Question about ASUS VIA Apollo Pro133A Chipset P3V4X Motherboard
I have purchased an appollo pama 3 and have charged it for over an lhour, but it will not turn on. I have tried the reset button, this is not helping, can you. thanks Jackie Stephens
Can't get sandisk sansa fuze+ to turn on, what do I do
Hold the on/off slider for 30-40 seconds and then release to reset the device. Then try turning it on. Also, sometimes if the battery is low/dead it will take longer than 3 hours to charge up. If it does not turn on after the reset you might try letting it charge for a day or so and try again. If it doesn't work after all of this, it should be returned to where ever you bought it for a replacement.
Aug 13, 2014 | SanDisk Sansa Fuze MP3 Player
Won't charge
Please make sure the tablet is charged for at least 4-6 hours. Also, make sure the correct button is being used, oftentimes we hear the back or home button has been used in error. If the issue persists, you can try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
If your tablet does not have the reset button: With the tablet plugged into the charger, hold the power button for 10 seconds then click the volume up once. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
Support Troubleshooting Guide
Feb 25, 2014 | Kocaso M M9100 9-Inch 8 GB Tablet
Need unlock code
try using numbers instead of letters. PAMA (7262) if that doesnt work, try 0000
Jul 29, 2009 | LG Shine CU720 Cellular Phone
Flip Mino HD will not boot, charge or reset
Call Flip support, problems are happening to too many people, contact Flip support, if they cannot help, contact MacWorld or other online reviewers and let them know.
Jul 06, 2009 | Pure Digital Flip Mino Digital Camera
Pama bluetooth manual
pama omega bluetooth handsfree kit pairing code
Jun 30, 2009 | Handspring Visor Prism Handheld
Tom tom one not turning on used 3 months
I had some problems with the 920. It started to not turn on. The it just died completely. After opening the case and testing the battery. I concluded the battery was dead and Un-chargable.
Which is most likely the case with yours.
Try this first. Then contact customer support.
  1. Check that the battery is charged properly.
    Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
  2. Remove the SD card
    If your device uses an SD card, remove it.
  3. Reset your device.
    Use a straightened paper clip, or something similar, to push the reset button for 15 seconds. See the pictures below for where to find the reset button.
  4. Turn your device on.
    Press the On/off button for at least 5 seconds.
  5. Insert the SD card
    If your device uses an SD card, insert the SD card
Unless you are good with electronics. Then id change the battery myself. I used a cell phone battery.
It has worked for the last year.
Regards and I hope this helped.
James
Sketchlab.com
May 28, 2009 | Tomtom ONE GPS Receiver
Phone will not charge and screen keeps showing pineapple logo
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also,Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 23, 2009 | Apple iPhone Smartphone
I can't turn my TomTom 130 on. Charged it for 3
Try doing a reset. Hold the on/off button down for 20 seconds.
Hope this helps
Mar 06, 2009 | Tomtom ONE 130 GPS Receiver
Forgotten how to pair my hands free
I FOUND THE INSTRUTIONS IN .PDF AT PAMA.COM. I WAS ABLE TO PAIR MINE. GOOD LUCK!
https://www.pama.com/product_images/mediabank/documents/EPSILON_instructions.pdf
Dec 27, 2008 | Cell Phones
Blank screen
To reset your TomTom device:
1. Charge your device.
Charge your device for at least 2 hours. Make sure the charging light on your device is on (except RIDER which has no charging light).
2. Remove the SD card.
Use a straightened paper clip, or something similar, to push the reset button. For a visual representation of the reset button, see below.
Press and hold the On/Off button for at least 4 full seconds.
5. Insert the SD card.
If your device uses an SD card, insert the SD card.
images of where to find the reset button can be found here.
Sep 04, 2007 | Tomtom ONE Regional Car GPS Receiver
ASUS VIA Apollo Pro133A Chipset P3V4X Motherboard Logo
18 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
