Question about Garden
Hi just put our new lay z spa up but the pump wont bleed. There is water round the filter but it doesnt rise up enough to push the air out.
  • 126 Answers
Is the pump setting higher that the water in ur spa??? and there should be a pitcock valve to open on ur filter to let air out
Posted on Mar 31, 2011
My coleman lay-z spa pump is making an intermittent loud sound. All filters are new and spa is clean. What to do?
Could be your motor, bearings going bad or whatnot, pump flow being restricted, bad impeller, or the heater. If it sounds like metal its motor, water noise is the pump flow, and heater is other? I've heard banging and cracks from heater water heating too much and not enough flow. No mater what it is call and see if you warranty is good still.
Dec 11, 2015 | Pool & Spa
Hot tub turned off during filter replacement
Hi Amy, When you say " I can't get it back on" do you mean the breaker won't reset? Is there power at the spa? Is the pump running but not pumping water? Depending on the spa, you may have created an air lock in the system and need to bleed the air out. It's possible that some water got into the equipment area and shorted out the system. In which case you need to open the equipment area and dry everything out before trying to turn the breaker back on. I would need more specific info to help you with this problem.
Nov 10, 2013 | Pool & Spa
Spapool pump
First things first. When ever you fill your spa put the hose into where the filter goes, if it's a top load filter. Or into the skimmer if your spa has one. That way as it fills it forces more air out of the lines as it fills and limits how much air gets trapped in the lines. That being said, turn the power off, you can't bleed the pump if its running. On most pumps there is a bleed plug threaded into the face plate of the wet end. Loosen the plug until you hear air coming out. Once the pump fills with water and water is coming out of the plug, tighten it up and turn the spa on. I t may take several try's before you get rid of all the air in the lines.
Nov 08, 2013 | Pool & Spa
How do you bleed the line?
Make sure the pump is primed ... the cover in place ... turn on the pump. The pu p will push the air out.
Jun 25, 2012 | Hayward Pool & Spa
Difficulty in putting filter back together in getting clamp ring on
When reassembling the grids place the manifold upside down on a five gal. bucket. Then assemble that way, this will hold the grids stable and make that part much easier.
When that is done and in place. Lightly grease the tank "O" ring. Then run the pump to fill the bottom of the filter with water. With the air bleed closed set the top and lightly push down. As the water inside runs back to the pool the suction created will pull the top down tight. Then just set the ring and tighten.
Sep 13, 2010 | Pentair FILTER TANK BOTTOM, 48 SQFT
My pool filter is running but it doesnt seem to **** the water in or out and we got this last year but every two weeks i had to take it apart and for about a week and a half it works and then doesnt
It is getting air locked... they are very suseptable to that....just open the top a crack and bleed the air off whwn it stops and it will work again..
heatman101
Aug 05, 2010 | Intex Krystal Clear Model 635 Pool Filter...
Very weak suction on inlet side. Water is green.
unscrew the top valve on the filter carteidge and let the air bleed out
clean filter every day and run it 24/7
Intex pumps can not filter good enough
Jun 09, 2010 | Intex Automatic Salt Water System for ...
Brand new system... Code 90... Checked for air in hoses & loose hoses, changed pump filter, everything installed correctly... Help????
Make sure your flow sensor moves freely. Soak the unit in vinegar if it looks dirty
I would also try bleeding the system run your pump with the bleeder screw on top of the filter cartridge open a few turns Just enough to allow the water and air to flow do this for a minute or so and then tighten the screw
Jun 04, 2010 | Intex Automatic Salt Water System for ...
My self priming spa pump wont prime
Check fittings at front of pump for tightness. Threds have to been hand tight with 1.5 to 2 full turns with wrench. Also put ear to front of inlet fitting into pump and listen for air hissing, also an indication that threads arent tight enough or misaligned.
Jan 20, 2009 | Pool & Spa
Garden Logo
87 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
