Question about JBL CM52 Speaker
Which amplifier that match 2 of JBL CM52 speaker and 2 of Bose 151
  • 635 Answers
If you want to run both the speakers at a time you will have to buy a professional amplifier like CROWN XLS202.
Because together the total impedance will drop below 3 Ohms. An average domestic amplifier is designed to run speakers between 4 to 8 Ohms.
If you are running only one pair at a time you can buy any of the following Amplifiers.
Marantz - PM 7003
NAD C356
Posted on Mar 31, 2011
How do I connect 2 jbl ct 26 speakers in a series to Bose sa3
I don't know the impedance of these speakers but the Bose SA3 amplifier is 100watts per channel.A higher wattage speaker may damage the audio amplifiers.
Aug 28, 2012 | Bose SA3
Bose 321 power woofer buzzes but produces no audio sound
I assume the other two speakers are working fine. Contact Bose and ask them. Could be a simple fuse. Sounds like a fried speaker driver, but do this first. Take the back off and check the power amplifier for a blown fuse. If none, disconnect the power amplifier. Reconnect the speaker cabinet w/o the built-in power amplifier to a known good amplifier to see if the speaker works. If it works then you know its the built-in power amp that's fried. Contact Bose for a replacement or better yet buy a another one with a higher RMS watt capacity. Wattage ratings in other than RMS are worthless. JBL and Cerwin Vega produce high wattage units. You need to keep the volume lower to avoid the problem in the future.
Aug 27, 2012 | Bose Audio Players & Recorders
Can i connect bose speakers with denon amp
The brand of the amplifier doesn't matter one bit as long as it has enough output to power the speakers the way they are designed, so the answer is yes.
Jan 25, 2012 | JBL LSR25P Speaker
Which model of amplifier will match the Bose AM 10 series4
There's a pretty decent write up for this speaker system on CNet. The "Speaker System" section calls for an amplifier capable of 10 - 150 watts RMS.
Bose maintains a library on their products as well. You can download FAQs, Manuals and Product Information easily. On the accessories tab, Bose lists an Onkyo receiver for $350 that will work very well with this speaker system. Of course, any quality modern stereo receiver or amplifier with power in this range 10 - 150 watts should provide good results, but better amps will be in the 75 watts and greater range.
I hope this helps - good luck
Sep 14, 2010 | Bose Acoustimass 10 Series IV Home...
What kind of amplifier and other accessories are recommended for bose 901 speakers
I would recommend a high power 2-channel amplifier, minimum 16 guage speaker wire, and of course the Bose 901 active EQ that matches the series of your speakers. I use a Yamaha mx-830 power amp & cx-830 pre amp 170 wpc They (Bose) claim that they're unlimited power handling, But if you use a amplifier with to little power and overdrive it to make it louder, you could damage the speakers or amp. With my 170 watt class A amp,the 901 series 6 will blow wind across the room. Go with the best amp you can afford! best for money- Yamaha,Denon,Onkyo!
Dec 22, 2008 | Bose 901 VI Main / Stereo Speaker
Bose speaker 151
Hi
I checked in the specs of the manual here. page 6. They quote it as being suitable for 4-8 ohm AMPLIFIERS. but do not mention the actual impedance. I would expect from that that the speakers must be close to 8 ohms, as you they would not advise you to connect a 4 ohm speaker to an 8 ohm output stage, as likely damage could result. If you had a multi meter, you could do a DC resistance check of the speaker, this is generally very close to the impedance. happy to talk to you more about it.
regards
robotek
Nov 04, 2008 | Bose Lifestyle SA-2 2-Channel Amplifier
Do all speakers have fuses? I may have blown one of my Bose 151 outdoor speakers, but can't find a fuse inside.
Unfortunately many speakers do not have fuses. Most likely the voice coil has opened up inside the speaker itself. You can either get a replacement driver (speaker) or re-cone the one you have. In any case, the driver needs to be replaced.
You can verify this if you use an ohmmeter. With an 8 ohm impedence speaker, the reading should be about 6 ohms. If you read a higher number or infinity, the coil is bad.
Dan
Oct 08, 2008 | Bose 151 Main / Stereo Speaker
259 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
