If the set had worked well and then started to shunt with an ON/OFF condition then it is possible that there is a case of low voltage into a circuit which dampens the feedback to the processor and so shuts down only to start up.
Please check the power supply, check all solder joints for drying , check electrolytic capacitors in the power , main board and driver sections.
Check any particular components that seems to heat up and cause this malfunction, it can be related to an IC that becomes unstable. Use a freeze - it spray to confirm.
