovery and get some guidance.
You should remove it from the Windows computer ASAP. Windows has the habit of making changes to any disk it sees and you may lose everything!
I hope this helps.
Jul 17, 2009 | Microsoft Windows Server Standard 2003 for...
Tabs keeps closing down during chat sessions - Help!
hello
try going to tools at the top of your internet browser then internet option then click setting under the tabs section and restore it to default if that does not work try updating your browser to the lastest version
Jun 16, 2009 | Microsoft Internet Explorer 7
Normail.dot is being used by another session when closing an Attachmate X-treme Session
This was fixed in an earlier release but the fix may have been dropped in V9. It happens even with SP2. The problem is that both Word and X-treme 9 have normal.dot template files. the solution is to rename the Attachmate Normal.DOT file.
May 27, 2009 | Attachmate EXTRA! X-treme
Yahoo Mail closes unexpectedly
this is an issue with firefox 3 try to use firefox 2 when logging in yahoo mail, other yahoo services are ok.
Nov 07, 2008 | Yahoo Mail
Philips HDD6330/17 suddenly not recognized by Vista
Check which version of Windows Media Player you have loaded.
Open Windows Media Player. Click "Help" and "about". This should show which version you have.
Windows Automatic Updates may hve updated to version 11.
The Philips HDD6330 is only compatible with version 10 under Windows XP.
If you have version 11, then uninstall and it should roll back to version 10.
Dec 22, 2007 | Philips GoGear HDD6330 MP3 Player
Hummingbird Exceed 9 (exmpi550305m0900u) for PC, Unix Logo
283 people viewed this question
Top Hummingbird Computers & Internet Experts
Les Morrison
Les Morrison
Andrew Taylor
Andrew Taylor
Are you a Hummingbird Computer and Internet Expert? Answer questions, earn points and help others
