Question about Baumatic B187 Stainless Steel Electric Single Oven
My grill works but the oven doesn't heat up - Baumatic B187 Stainless Steel Electric Single Oven
  • Baumatic Master
  • 43,501 Answers
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Posted on Mar 31, 2011
  • 69 Answers
SOURCE: my omega europa oven is not heating up .grill fan
Sounds like a faulty fan oven element. To replace: Disconnect from power (usually easiest to switch off at fuse box). Remove racks etc from inside oven. Remove rear panel inside oven- four screws. You will now see a heating element that goes around the fan- often you see blow mark on element. You need to remove the back panel of oven to access the nuts that hold element in- two nuts, undo nuts, remove wiring from element. New element available from any good appliance repair shop. Reverse procedure to refit. Happy fixing!!
Posted on Mar 18, 2010
  • 40 Answers
SOURCE: oven does not heat up
Bad thermostat
Posted on Aug 04, 2009
  • 12 Answers
SOURCE: indesit fde20 main oven wont heat up
sounds like the circular element at the back of oven has blown.
Posted on Oct 24, 2009
  • 553 Answers
SOURCE: My oven is not heating up, light works grill works
Assuming you have electronic ignition, It's most likely the ignitor. Try the broiler, if it lights you can be almost certain it's the ignitor. Changing it is not all that hard. BE SURE TO UNPLUG OR TURN BREAKER OFF BEFORE YOU START! You need to take the bottom panel out of the oven. The may be a second cover over the burner. The ignitor is most likely in the back. It will look like a bent up square rod and will most likely be screwed to the back or bottom of the oven. Once you have it loose there will most likely be just 2 wires, be sure to mark where they connect before you disconnect them. Connect the new ignitor just like the old one and replace in the same position as the old one was. Replace the covers and your done. You can most likely get a replacement at your local Heating & Cooling or Hardware stores.
Posted on Mar 26, 2010
  • 327 Answers
SOURCE: Simpson Harmony Nova Thermaflow Oven (63B906W) won't heat up
Hello,Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has faied...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Posted on May 26, 2010
Problem start when i turn Oven only on teka, then the fuses blown up. I can still use grill but whwn I turn to oven fuses go blow up again.
Hi! It seems it is not the heating element! It seems to be before that. Either a short circuit delivering to much current thus causing the blow. I would check the corresponding cable all the way to the circuit and the circuit elements corresponding to the oven element. The grill and oven elements being "independent" explains why grill still works. (A short circuit seems quite possible to me!)
Dec 06, 2014 | Ovens
My grill uses the same elemant as my grill but grill wont work , but oven will
when you use your grill the oven door must be open if if does not heat then the door switch is faulty
Apr 21, 2012 | Ovens
Electrolux EOU5330X Ultrafan Electric Double Oven -
Sounds to me like the lower element shorted and tripped the breaker as it burned out. If you're handy at electrical troubleshooting that's where I'd start - comparing ohmmeter readings between the bad element and the one that works.
A wire short to the chassis would have a similar set of symptoms and be easier to find and fix.
Beyond that, you need a service tech.
Sep 03, 2017 | Electrolux EOU5330X Ultrafan Electric...
Hi. My oven doesn't heat up after I've used oven pride on it. It's a New World DF 90 make. Everything else works, the fan, grill and hobs, but not the oven itself.
Unfortunately, it sounds like your heating element broke. Suggest using an ohm meter to make sure of that before you replace.
The good news is that element is pretty easy to replace and not very expensive either. Just make sure to trip the circuit breaker BEFORE you attempt the remove and replace.
Jun 05, 2011 | Ovens
Hi there Have recently moved into a house with a Belling 626 white, electric cooker and the grill doesn't seem to be working. It has a mian oven, top ovem and "dual grill". The main oven...
ISOLATE THE MAINS POWER BEFORE CHECKING THE APPLIANCE
Run your fingers along the grill element, in this model it is accessible, check for raised areas or small hole or roughness not food burnt, if visible, it should be Black Grey colour at the blemish, you can obtain parts from www.whitegoods.co.uk you will need the model and serial numbers.
The grill elements come out but when unsrewed sometimes the ceramic holders crack, remove element before ordering as you may have to replace the element holders.
Hope this has been helpful
john
May 31, 2011 | Belling Ovens
Both lights on the top oven work when using it as an oven but when using it as a grill, they don't! There doesn't appear to be any other fault as the oven and grill still work fine. Any thoughts...
The unit is working as it should. The top oven lights will only come on when the top oven control knob is turned on. The grill control does NOT turn the lights on. If you want to see what you are grilling, then you should turn the top oven control on to its first position. This works even if the grill is operating.
May 10, 2011 | Stoves 720EF Electric Double Oven
Oven problem- grill works but the fan assist wont heat up
possibility is that the wire that link the oven element and that of grill is loose or burnt
Sep 25, 2009 | Ovens
Top oven (and Grill) have stopped workingMy 3 Year old AEG Competence D2100-4 Double oven has malfunctioned.  Bottom (main oven) works fine but top oven and grill have ceased to function.  The fan will run...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Nov 12, 2008 | AEG D2100-4 Electric Double Oven
Baumatic B187 Stainless Steel Electric Single Oven Logo
1,640 people viewed this question
Top Baumatic Ovens Experts
ashburton
Starnley Johnwells
Starnley Johnwells
Are you a Baumatic Oven Expert? Answer questions, earn points and help others
