Question about Microwave Ovens
I have a Maytag gas stove and the 2 of the burners are clogged. We rent and don't have a manual for it, so I'm kinda flying blindly here. Don't want to break anything. It says it's self cleaning but that doesn't work anymore for sure, I've tried it. Would it be ok to go ahead and use an oven cleaner in the oven? Two problems and I hope you can help me, if not at least point me in the right direction. Thank you so much Susie Wilson
    Brigadier General:
  • 8,909 Answers
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Posted on Mar 31, 2011
Hot plate just wont turn on...switches checked in meter box and no iscolating switch. baumatic ceramic cook top. BA 13.2 ( i think) house just been sold. Hotplate wked thurs. House sold Fri. new owner...
Hello, is this a two electrical filament hot plate? Also, is this range stove/oven? I'm a little confused here on what exactly what you are referring to hot plate or cook stove with electrical burners and oven. If it a really old hot plate with one burner look at the plug there could be a fuse in it. If it is electrical range then check the control board and see they a fuse on. If not, check the voltage with a volt meter. Be very careful here there two phase that is 240 Volts AC. The voltage will be split between the two l20 hot legs AC which is 120 degrees out of phase in respect to each other; in other words, don't both of them don't let them touch each other.
If it a kitchen stove I'm fairly sure that the control board is shot and with this not operating it will not open the current/voltage relays for the electrical burners. REMEMBER YOU ARE DEALING WITH 240 VOLT AC...BE CAREFUL.... GB....stewbison
Aug 26, 2011 | Baumatic Microwave Ovens
Hi, I have a Maytag stove and unfortunately have lost my manual. In the last couple of days there has been an alarm going off with F1 appearing on the display panel. Once at 5:30 am and at 1:00 am. Could...
With Maytag Ovens the F1 error means Defective touch pad or clock (ERC). This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present. (If you don't feel comfortable doing this yourself you need to arrange a repair technician to look at it for you)
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Regards, Kat (please leave feedback, thanks)
Aug 19, 2011 | Maytag Microwave Ovens
Just got this RV. I can't get the range to light. Is there a shut-off valve that I just don't know about???
There may be a valve under the cook top or under the stove. You will of course have to look. There is really no 'standard' or requriement for a valve to be there.
Another reason for this kind of problem is spiders. Spiders love the smell of propane. If you are sure your gas is ON and you do have fuel in the tanks and the tanks are on, (always have the valves of both tanks open all the time (consistent with the highway regulations in your area) and the selecter lever is pointed left or right (never n the middle!)!) remove each burner and blow it out with compressed air. Simply blow it out with your breath or get some 'canned air' at the computer store.
Does your frig operate on gas? You can force it to run on gas (to check it) by disconnecting the 115 Volts; simply disconnect your main cord. Will your frig come on? How about your heater? and your hot water heater?
YOU MUST have a 12 volt battery connected to your RV - a "HOUSE" battery not a "VEHCLE" battery. Everything in your RV runs on 12 volts except the obvious 115 items like the AC and the microwave and the TV. Do not rely on the 15 amp "converter' to supply all your 12 power requirements which often exceed the ability of your converter to provide.
If you stil have no luck, I suggest you turn off the tanks and disconnect the gas line from the stove. Have an associate turn on the tanks while you observe (smell, watch, listen) the unattached pipe. If you hear, smell or see gas, have them turn it off immediately. Reconnect the pipe and test for gas tightness (use a soap water misture. Bubbles = leak. Next step will be to consider the burner controls. This may not be a DIY job. NOTE: Propane is heavy and will sink to the floor. Make sure you have no open lights or flames when you perform the test above and let the gas excape out the open door.
You don't say how old the RV is and given the thousands of makes and models it really doesn't make a lot of difference. Unlike cars and trucks, manufactures of RV's install what they have subject to many substitutions through out the model year. Typically, newer RVs have electronic ignitions while some older RVs have pilots (NOTE: pilots burn precious limited fuel and generate unnecessary heat) and many are simple match light burners.
I hope I have shed a little light on your trouble and you are able to resolve this problem. If you cannot, of course, you will have to have reservations for supper which will make you or your spouse happy.
I hope you enjoy your camper this summer. Thank you for your interest in FixYa.com and please come again.
Jul 24, 2011 | Microwave Ovens
Maytag MGR5730BDW gas range oven do not bake, the automatic pilot turn on but burner bake don't start
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jul 04, 2011 | Microwave Ovens
The fans on this microwave will automatically turn on when I have more than one burner on the gas range going. The fan is horrendously loud and will not allow me to shut off for 2-3 minutes regardless if I...
That's typically normal operation. The microwave has a thermostat which turns on the hood vent exhaust fan at a certain temperature to protect the controller.
Your owner's manual will cover vent fan operation.
If for some reason you don't have yours, you can download Whirlpool owner's manuals and installation instructions here.
I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
If - above and beyond this - the fan has a problem, that could make it excessively loud. Some are just loud though, it's hard to judge without actually hearing it.
You can contact Whirlpool customer service with your model number via that link above and ask them about the loudness. They may be able to tell by listening over the phone if it's abnormally loud.
Apr 28, 2011 | Whirlpool MH7130XE Microwave Oven
I have a kenmore stove whose burners wont light. oven works fine. burners will spark but no gas comes out. recently I turned off the power to the stove by turning the fuse off. what do I need to do to get...
If the gets give no gas then sounds like a Thermocouple, this is a device that allows the gas to come on after a period of time ensuring that the pilot is lit and heated up this thermocouple, once it heats it then allows gas to enter and ignite the main burner..hope this helps ,please leave feedback.
Apr 12, 2010 | Kenmore 66469 / 66462 / 66464 Microwave...
Stove won't stay lit!!
So, you cleaned the burner per the manual (or the one you looked at when visiting the appliance store,) and it still flames out right after coming on? Sometimes things catch in the works and there are a few methods to clear them out (e.g. at the controls) depending on the model. Beyond that,in order to disconnect the stove and check the inlet filters, you might want to call the appliance or gas co for a technician. No use having leaks, searching forever for the main shutoff valve, etc.
Mar 24, 2008 | GE XL1800 1100 Watts Microwave Oven
Microwave Ovens Logo
29 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
