Compressuir turns but a/c dose not kick in (hot air only)
  • 182 Answers
Fan turns on outdoor unit....compressor doesnt run?could be alot of things.due to the voltage involved i'd say get a pro to check it.
Posted on Aug 05, 2008
I have a Deammaker hot tub. The tub works and pump is running. When I turn on the air valve the is no change in jets. The air vave is opening when turned.
I don't know this model but most hot tub have a micro switch on the valve that starts the compressor to confirm turn the power off then removing the access panel and take the wires of the switch and connect to gether then turn back on if the compressor is working then the switch needs replacing if it is not workin the the compressor is faulty
Jan 18, 2015 | Dream Maker Spas Pool & Spa
1996 buick centrey fuse box
Does the compressor kick in when you turn it on?(if not it could be the a/c switch or the power to it, the a/c clutch wire connection, the clutch itself, or it's low on freon) You should hear the clutch kick in when you turn the a/c on. Low freon will also cause the clutch to not kick in. Remove the low-pressure switch plug and jump it with a piece of electrical wire. If the clutch kicks in, you just need to add some freon. Put the plug back where it was after you remove the jumper wire.
Is the belt on and adjusted to the right tension? If the belt is loose it won't cool as good as it should.
Check the freon in the system with a gage. If it's low, add some to the right amount and see if it cools. If it is overcharged, it will blow hot air, too.
The heater control valve slider should be all the way to the left so hot water isn't allowed to circulate through the heater core which would also make it blow hot air out the a/c ducts.
Good luck, they can be a pain, but with careful, step by step troubleshooting it can be fixed. There is plenty of information about a/c online to help you out. Try googling in: auto ac troubleshooting tips for more info. garcuda
Sep 03, 2014 | 1996 Buick Century
A/c dosnt cool
it does sound like the coolant leval is low does the compressor kick in and out very quickly if it does it is low if it dosen't engage you may have a leak in the system or it maybe a bad relay or fuse see if it work partially then recharge if it dose
Jun 30, 2012 | Chevrolet Silverado 2500HD Cars & Trucks
A/C stopped working and blowing hot air. Is there a fuse to check?
In almost every case, when hot air blows while AC is turned on, it's an indication the system is low on refrigerant. This could be due to a leak in the system. There are do-it-yourself kits sold at most auto parts stores or a qualified service station can recharge your system (they have to check for leaks prior to recharging the system).
If you can hear the compressor kicking on and are still getting hot air, check coolant level. If coolant level is good and compressor is kicking on, you may need to change out your thermostat.
Aug 05, 2011 | 2005 Honda CR-V
Compressor not kicking in when i turn the air conditioning on.
what is the make and model? how long has it been switched on? is the compressor top hot?
Jun 23, 2009 | Dometic Rooftop RV Air Conditioner
1992 honda accord ex 4 door heater not blowing
You may have a clogged heater core, leaking heating cores still provide heat.
Dec 04, 2008 | 1992 Honda Accord
Heating & Cooling Logo
67 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
