Question about Indesit Dishwashers
I have an indesit dishwasher DIF 16 - need to fit kitchen door to fron of dishwasher door - is there special fixings and where can I obtain?
ginko
  • 19396 Answers
SOURCE: Will the front panels for
Hi.
The integrated cover panels are compatible with most dishwashers, providing that the model is fairly new (almost all models in UK). The dishwasher usually comes with all the necessary screws and a template for the door to allow adapting to the cover panel.
IKEA cover panels are mounted in the same standard way as other cover panels.
Here an IKEA forum on the topic.
If this comment is helpful, please do not forget to accept.
Regards.
Ginko.
Posted on Sep 05, 2010
SOURCE: Integrated dishwasher door fitting
open the front door. On each side of the inside of the door are various long screws, unscrew these and the old door will fall off. discard the old door and follow the same steps in reverse to put the new door on. It took me 10 mins to do. Hope this helps
Posted on May 22, 2007
SOURCE: Ontegrated dishwasher door fitting
wash your dishes by hand
Posted on Jul 05, 2007
SOURCE: Broken door handle Indesit dishwasher DG 6100
broken door handle solution
Posted on Mar 07, 2008
glasgowlove
  • 40 Answers
SOURCE: how do i fit a replacement lower door seal on a dishwasher
try here for help
or contact them direct..
http://www.devicemanuals.com/guide/Dishwasher/Indesit-manuals.html
Posted on Oct 29, 2009
Dif 16. Why does it try to fill but can't?
You probably had the right area of low water or lack of water so check for blockages.
Jun 02, 2015 | Indesit Dishwashers
Indesit dif 04A dishwasher
Either: broken wiring at the hinge point o the door
or: water solenoid full of crud.
get a service tech to check it out.
Oct 18, 2013 | Dishwashers
Indesit model DG5400wg dishwasher can I fit new bottom door seal without removing the door bernice. If not can you tell me how. I'm fairly nifty wuth a screwdriver.
If you have a 90 degree screw driver you may be able to fit it enough to remove the 5-6 screws holding it in. may take some time but can be done with the right tool.
Dec 20, 2010 | Indesit 24 in. D63 Free-standing...
Indesit DIF 04 error lights halted cycle
i have a indesit dif 04 that starts a cycle fills with water and then the lights on door start to flash,leving all the water in the bottom?
Jan 10, 2010 | Dishwashers
Cant fit door to dishwasher
You would need to tell me which fixings are supplied with the DW. There are a variety of different ways to fix the door to the appliances, some have 2 white spacers which you would need to fit to the lower part of the door and others screw directly to the appliance.
Jul 10, 2009 | AEG 23 in. Favorit 50750Vi Built-in...
Indesit IDL530
it will require the door outer casing to be removed and the control panel to be removed as the lock assembly is fitted to the control panel,please make sure appliance is disconected from the mains supply as there are electrical connections there.
Sep 21, 2008 | Indesit 24 in. IDL500 Built-In Dishwasher
Indesit D4000 Dishwasher seal
you will find the door seal has some shape to it at the two corners,if not fit the seal from one of the bottom corners first with about 3-5millimeters passed the frame that the seal fits into,then push in all the way round to the other end,the seal has a flap type shape on it which should be fitted with the open end apearance of the seal (flap)pointing towards the door
May 30, 2008 | Tappan 18 in. MDR251RE Built-in Dishwasher
I agree read "broken door catch" solution and be particularly careful in respect of the edges of the stailess steel panels - some of the edges are hidden and they are very sharp.
Jan 29, 2007 | Indesit 24 in. D61 Free-standing...
Dishwashers Logo
71 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
