Question about Lexmark P4350 All-In-One InkJet Printer
How do i change printer cartridges ? - Lexmark P4350 All-In-One InkJet Printer
  • 639 Answers
Step Action Image 1 Ensure the All-In-One printer is powered on. No image. 2
Lift the scanner unit or access door (per right-hand image).
The cartridge holder will move to the center of the Inkjet or All-In-One.
how do i change printer cartridges ? - pattlnk_3232007_1123-01%20open%20scanner%20unit.jpg 3 Press down on the cartridge carrier latch to raise the carrier lid. 4 Remove the used cartridge. NOTE: If you are removing both cartridges, repeat the preceding two steps for the second cartridge. No image. 5
Remove the protective tape from the back and bottom of the new cartridge(s).
WARNING! Do not touch the gold contact area on the back or the metal nozzles on the bottom of the cartridges. pattlnk_1202009_2013-remove_tape.gif 6a Insert the new cartridges into their respective carriers. The image at right illustrates insehow do i change printer cartridges ? - pattlnk_1202009_2024-color_install.gifhttp://i.fixya.net/uploads/images/pattlnk_1202009_2024-color_install.gif" alt="pattlnk_1202009_2024-color_install.gif" class="h_mi" /> 6b 7 Close the carrier lids so that they remain closed. See image above in Step 3. No image. 8 Close the access door or scanner unit, taking care to keep your hands out from underneath the scanner unit as it is being closed. No image. 9 On some All-In-One units, the control panel display will prompt you to load paper and print an alignment page. NOTE: The scanner unit must be closed before you can start a new scan, print, copy, or fax job. No image.
Posted on Mar 31, 2011
Testimonial: "Thanks for the info. Very much apreciated as I have lost the manual. Many thanks !!"
Can't get WF-3520 cartridge holder box from far right position so I can remove & replace an ink cartridge
To force cartridge removal do the following
Shut down the printer (if it is powered on)
Now turn the printer on
When you see that the carriage starts to move instantly unplug the printer power cable
Now you can move the carriage freely by hand!
Move it in the cartridge change position and change the cartridge you want to change
Do it just if the printer has a defective cartridge and the carriage won't go to the cartridge change position :)
Hope you found it useful!
Dec 17, 2015 | Epson WorkForce WF-3520 All-in-One Inkjet...
How to change the inkjets
  1. Open the top panel of your inkjet printer. You should be able to access the ink cartridges once the top is open. Some printers will reposition the cartridge carriage to provide you better access.
  2. 2
    Remove the old cartridge from the carriage. Depending on the printer, you may need to press down on the cartridge and then pull outward to remove it. Other printers may require you to lift the cartridge out of the printer.
  3. 3
    Unpackage the new replacement cartridge completely. New cartridges will often include plastic strips and protective packaging that must be removed before you can insert the cartridge into the printer.
  4. 4
    Insert the new cartridge into the printer. This will be the reverse of removing the old cartridge.
  5. 5
    Close the top panel of your inkjet printer and allow the printer to detect the new cartridge. You should now be able to print using your newly changed inkjet cartridge.
Jan 02, 2011 | Canon Office Equipment & Supplies
What is the cause of my printer o be saying change cartrige when i already change it
It may be some reasons:
1. Cartridge incorrectly changed. Just be sure to remove and set the new cartridge correctly.
2. No good connection. Sometimes ink spills on the cartridge connectors OR the protective plastic still set on the cartridge. Clean the connectors with a soft cloth and be sure to remove the plastics - see installation guide on cartridge.
3. No procedure was done. To change a cartridge correctly, some printers require a procedure for it, be sure to read the user manual how to change cartridge.
Other non-common issues: bad new cartridge, faulty printer, software or firmware glitch, etc,
Apr 15, 2010 | Brother MFC 420CN All-In-One InkJet...
HP officejet pro 8500 ink cartridge problem
Changing a printer cartridge is not complex but improper handling of the parts may damage the printer and the cartridge. If the user notices that while printing the ink comes out dry or faded, it may be time to change the ink or the toner. The user will know if it is time to change the toner because instead of a sharp image, one will get a faded image. It is time to change the ink cartridge when the printing comes out spotty or colors are used to replace others —for instance, blue for black or yellow for red. Remember, faded images signal the need to change the toner; spotty printing signals the need to change the ink cartridge get more help for change cartridge .
Hope this helps you.
Jan 21, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Change cartridge on epson cx5500
Please try their website and search for the manual.
Sep 27, 2009 | Epson Stylus CX5000 InkJet Photo Printer
Cannot use ink cartridge after initialization. Happens every time I change cartridges although cartridge was sent to me by HP themselves. When do I change the cartridge - I presume before I turn the...
You change the cartridge whenever the printer software says to, or when the color starts to fade on prints. You can change the cartridge with the computer and/or printer on or off, it doesnt matter
Sep 21, 2009 | HP Photosmart C5180 All-In-One InkJet...
Changing ink cartridge
Turn on your printer and raise the lid or press the cartridge changing button. Wait for the cartridge carrier to slide out.
Lift the cartridge holder lid, and the cartridge will pop up for removal.
Carefully remove the tape from the ink opening on the bottom of new cartridge.
Insert the new cartridge into the cartridge carrier. Make sure the new cartridge is oriented the same way that the old cartridge had been.
Close the cartridge holder lid and press the cleaning button to charge the cartridge.
Close printer cover.
Mar 07, 2009 | Epson Stylus C86 InkJet Printer
Printer won't recognize ink cartridge change
changed black K cartridge with new one but still shows black toner empty! Could toner cartridge be faulty?
Dec 05, 2008 | Konica Minolta magicolor 5430 DL Laser...
HP 1610, Remove Cartridge message
also replace the colour cartridge as it is not showing but the printer is not able to detect that cartridge also.many a times it solves the problem.
Sep 30, 2008 | HP PSC 1610v All-in-One Printer
My printer alarm after i changed cartridge
you may have touch/damage the sensor when you force the head... try to reinitialize your printer and reinstall the cartridge
Aug 29, 2007 | Canon BJC 4300 InkJet Printer
Lexmark P4350 All-In-One InkJet Printer Logo
142 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
