Question about Panasonic Televison & Video
What will be the problem when it is not showing power
  • Panasonic Master
  • 467 Answers
No power is a typical failure of the switchmode power supply, which, unless you have sufficient knowledge of this circuit, requires a workshop service centre repair. Several components, including the most likely culprits (electrolytic capacitors) will need replacing. In extreme cases, the entire PCB will need to be replaced.
Bad caps are usually very easy to spot in most power supplies, look for crooked, swollen or bulging caps, and/or splits in their vents (the impressions in the tops of them) along with electrolyte spilling out (electrolyte is highly corrosive, so if any has leaked out of any caps onto the PCB, it may damage the copper tracks). Some may have dropped in value, some may be open-circuit (no capacitance at all), while others may have taken out one or more IC regulator and/or the chopper transistor(s); this could lead to an expensive repair, particularly if surface-mounted components on the copper side of the board are short-circuited.
NOTE: when servicing switchmode power supplies, with electrolytic capacitors, it is standard practice to replace ALL the caps in this circuit to ensure reliability and to minimise the likelihood of a service recall later - even if the ESR of some caps measures OK, they should still be replaced, and in a lot of cases, the working voltages and values of those capacitors which are replaced may be uprated/increased.
As I said, unless you have knowledge (and experience) with this type of circuit, submit your unit to an authorised repair centre, get a quote on the likely repair cost(s) and/or a second opinion from an authorised technician as to the extent of the fault(s) in your unit, then make a firm decision afterwards as to what you want to do about it.
It's up to you - either spend a fortune in repairs to this one, or, if it is NOT a DVD recorder, buy a new player - but only as a last resort. I suggest that you get the repair quote first before going any further.
Posted on Mar 31, 2011
Show me how and where to hook up power cord, to charge battery for camcorder, omni2
many camcorders have a power pack that attaches to the camcorder and then the battery attaches to the power pack you can also put the plug in and run the camcorder when everything's attached
Feb 26, 2015 | Video Cameras
Could you show me the correct way how to power up the hard drive box a green circular light is by the power cord is on when plug up but the fan is not running could you show me what is wrong the computer...
Could you take a picture of the entire back of the PC? You only show the power supply connected with power, what about the graphics card output? and power to your monitor etc.?
Oct 19, 2013 | Computers & Internet
ALWAYS SHOW " 1024 X 768" HERZT. CAN'T SHOW
Hi, Same problem as mine! Are u suing the original Samsung CX511n cable? If not, video will not appear! Buy the original cable!
Jun 15, 2011 | Samsung SyncMaster 510N/512N,SyncMaster...
Hello, Dryer won't heat. igniter shows 80 ohms resistance. but there is no power to it. two sensors on exhaust shoot show red wire hot with power through. sensor on intake shows no power. switch by motor...
what is the brand name and model number,if it's a whirlpool or kenmore check the thermal fuse,when you read out a part you have to remove at least one wire.
May 04, 2011 | Dryers
Laptop screen is not showing anything after power is on
if the power is on and the screen does not show up , try to hook an external monitor using the VGA cable. If the screen does show up, it means that the problem is in the laptop LCD monitor itself. Otherwise if the external monitor does not show up, that means your laptop does not boot anymore to the operating system. Try to turn off the power and remove the power cable and battery on the laptop. Then press and hold the power button for 8 secs. Then reinsert the battery and power cables on the laptop then turn on the laptop. If there is still no screen displayed then call Lenovo for repair of your laptop.
Oct 22, 2010 | Lenovo 3000 C200 Notebook
Programmable A/C thermostat has power but shows no temp.
Check power totast. Float switch sometomes kills power to stat. Check drain.
Jun 08, 2009 | Heating & Cooling
No bios showing up in the monitor
does it power on showing power leds or not.if it does power on your video card could be bad.
try your video card in another pc if you can.
Mar 04, 2009 | Acer Veriton 5200 PC Desktop
Televison & Video Logo
54 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
