Question about Epson Aculaser C1100 Printer
A white streak appears on the right hand side of the print out
  • 1,719 Answers
If faded prints happen even after replacing the toner cartridge or if your current cartridge has enough toner, it is most likely be due to dust at the laser reflecting mirrors inside the printer.
I have worked/ serviced similar Laserjet Printer with same issue.
Actually, faded prints are due the the dust/ toner dust accumulated on the optics (mirrors and lenses) inside the printer, which refect the laser beams to form prints. Hence the image is not produced properly. This needs professional hands for servicing and cleaning of the optics inside the printer.
Rest assure that the printer requires ONLY CLEANING OF THE MIRRORS, which are inside the printer. So, it is advised that you get the printer serviced by any printer repair/ service professional. (Please note that the mirrors, lenses and scanner assembly inside such printers is extremely complex and can get damaged very easily especially the mirrors).
Hope it would help. If you need any clarification, let me know
Good Luck!
CreativeTECH
Posted on Mar 31, 2011
  • 39 Answers
Causes:
Contamination in the laser path
Failing toner cartridge
What to do:
*remove toner cartridge and shake it gently from side to side to distribute the toner inside. Reinstall. If nothing changes, replace the toner cartridge.
*Clean the laser scanner mirrors and lens
Posted on Jan 31, 2013
  • 85 Answers
O understand that not print or print on that very vaguely shows wear probably check cartridge with many printed pages and may be close to another cartridge goleventual inocuieste
2 Suggested Answers
  • 2567 Answers
SOURCE: Print output shows a white
It looks more like a problem with the drum itself. If you have a replacement drum, try to use it & see if this cures the problem.
Please feel free to let me know in case you have any further questions.
Posted on Jun 15, 2011
This started out as error 5200. Now, my Canon MX340 printer isn't connecting to the computer. The computer acts like the printer hasn't been installed. I tried to remove the printhead and restart...
Issue: How do I align the print head?
Solution: Perform a Print Head Alignment (Windows)- MX340
Aligning the Print Head Position Print head alignment corrects the installation positions of the print head and improves deviated colors and lines. The procedure for performing print head alignment is as follows:
alignike.gif Print Head Alignment
  1. Open the printer driver setup window
    • In Windows Vista, select the Start menu -> Control Panel -> Hardware and Sound -> Printers.
    • In Windows XP, select the Start menu -> Control Panel -> Printers and Other Hardware -> Printers and Faxes.
    • In Windows 2000, select the Start menu -> Settings -> Printers.
  2. Right-click your model name icon, and then select Printing Preferences from the displayed menu.
    The printer driver setup window appears.
  3. Click Custom Settings on the Maintenance tab.
    The Custom Settings dialog box opens.
  4. Check the Align heads manually check box.
  5. Click Send, and click OK when the confirmation message appears.
  6. Click Print Head Alignment alignike.gif on the Maintenance tab The Start Print Head Alignment dialog box opens.
  7. Load three sheets of A4 size or Letter size plain paper into the rear tray (3).
  8. Execute head alignment Make sure that the machine is on and click Align Print Head.
    Follow the instruction in the message.
  9. Check the printed pattern
    Enter the numbers of the patterns with the least amount of streaks in the associated boxes.
    Clicking the patterns with the least amount of streaks in the preview window, will automatically set their numbers in the associated boxes.
  10. When you have entered all the necessary values, click OK.
    Note:
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable vertical white streaks.
      (A) Less noticeable vertical white streaks
      (B) More noticeable vertical white streaks
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal white streaks.
      (A) Less noticeable horizontal white streaks
      (B) More noticeable horizontal white streaks
  11. Confirm the displayed message and click OK.
    The second pattern is printed.
    Important: Do not open the Scanning Unit (Cover) while printing is in progress.
  12. Check the printed pattern
  13. When you have entered all the necessary values, click OK.
    Note:
  14. Confirm the displayed message and click OK.
    The third pattern is printed.
  15. Check the printed pattern
    Enter the numbers of the patterns with the least noticeable horizontal stripes in the associated boxes.
    Clicking the patterns with the least noticeable horizontal stripes in the preview window, will automatically set their numbers in the associated boxes.
  16. When you have entered all the necessary values, click OK.
    Note:
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal white stripes.
      (A) Less noticeable horizontal white stripes
      (B) More noticeable horizontal white stripes
Note: To print and check the current setting, open the Start Print Head Alignment dialog box, and click Print Alignment Value.
