Question about GE Refrigerators
My g.e. 2 door no frost refrigerator are not cooling well but my freezer are ok.
  • 126 Answers
Open ur freezer and can u tell if it's blowing cold air or it just cold air,because if i'm right there's a fan back there in the freezer,
behide the vent, and if this fan has gone out,your freezer will be cool but ur fridge won't be
Posted on Mar 31, 2011
Back of freezer has frost and freezer wont cool to proper temp. icemaker etc also not working
Did you leave the freezer door open for a period of time while the refrigerator was running? Unplug and defrost the freezer manually with a hair dryer until all frost is removed inside and in back of the freezer. Reapply power and see if it will then cool/freeze properly. Let me know the results
APPLIANCE 911
Jan 10, 2016 | Samsung RH29H9000SR RH29H9000SR 36"...
My whirpool freezer is ok but fridge not cool the fan is ok too
Check ur cold control thermostat, ur thermistors, ur air flow vent from freezer to fridge.( to make sure it opens and closes without any restrictions) On thermistors check for A close circuit and amount of ohms not just an Ohm reading. As per ur model. Most should atleast show 1200 ohms. Also Check door seals for leakage.
Evaporator coils
Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Apr 03, 2015 | Whirpool Refrigerators
LG 262SQA Model fridge cannot cool
That does not look like an LG model number, but regardless, it sounds like the defrost system is not working, allowing frost to build up and block air flow over the cooling coils in the freezer (where all the cooling for the entire refrigerator takes place). Take back panel off inside freezer, melt frost / ice with a hair blower. Test for continuity through defrost heater and replace if "open". If it was OK, problem could be deftost control, or as simple as a door not fully closed at some time, allowing excessive frost build up.
Nov 18, 2011 | LG Refrigerators
My son left fridge door open, from 1-2 hours. it doesn't seem to be cooling now. Is there a problem or does it take a while for condensor to come back on?
What has happened is that the evaporator (the cooling coils inside the freezer) have frosted up due to all the moist air which entered the refrig with the door open. This frost has blocked the normal flow of air within the refrigerator/ freezer. Turn unit off, unload freezer, and leave freezer door open for several hours to allow built up frost to melt. Better yet, remove the panel at the back of the freezer and melt the frost off with a hair blower.
Dec 02, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
FROST IN FREEZER WATER IN REFRIGERATOR DOOR SEALS SEEM OK
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Nov 13, 2009 | GE (GTS16BBS) Top Freezer Refrigerator
Samsung refrigerator - frost on outside of freezer drawers
try checking the freezer door seal.
if slight gap anywhere around the door seal drawer fronts will frost up.
warm seal up with hair dryer and ease seal out with your hands..
problem often happens with door reversal.
Oct 09, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
The freezer side not freezing just cool, the
Open freezer door, pull food off shelves on lower half of inside freezer and look if you have frost building up on the back wall of freezer. If you do then you have a defrost heater or thermostat possible gone bad.
Advise if you have frost build up and I will advise on how to check it.
Oct 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
No cooling
Both refrigerator and freezer operate from one system. Air from freezer cools refrigerator. Check back wall of freezer for frost buildup. If frost is evident on the back wall of the freezer it indicates a defrost system problem.
Aug 08, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
54 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
