Question about Tefal FF1006002 Maxi-Fry Deep Fryer
I have it plugged in, switched on, at whatever temperature and there is no red light on and no sign of the oil heating up.
    Sergeant:
    Champion:
  • 422 Answers
A sort of power problem. A blown fuse will cause that, if it had power but no oil heating up, then a open heater is the culprit or a disconnected wiring inside cause that problem.
I hope I help you answer your problem.
Posted on Mar 31, 2011
  • wayneKW Apr 22, 2011
    Where could you find the fuse in the T-Fal deep fryer? It is pretty simple wiring but no fuse can ever seen. Please help be more specific. Thanks a lot.
How do I turn on?
I just tested a Eurodib Model SFE01860-120 that would not turn on.
If you have added oil and plugged it in and pressed the on/off switch but the light does not come on, you have to rotate the thermostat control to the desired oil heating temperature. The red light will then come on and it should start to heat. If not, then the high limit safety cut off switch has tripped. Check the black screw button on the back.
Using a larger flat blade screw driver or your hand, unscrew the cover counter clockwise and push the little pink (red?) rod back in all the way. Replace the cover of the limit switch and all should be good to go. If not, then there must be loose wires inside. The high limit switch could have tripped if the fryer was turned on without oil for any length of time, which would cause the heater element to get hot really fast. Not a good idea.
Hope this helps
Dr Fix-it.
Aug 17, 2015 | Kitchen Appliances - Others
Coolant and heating fault
I would guess that the entire cooling system needs to be cleaned and flushed, and any leaks fixed. If you are having to add coolant continuously, then you have a leak someplace. Check all your hoses and the water pump for any signs of a leak. Run the car until it's at normal operating temperature, then shut it off. While it's cooling down, look closely under the engine for any signs of a leak (drips, etc.) If you can't find anything, there is a possibility there is an internal leak someplace. Check your oil dipstick for any signs of water in the oil, and pull the spark plugs and inspect them for any signs of water. If you can't find the problem after this, you probably will be better off taking it to a shop.
Jan 24, 2014 | Cars & Trucks
2001 Oldsmobile Silhouette...Overheating, changed the thermostat, no signs of leaking, and the oil looks fine. At idle it takes 20 minutes to max the temperature gauge (red) and while driving it take
Usually the problem with no heat and overheating is low coolant, thermostat, or a faulty water pump impeller.
The radiator may not be full of liquid coolant, or the pump may not be moving the coolant thru the block.
Feb 19, 2013 | 2001 Oldsmobile Silhouette
Why light blinks then goes off when switch is still in the on position
The thermostat in the iron controls the temperature of the iron. The red light indicates when the power applied to heat the iron which is set by the temperature dial on the iron. When it reaches the correct temperature the thermostat turn off the power and that is when the red light switches off.
Jan 15, 2012 | Irons
How do you turn on a comfort zone cz7007? has a knob that turns up to 7 and 2 red switches right next to each other.
On the comfort zone CZ7007, the #1 rocker switch is for 600 watts, the #2 rocker switch is for 900 watts. If you flip 1 and 2 both to on you will get 1500 watts. Which is 600 and 900 added together. There is no down position, but only on and off.
Sep 24, 2010 | Comfort Zone CZ7007 Oil Filled Electric...
Check engine soon light on. oil changed regularly. what else needs to be checked - cjp
go to autozone and get a check engine light test done, its free. ask them to tell you what comes up on the computer.
Jun 24, 2009 | 1987 Mercury Sable
VW Cooling System
Hi Lori . Sorry but it sounds like your water pump inpeller (The internal part that circulates the water) has broken off or come lose . But i would recomend changing the cambelt and tensioner as well . Regards VW Audi tech
Jan 09, 2009 | 2001 Volkswagen Beetle
Tefal FF1006002 Maxi-Fry Deep Fryer Logo
184 people viewed this question
Top Tefal Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
paul
paul
Oscar Netto
Oscar Netto
Are you a Tefal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
