Question about Microwave Ovens
I have a range master 110 clasic 2007 when the small oven was switched on a fan would come on. my engineer says that this model has no fan because it is gas.
    Brigadier General:
  • 8,909 Answers
I have a Rangemaster and like yours is dual fuel. Gas hob and electric oven. The large oven is fan assisted but the small oven, on the right hand side of the range) is self cleaning and not fan assisted.
Hope that helps.
http://www.pricerunner.co.uk/sp/rangemaster_classic_110.html
Posted on Mar 31, 2011
My microwave oven model 721.85033111 vent fan stays on
You probably have a bad fan thermostat. This thermostat is supposed to turn on the vent fan if the microwave oven gets too hot (caused by cooking too much or having too many burners turned on on the range beneath the microwave oven). It should shut off in about 15 minutes after your turn off the range burners. But if it comes on for no reason, or won't turn off, then You probably have a bad fan thermostat.
Aug 10, 2014 | Kenmore Microwave Ovens
I hane a Galaxy over the range microwave model # 721.80002401. The problem is the fan randomly turns on and will not go off unless I unplug it.
May be a defective fan switch or the unit is detecting some heat there--not likely to be a do it yourself repair--consider having a shop look at it for you---
Jun 16, 2012 | Kenmore 64002 Microwave Oven
GE Over range microwave model JVM1443LK01 This started a couple days ago. After removeing something from the microwave and we shut the door, the fan started up. The fan will run as long as the door is...
I would check the door switches for a faulty switch. If it were condensation on the control panel. I would think it would have dried out by now unless it has damaged the control board.
Mar 22, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My whirlpool Gr2 microven Model # GH6177-XPS does not heat. All display functions seem operable otherwise.
Sorry to read about your problem.
It seems your have a general failure in the power control or switch failure on the unit. if you unit has power, and things lite. it is more likely you have a control/switch problem,
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
dsddd
Dec 23, 2010 | Whirlpool GH6177XPS Microwave Oven
Model is GE JVM1430BD002. Microwave works but range fan and lights do not. Unit "popped" when fan was turned on one time and hasn't worked since. Is there a fuse or breaker for the range hood functions?
Yes - there is an internal "special" in-line fuse. Most likely it is the fan that has caused it. Clean the fan with switch-cleaner spray and make sure it is smooth running. Replace special fuse with identical version.
Check lights before operation.
Replace all covers before test.
Oct 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Door-activated power switch is loose and/or has a short
Fixed this problem! The door latches were greasy and sticking in the closed position (i.e., pushed down so not latching and engaging fully when the door was closed) and this created the problems described above. Solution was to squirt some Windex into the latch holes to dissolve the grease. The switches popped back into position (must be spring-loaded) and the door closed and latched properly, allowing the oven to function properly. I swabbed out the hole with a q-tip, let it dry for 20 minutes and all is well.
Nov 17, 2008 | Whirlpool MH6150XMS Microwave Oven
Frigidaire PLMV169cd Microwave Exaust Fan Hums but wont run
Do you mean the hood vent fan? (That would be a large assembly a little smnaller than a loaf of bread, I guess)
If it's this one, I would suggest you check the big starting capacitor on the circuit board and the connections on that cap.
Or do you mean the cooling fan inside, which would be small enough to basically fit in your hand?
In either case, I would measure the line voltage to be sure it's in the 110-125VAC range.
If it's grossly outside this range, you may have a problem with other electronics or light bulbs bblowing or being dim or erratic.
One handy thing about Whirlpools is that behind the control panel they have a mini-manual which is very useful in troubleshooting.
It may be that you have some toruble on your control board, which we repair for customers nationwide.
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Nov 30, 2007 | Whirlpool MH1150XMQ Microwave Oven
Will i need a separate 110 circuit????? cannot use the 220v leg??
I would contact a few electricians for their opinions. Appliances like microwaves and ranges, etc. should be on separate circuits / breakers due to the high currents they draw.
Dec 08, 2006 | Kenmore 62622 Microwave Oven
Microwave Ovens Logo
123 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
