Question about Refrigerators
How do you change the direction of the door opening.
  • 126 Answers
(THIS IS A TWO PERSON JOB)(be sure u unload the door first)At the top of the door u have a bracket with three screws or bolts in it, take out the screws while the other person holds the door once this is done take off top bracket the door should lift off of the bottom bracket,now take the bracket off the bottom of the refrigerator,On the other side of the fridge there should be some small white plastic plugs pull them out ,this is were u will put the bottom bracket ,u will also have some plugs on the top of the fridge too..be sure u put the plugs back in the holes that u just took the screws out of.Put the bottom bracket on first,do not over tighten screws,then take ur door place the bottom of door on bottom bracket,put bracket for top of door in the top and screw back down now ur door should be good make sure it closes correctly,and of course put the stuff back in the fridge
Posted on Mar 31, 2011
Change door opening direction
I seriously doubt that can be done.
Dec 01, 2013 | Samsung WF8704RSW
Tip
Switching door opening direction in Tadiran Appolo 103
Even though in the support I was told that in that specific model there is no way to change the door opening direction, I manged to switch it. The door handles are now useless and confusing, but overall the fridge is ok.
on Oct 04, 2011 | Refrigerators
I want to change the direction of the opening on my kenmore from right to left. Is this difficult?
Hello and Welcome to FixYa!
What I understand from your query is that you want to alter the door opening direction If I'm right... Altering the door such that it opens on the counter side is possible. but in most cases, it ruins the working of the device completely.. actually changing the direction causes many things to go wild from the refrigerator light switch. to the refrigerator doors gasket. Also it requires some new holes to be drilled at the other side... That turns the alteration to more complex and tricky.. In a nut shell, I would not suggest to have such changes to your equipment.
Have a nice day,
Please do Rate the solution, if you feel that this helps you,
Concerned.
Sep 18, 2010 | Kenmore 64823 Top Freezer Refrigerator
Have a genie garage with two doors and need to change one to open, one of the doors that use to open another door. Other door is opened by bluetooth by autmobile. How do you change code on unit on ceiling...
Go to this site and follow the directions under "Replacing a lost or stolen remote" Then you will need to program your bluetooth.
http://www.aaaremotes.com/gegadooptr1.html
Feb 15, 2010 | Sears Craftsman LiftMaster Chamberlain...
Can you change the door direction on a Maytag
Unfortunately, you can only change front loading dryer door directions on some models. Washing machines do not allow this. If the units are stacked i may be easier to switch loads, otherwise the dryer door may be able to have the door swing direction changed but without the Dryer model # I couldn't say for sure.
Dec 29, 2009 | Maytag EPIC MFW9700S Front Load Washer
I want to change the direction the freezer door opens ?
You didn't mention whether this is a combination freezer/refrigerator but I'll assume it is.
If you inspect the areas opposite where the hinges currently are mounted, you should see some small, cosmetic plugs that can be pried out. These are the mounting points for changing the opening direction of the doors.
On most units however, doors would both have to be moved since the center hinge is normally a single piece with hinge pins pointed up as well as down. The hinge mounts should have holes slightly larger than needed so that the closure of the doors can be slightly changed to correct alignment.
Oct 27, 2009 | Hotpoint Refrigerators
My garage door opener moves about 8" then reverses direction before touching the limits
Remove the cover and take a look at the drive gear. It is white nylon and is just in front of the motor. It is most likely stripped. You can purchase a new one at Sears or any good door opener company. It comes with instructions.
May 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Keypad will close door, but not open it!
Try changing the battery and reprogam the keypad. The code remains active for about 30 sec. after it is entered into the keypad which allows you to press enter to change direction of the door
Jan 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Is it possible to change hte direction the door opens
no its not possiable because of the latch assembly
Mar 15, 2008 | Kenmore 42822 Front Load Washer
Refrigerators Logo
110 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