Aug 11, 2011 | Canon PIXMA MX340 Wireless Office...
Hi, My Canon 3245 Imagerunner is streaking.
First, the streaks appears when copy from glass or adf, when printing or all?
Solution #1:
How many copies did you do from last drum changing? if over 80 000 copies, replace the drum unit.
-in case that streaks appears when copy and print
Solution #2:
If the streaks appears only if you copy from adf or glass, clean the glass and dry it out. Both glasses, narrow on left side beneath the adf/cover and glass for copy of original.
Solution #3:
If the streaks are wide and solid, with possible toner left overs, you need to replace fixing film.
Hope that helps!
Apr 04, 2011 | Canon ImageRunner 3245 Black and White...
My canon pixma 480 has thin horizontal lines. tried cleaning and deep cleaning where is the head alignment tool?
The instructions as copied from the Pixma 480 "onscreen manual." (Only the text -- not the images -- could be pasted into the solution. Hope you can follow the text.) Steve G.
Prepare 2 sheets of A4 or Letter-sized plain paper
1. Make sure that the power is turned on, and load 2 sheets of A4 or Letter-sized plain paper in the Rear Tray.
2. Open the Paper Output Tray gently, and open the Output Tray Extension.
3. Print the print head alignment pattern.
- Press the Menu button.
- Select Maintenance, and press the OK button.
- Select Print head alignment, and press the OK button.
Note: To print the current head position adjustment values, select Head alignment print in the Maintenance menu and press the OK button. See Selecting Menus on the Top Menu Screen.)
- Select Yes, and press the OK button to print alignment sheet.
- Check the pattern is printed correctly, select Yes and press OK button.
- Confirm the displayed message and press the OK button.
The Print head alignment screen appears.
4. Adjust the print head position.
- Check the printed patterns, and use the (Left) or (Right) button to select the number of the pattern that has the least noticeable streaks for column A.
Note: If it is difficult to select the best pattern, select the pattern that has the least noticeable white streaks.
(B) Noticeable vertical white streaks
(C) Less noticeable horizontal white streaks
(D) Noticeable horizontal white streaks
- Repeat the same procedure to input the pattern number for each column from B to L, then press the OK button.
- Select Yes to continue printing, and press the OK button.
- The second page of print head alignment sheet will be printed.
- Confirm the message for print head alignment, and press the OK button.
- Check the printed patterns and use the (Left) or (Right) button to input the number of the pattern that has the least noticeable horizontal streaks for column M.
- Repeat the same procedure to input the pattern number for each column from N to R, and press the OK button.
Jan 12, 2011 | Canon Pixma MP480 All-In-One InkJet...
Ricoh 1224c prints on left side only - Blank on right side
well if its just on the black then it might be the black drum see if it does the same on the color from copying and printing. If it does the same in color then its not the drums it may be the developers, but you wont know untill you test the color if it only happens in black and white its definitely a problem with the drum.
Mar 25, 2010 | Ricoh Aficio 1232C Color Copier
We have recently bought a second hand OKI C5200 Colour Laser Printer and even though the black and white print seems to be great the clour is coming out with coloured streaks, what would you recommend?
One or more of the drums may be defective. Swap the black with another color and print a document. If that color printed the charectors ok, then continue the test with the other drums each taking a turn in the Black drum position until you find the bad drum.
Oct 08, 2009 | OKI C5200n Laser Printer
Color streaks on page
Had a similar problem. Tried lost of things. In my case, the streaks cleared up after I cleaned the toner drum.
Aug 25, 2009 | Brother MFC-9420CN All-In-One Laser...
Black streaks down left side of printouts Epson Aculaser C2600
I had exactly the same problem. Luckily we have 3 of these printers. Swapped the photoconductor and it solved the vertical streaking, even though the photoconductor was only half way through its life.
Dec 02, 2008 | Office Equipment & Supplies
Print quality Epson C1100
It sounds as though a cartridge is faulty. To determine which one, the easiest way is to run a page of text/block of colour through in yellow then cyan then magenta. which ever page comes out with the streaks on it will tell you which cartyridge to ditch and replace. Hope this helps Cops Pete@wedotoners.com
Oct 10, 2007 | Epson Aculaser C1100 Printer
Epson Aculaser C1100 Printer Logo
336 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
