Question about AudioCodes Mediant 600 1 Span SIP Router
"The board detected a new
Can a Box Switch Record Logs and Alarms After a Loop Detection-enabled Interface Detects a Loop?
A fixed switch (such as S2309TP-EI-DC) can record alarms but not logs after a loop detection-enabled interface detects a loop. The configurations are as follows:
In V100R005 and V100R006, you can run the snmp-agent trap enable feature-name ldttrap command to enable the alarm function for loop detection. If snmp-agent trap enable has been configured globally, the alarm function has been enabled.
Loop detection and loopback detection have been available since V200R001. You can run the snmp-agent trap enable feature-name ldttrap command to enable the alarm function for loop detection and run the snmp-agent trap enable feature-name lbdt command to enable the alarm function for loopback detection.
You can run the display trapbuffer command to view alarms.
Jul 18, 2016 | Computers & Internet
Code E60 flashing on screen of electrolux ewf1087 after powere cut during cycle. can't reset can't open help please
Electrolux E60 - NO WATER DETECTED ENTERING MACHINE OR PRESSURE SWITCH TRIP NOT DETECTED.
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or blocked or scaled up screens in the inlet valves
    3. Verify inlet valve operation
  • If there is water in the unit:
    1. Verify Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operation
Mar 13, 2011 | Electrolux Washing Machines
How does the COM1 port need to be configured ? I get the "Error Communicating to Printer " error in Label Vista. Do I need to change the baudrate ?
Hi
have you verify if you can read file on the printer ? (with label vista go to printer tab and click on read file)
Jean Christophe Millard
Feb 10, 2011 | Zebra QL 420 Plus Thermal Label Printer
After restore database lost my graph of sales ,
You should run Verify to check for damage whenever QuickBooks appears to be functioning improperly or erroneously. The Verify Data utility detects data damage, and then logs any errors it finds in a file named Qbwin.log. The Qbwin.log file is contiguous, so that every time you verify, rebuild, condense, or update your data, any integrity issues found will be appended to the end of the Qbwin.log file. It is common for the Qbwin.log to become very large. You can identify only current errors in the data file by renaming the Qbwin.log file, located in your QuickBooks directory, to Qbwin.old. QuickBooks will create a new Qbwin.log file to store the results of the utility you ran most recently. To run the Verify utility
check this for more details
Jan 18, 2011 | Intuit QuickBooks Pro 2010 Full Version...
I was trying to backup my server while exchanging DLT tapes, the tape in use light stayed on and the serve would then alternate to four flashing lights and then back to flashing "Tape In Use...
Try the following action to resovle your issue:
1. Run the Drive Assessment Test in HP StorageWorks Library and Tape Tools.
CAUTION: Running the Drive Assessment Test overwrites the tape. If it is not possible to
overwrite the tape, run the logs-based Device Analysis Test instead.
2. Check the backup logs.
3. Verify that a supported configuration is being used.
4. Check for media damage:
o Incorrect label placement
o Broken, missing, or loose leader pin
o Damaged cartridge seam
o Usage in incorrect environment
5. Check for software issues:
a. Check the backup software.
b. Check that virus scanning software is not scheduled to run at the same time as the back-up.
6. Verify that a tape can be formatted.
Tape Error LED is flashing:
1. Reload the suspect tape. If the Tape Error LED stops flashing, the problem has cleared.
2. Load a new or known good tape. If the Tape Error LED stops flashing, the problem has cleared.
3. Reload the suspect tape. If the Tape Error LED flashes, discard the suspect media as faulty.
From my experience, most of the time it is a bad tape, using a new tape usually solves the problem. If after inserting a new tape and the problem exist, you may need to update your firmware/backup software.
Good Luck
C2Solutions
Jan 13, 2011 | HP Compaq ProLiant ML350 G3 Server
Whenever i try to access my Windows Movie Maker or Skype there is a message that reads "A video capture device was not detected. Verify that a device is turned on and connected properly, and try...
Just reset it! At the back of the router is a small hole.With a toothpick or some like press gently for 30 seconds and wait for the router to start up again.Log in to http://192.xxx.xxx and start a new configuration.
If you need more help come back.
Post / thumbs / testimonial are welcome!
Dec 31, 2010 | Computers & Internet
It beeps and rotates a blinking "H" and an "F" in
No water detected entering machine or Pressure switch trip not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
Potential Causes
- Make sure that both valves at the water source(s) are turned on all the way.
- Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
- Verify inlet valve operation
- Verify Drain pump operation
- Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
• Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
Nov 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My network can't detect the new sato cl408e we just purchased.
1.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop,desktop,printer do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
7. Move the device about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
Jun 29, 2010 | SATO CL408e Label Printer
I have a gestetner DSm745e it keeps on poping out a code SC302 however i don't have a manual for it can you help me?
Charge roller current leak.The polling module detects a current leak of the charge roller.Check,clean or change the charge roller,verify the connection of the PCU,and verify the high voltage suplly board conectors.Turning the main power switch OFF and ON resets the SC code if the error is caused by incorrect sensor detection.
Nov 20, 2009 | Gestetner DSm745 Black and White Copier
Reboot is in a loop and c drive is corrupt
I had this same problem on a machine that was brought in for me to repair. After removing a lot of spyware, the machine started logging out immediately after logging on. Here's how I fixed it: First: I used the XP CD to boot to the recovery console("R" at the first prompt). From there, I ran chkdsk /r c: to fix problems on the hard drive. There were plenty. Second: I rebooted to the XP CD to repair the installation of Windows XP. Do not use the "R" Recovery Console this time. Instead go through as if you are going to reinstall afresh and when it detects the current installation, choose the option to repair it. That corrected the problem. It seemed to be an issue with errors on the hard drive related to corrupted user profiles because I could not log in with any account. Hope this helps.
May 06, 2009 | Acer Aspire 5500 5570-2609 Laptop
AudioCodes Mediant 600 1 Span SIP Router Logo
141 people viewed this question
Top AudioCodes Computers & Internet Experts
Are you an AudioCodes Computer and Internet Expert? Answer questions, earn points and help others
