My SDP63SWA is not switching on what do i do? it fell from my bed and since then is not been working please help me out
    Brigadier General:
  • 8,909 Answers
It sounds like it has sustained internal damage. What sort of damage I cannot tell.
I would take it to a local repair shop and get an extimate for repair.
Posted on Mar 31, 2011
98 regal low bed don't work but the high beams do....????? HELP ME PLEASE
Turn on the low beams and check to see if you have battery voltage at the connectors, if not, check the fuse panels for a blown fuse, if all the fuses check out Ok, The next step is to check the high beam switch, called a multi-function switch on the column. It's not that common for the headlight switch itself to fail, however, the main connector to the headlight switch can and do fatigue, sometimes even melt due to a poor connection. I would check for that first as it is a common problem. Your wiring diagram will give you the wire color codes so you know which wire to test.
Apr 21, 2013 | Cars & Trucks
1986 sca wolff 328sl tanning bed wont stay running
Consult manufacturer. You can track that down online. You may have a over-temp switch inside the bed. If so, then either the switch is bad or the bed is getting too hot. Have a trained technician to check voltage going to bed, if voltage is wrong that can cause bed to overheat. Make sure all fans are running, replace any fan that is not running. Clean all dust out of bed with vacuum and brush while you have it open.
Dec 15, 2012 | Wolff Sunvision Pro 24S Tanning Bed
My Adjusta-magic control for my Englander bed will not work. HELP PLEASE! The foot of the bed will not go down.
1) You must open the foot of the bed , and see for the switch, and test it with a VOM, see for open , tight any wires loose cables, or broken and repair. God bless you
Jun 13, 2012 | One For All URC-3300 Remote Control
WIRELESS REMOTE CONTROL - MODEL - r2t3/r2t4. Wonder if you can help please! Have an Electric Adjustable Bed with a remote which has stopped working. Details on the back of the remote are - Model No:R2-T3....
I have a remote for adjustable bed that won't work. I know it is the remote, because I put a new 9V battery in and the red light doesn't come on. Model No:R2-T3. FCC ID: MGB _R2-T (03-680252-03). I see someone posted the same problem and don't see any recommendation to fix or replace it.
Jan 05, 2011 | Televison & Video
My psp fell and now games from memory card are not loading
Did you try the memory card on another PSP? Or try another memory card in your PSP? If your memory card works in another PSP, then there's a problem with your memory card reader.
If you have a PSP-1001 model, it's not your motherboard but the circuit board that holds the memory cards.
If you have a PSP-2001 or PSP-3001, the memory card reader is a part of the motherboard and they are correct -- bad motherboard.
Nov 12, 2009 | Sony PlayStation Portable (PSP) Console
My remote fell off my bed and fell apart and now doesnt work. its an rca tv 244889 remote control. can someone please help fix it. Thanx
You should be able to fix the remote yourself with a screwdriver. if the plastic has broken of the circuit board has broken all you can do is replace it im afraid.
Mar 10, 2009 | RCA 244889 Remote Control
3680 2682 Laptop fell off bed to floor w/ USB drive plug in back
hi, if the port is working fine, its ok.. but do not use this port, since its damaged, it could short the pins inside while pluging the cable, left side is better
Jan 03, 2008 | Acer Aspire 3680 Laptop
Help me
ive read in other places on the net that some of the switches are not soldered on very well i read some were that some folks were selling them for spare parts. but you might try the firmware up=graded if you can find it on the net or have a cd that cam with the player. http://www.lenoxx.com/2005/mp3player/mp556.htm if you have a ilo model mp-556 (on the back cover) this page has links to the firmware ... i follow the instruction and got mine working.
Aug 06, 2007 | iLO MP3 Player
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
