Question about Canon Pixma MP500 All-In-One InkJet Printer
Printing problem Hi When I try to print from either the lower cassette or the top paper feed the paper is getting chewed up? I have tried the maintenance of the roller as described in the manual. Nothing has helped???? Any suggestions??Thanks Sharina
I had to open the side of the printer by taking out the only screw you could see on the top and then another one you can see when you open the front cover that helps unhook the side wall of the printer. A piece of paper was stuck in there and once I removed it and put the printer back together it worked perfectly.
Posted on Aug 05, 2008
I have a Canon Pixma MG5420. I would like to print index cards using the upper cassette but I can only get the printer to print from that cassette using photo printing software. Otherwise I can't access...
Try opening control panel>devices&printers. Set the paper feed to the upper feed as permanent. Then on printer itself make sure that paper type, size and feed is where you want it.
Oct 28, 2013 | Canon PIXMA MG5420 Inkjet Photo All-in-One
The color is not printing true. When i print with my canon printer, colors are no where near true. I have been trying to print a red, cmyk: 0%, 100%, 100%, 10%, and the color is printing red-orange on...
We just bought one of these IX7000's. It is the usual giveth/taketh away situation. Ours prints beautifully from the paper cassette and pretty badly from any other feed (mostly the rear) you really have to wrestle with the driver if you print from the rear feed. If yours is printing badly from the cassette feed, I would say you have a problem with the clear ink. You may want to make sure it is inserted correctly and then clean the nozzles. I have found only one setting in which it will print nicely from the rear (envelope) feed. The cassette only accepts a limited number of paper sizes. I was disappointed by this. If it prints poorly from the cassette, it is either your driver settings or an issue with the clear ink feed. Maybe.
Nov 20, 2010 | Canon PIXMA iX7000 Inkjet Business Photo...
Follow the steps:
Turn on the printer and press the Paper Feed switch until the Auto Sheet Feeder indicator light turns on.
Pull up on the paper sheet feeder on the top and back of the printer and slide out the paper support.
Take a stack of no more than 10 pieces of photo paper and flatten the corners, if they are curled. Curled corners may cause jams within the printer.
Place the paper in the paper sheet feeder with the printable side of the paper facing up. The printable side of photo paper is the shiny or whiter side of the paper.
Print your documents as needed.
Paper Cassette :
Switch on the printer and press the Paper Feed switch until the Cassette indicator light turns on.
Pull on the cassette on the bottom of the printer to slide it out of the printer.
Flatten the corners of a stack of no more than 10 sheets of photo paper if the corners are curled. The paper may become jammed in the printer if the corners are curled.
Place the stack of paper in the cassette so the paper is touching the right side and the printing side of the paper is facing down. Adjust the plastic paper guides so they touch the paper. The paper stack guides help facilitate the paper moving into the printer.
Slide the cassette back into the bottom of the printer. The printer is ready for printing.
Oct 20, 2010 | HP PSC 2355 All-In-One InkJet Printer
Kyocera FS 4000 DN printer stops printing for no reason.
Try the feed tires in the tray first. More than likely the paper is not being picked up and causing jam message. The separation roller also has a hub on it to prevent a second sheet from feeding. Sometimes these start to lock up ,a little oil on the hub sometimes relieves some of the tension.
Jun 03, 2010 | Kyocera FS- 4000DTN Laser Printer
IP4700 series has 2-way paper feeding. Please check you paper feeding from bottom cassette or rear auto feed!
Before perform the printing job, you may notice on your printer right side can select paper feed from rear or bottom.
Enjoy printing.
May 29, 2010 | Canon iP4700 InkJet Photo Printer
Printer does not attempt to pick up paper but gives out of paper message and or flashing paper sign on panel
(a) driving a pickup roller, picking up printing paper stacked in a paper cassette, and then, feeding the picked up printing paper to an image forming unit
(b) after picking up the printing paper in step (a), checking to determine whether or not the printing paper has been fed to the image forming unit(c) when it has been determined in step (b) that the printing paper has not been fed and a paper feed error has been generated, again driving the pickup roller, so as to attempt to pick up the printing paper stacked in the paper cassette again.
Apr 21, 2010 | HP Officejet Pro K5400 All-In-One InkJet...
Grinding Sound - Orange Paper Jam Light
You have a broken gear main motor. I had the same problem, bought $5 part and after the replacement of the gear,it runs like new
Dec 04, 2008 | HP LaserJet 4L Printer
Canon pixma ip 8500 won't feed paper
I have discovered that my problem was a one inch nail which had at some time been dropped into the paper feed slot. It could not be seen from the outside of the printer and was only discovered when I removed the side trim and top cover. When closely inspecting the nylon roller system that feeds the paper out, I saw a tiny piece of metal that looked out of place. Further probing then loosened the nail back to the paper input area.
My printer is now back in full operating condition after spending a couple of careful hours finding out how to remove the trim.
A well worth while exercise in my case.
Oct 15, 2008 | Canon PIXMA iP8500 InkJet Photo Printer
HP IIIp prints extra blank pages
HI there make sure that the paper tray guides are fully against the paper also try sending the job through the manual feed to see if you get the same problem. If you do not then it maybe that the paper cassette separation pad is worn and will need replacing. If your model has no rubber pad at the front of the cassette then you will have a metal hold over one corner of the paper make sure that when the paper lifts that the paper sits under the silver (Dog Ear) as this acts as a separator.
Hope this helps
Thanks J
Jan 28, 2008 | HP LaserJet IIIp Printer
Canon Pixma MP500 All-In-One InkJet Printer Logo
23 people viewed this question
old marine
old marine
