Question about Bosch Logixx WFR 2867 Front Load Washer
Bosch Logixx WFR2868GB Control Panel broken, dial and display panel, can it be fixed / replace?
    Brigadier General:
  • 6,277 Answers
I would expect it should be available but you could try checking with spares suppliers to make certain. It might take some time ;-0)
Spares Suppliers
You will need to type into your search engine/web browser '(make) washer spares' and you should be presented with a number of sources from which you can order. During the process you will be asked for the actual model number and possibly other information such as the serial number.
Good luck,
John C
Posted on Mar 31, 2011
Pls how can i unblock a pump on bosch logixx
Turn it anticlockwise
if it won't turn it has something inside jamming it
you will need to remove the pump and filter assembly and take it apart to clear it
Jan 08, 2015 | Bosch Logixx WFT 2806 Front Load...
Bosch logixx 8 varioperfect
you will have a broken spider in the machine
Jul 22, 2014 | Washing Machines
Bosch Logixx 8 - unblocking pump/removing front panels
Bosch Logixx 8 Washing Machine This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Aug 30, 2012 | Washing Machines
Hi my Bosch Logixx fridge keeps switching off and now the temperature light is flashing
Chances are the electronic board has something to do with its erratic operation. As you know it control the operation of the refrigerator including temperature control, defrost timer, etc.But before replacing that, have the compressor, relay, overload protection be check. That is located at the back of the refrigerator.
Sep 01, 2011 | Bosch Logixx KDR40423 Refrigerator
I have a bosch logixx 8 washing machine. Fault code f67 when I turn the machine on. What does this mean?
I have Logixx8 WAS 32782 that got the f-67 code. I had it repaired today and the technichan updated the software. f-67 was indicating "lost contact with display panel". The display panel had of some reason erased its software. SW update was the standard solution.
Oct 02, 2010 | Bosch Washing Machines
The door handle strip on my Bosch logixx fridge has two broken fixings. I have bought a new handle strip but the 2 remaining fixing points are OK so I can't get the old strip off! Any ideas on how to...
I have a Logixx with the same problem. Brute force was the answer. You cant lever the tongues out of the way and so cant release the handle gently. Use a piece of wood and lever the handle forward in the same direction as you open the door and it should come off. The new handle then snaps back in. You may need to remove the residue of the old broken part of the clips.
Sep 23, 2010 | Bosch Logixx KTR18420 Compact Refrigerator
Bosch logixx code f-23 .wat does it mean?
it means the float at the base of the machine has been triggered. Open the back panel on the machine (turn off power and water tap first) then remove all screws and take metallic back off. Dry inside base with a towel and push down the float which is located in the corner. This will reset it. Keep an eye on it as it may mean you have a leak.
Aug 02, 2010 | Bosch Logixx WFT 2806 Front Load...
My bosch logixx dishwasher quick wash has never
i would change the control board or control module. thermador .com will let you order it.
Apr 09, 2010 | Bosch SHU9915UC Dishwasher
Bosch HBN745AUC control panel broken and needs to be replaced. Any DIY advise appreciate, included the parts no. and cost information.
If you mean the glass in front of the display and touch panel is smashed, you can buy a new glass panel, about $200, part 239424 (for a stainless oven), see bosch parts link below. Probably the electronic touch sensor board underneath is fine, but its basically glued to the glass panel so will be a bit tricky to peel off and re-glue to the new one.
http://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/us/prodp.htm?prod=HBL745AUC%2f02&ESHOPTYPE=S
Jul 12, 2009 | Bosch HBL 745 Stainless Steel Electric...
Bosch Dishwasher SGS43E02 Exxcel Control/Display Facia Panel
The panel is replaceable by removing the #20 torx screws inside the door. Once removed the metal outer door cover will slide down and the plastic top housing less switch panel can be unclipped from two locking tabs on either side. You can order via BOSCH service center, check to see if it is warrantied before removing
Feb 06, 2008 | Bosch 24 in. SGS43E02 Exxcel Built-In...
Bosch Logixx WFR 2867 Front Load Washer Logo
178 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
