Question about Microwave Ovens
I lost the sealing-ring for my blender. How can I get a new one? solveig
    Brigadier General:
  • 8,909 Answers
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Posted on Mar 31, 2011
I have a blender thats been about 20+ years old... However, although I continue to use it well, lately it has been subject to leaking and other issues. I suspect that the rubber part (to hold the liquids...
Do you happen to know the make / model of your blender? If you do, you should be able to go to the manufacturer's website and order a replacement "o-ring".
Aug 17, 2011 | Microwave Ovens
Is the blades supposed to come off when I take the container off of the blender.. My blender is brand new sat for 3 or 4 years after I bought it. . The first time I used it , it was extremely hard to get...
You did not specify a brand or model number of your blender; however, most blender jars will lift off their power base without turning or with only very little turning motion to release them from the base. The blade assembly should NOT come off as you remove the blender jar from the power base.
Were you successful in removing the bottom ring which normally screws on to the bottom of the blender jar from the powerbase?
You should make sure you have properly attached the blade assembly for your brand/model.
The blender blade assembly should be held on to the bottom of the blender jar by the bottom ring which screws on clockwise; most will have a sealing gasket that fits between the blade assembly and the sealing surface of the blender jar to prevent any leakage while in use. It will take much more turning to unscrew the bottom ring to release the blade assembly than it should to release the bottom ring from the powerbase.
Assemble your blender jar and blade assembly and try a dry run by placing on the powerbase, giving a couple of bursts of power, and then seeing if you are able to remove without the blender ring unscrewing.
Make sure you are comfortable with the action required to remove the blender jar from the powerbase before you put in to use.
Jul 31, 2011 | Microwave Ovens
My blender Leakes at the gaskit or ring
Best is to clean the leak and then observe using a good powerful lamp to check into the sections.
It can leak at the gasket or the ring or from a WORN OUT spindle shaft.
So check the play of the shaft as if the BUSHES are wron out the liquid can leak.
Jul 21, 2011 | Hamilton Beach Microwave Ovens
My waring blender quit working. There was no burnt smell, just quit running. Is it repeirable?
Hi Cindy -
Technically, everything is repairable. The real question is: How much are you willing to spend on repairing an old blender? You should bring it to an appliance repair shop for an estimate, because without actually seeing it - it is going to be anybody's guess as to what is wrong with it based on the info you've provided (it is often difficult to diagnose this stuff by description only as most times methodical testing is required) . It may be a simple, inexpensive fix - or it may "break the bank."
While waiting for your estimate, you should price a new blender. You may find there are some that have more features for less than you paid for the Waring model (or even less than the repair estimate). Once you have the price for repair and the price for a replacement, you can decide which path is best for you.
I hope this help & good luck. Please rate my reply - thanks!
Jan 27, 2011 | Microwave Ovens
I need a new sealing ring for the Ultrex 05082c pressure cooker. The customer service numbers are disconnected.
I have the same problem, please advice where you purchased your sealing ring. medinajavier@yahoo.com
Nov 15, 2010 | Microwave Ovens
Why my new oster blender blade rotates counterclockwise and not clockwise?
It is a function of gearing or motor orientation, and it makes no difference which way it rotates, as long as all of the attachments need the same rotation....
Nov 06, 2010 | Microwave Ovens
Hi, I have lost my manual for my JE7700 Smoothie Juice Bar 2 Speed Blender, I was wondering if you know where I can get one?
Try calling Kenwood directly at 023 9247 6000. You should be able to order a manual directly from them.
Oct 31, 2010 | Microwave Ovens
My blender won't power on, the lights don't turn on. I've had the blender for 1 year and have never had any problems with it. In the past month it would only work intermittently, and now it doesn't work...
sometimes something (food etc) gets "stuck" in the lock mechanism, preventing it from turning. unplug the blender and give the locking mechanism a cleaning with a bottle brush or rinsing it under very hot water. also the lock could be broken/chipped, also preventing it from turning.
i must admit that I broke my locking mechanism 5 years ago by not "seating" it correctly and forcing it. my hubby somehow removed! the locking mechanism but now it goes on - turns - as soon as I plug my blender in (because the stop/lock doesn't exist anymore). so I must be very careful to always have the lid on before I plug it in. but it's a braun blender and I love it. so i've kept it all this time.
Oct 06, 2010 | Microwave Ovens
Microwave Ovens Logo
41 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
