Question about Saeco Primea Cappuccino Touch Plus Coffee Maker
Qwadsfasf adf asf asdfa df afd ad - Saeco Primea Cappuccino Touch Plus Coffee Maker
Codes erreur E000400-0100
CauseCommunication error between ADF CONTROLLER and MEMORY PCB.
Action
  1. Reseat the cable going from the ADF CONTROLLER to MEMORY PCB.
  2. If E400 is still present it has been found that replacing the ADF Controller (FM3-0370-000) or MEMORY PCB (FM3-0472-000 / New PN: FM3-4436-000) may be necessary.
  3. If symptom persists, replace the DF-RD26 Shield Cable (FK2-5118-000).
May 16, 2015 | Office Equipment & Supplies
How can I fix a paper jam in my Panasonic 4530 ?
look inside the printer, some where in or around where the paper feeds from the area there is a piece of paper that is stuck or has ripped off inside the machine, you going have to look with flashlight follow the feed rollers and you will find paper, paper clip, a staple, dirt, something blocking the rollers or feeder from working right.
www.ask.com/panasonic_4530_paper_jam/
www.ask.com/panasonic_4530_error_code_j50/
www.ask.com/panasonic_4530_where_is_paper_jam_located/
Apr 22, 2015 | Panasonic WORKiO Office Equipment &...
Help with algorithms course ?afds jafksajf asfj as fas fsa fas f asf
On your original TV remote look for button that says Picture size, Format or Ratio and press it till you see the normal size.
Sep 22, 2014 | Ellington Ashfield ASF56ABZ5RW Ceiling Fan
Error code c0040
C0044
ADF Cooling Fan Failure (Only when the optional DF is mounted)
- Refer to the option service manual (DF-605) for details.
Feb 10, 2014 | Minolta EP4000/5000 CS/PRO Copier
Got a dark line down document when scanner via AFD
When you use the adf, the scanner remains stationary at the far left side of the platen. Check and make sure that the glass is very clean there; use a damp cloth to remove any dirt or other foreign material.
May 27, 2010 | Canon PIXMA MX700 All-In-One InkJet...
Error c620
SC620 B Communication error between BICU and ADF The BICU does not receive a response from the ADF main board for 4 seconds or more. The BICU receives a break signal from the ADF main board. • Poor connection between the BICU and ADF main board (DF connector) • ADF main board defective • BICU defective
Apr 07, 2010 | Ricoh Aficio 2020D Copier
Asdf
yes, just go to asdf dot com.
Sep 01, 2009 | 1984 Ford Mustang
I have a machine error
Does your machine have a ADF ( document feeder) on it? IF it does check the connection between the ADF and the machine. Also check the connection between the scanner PWB and the DF drive PWB. These are the 2 boards that let the machine communicate with the ADF. If your machine does not have an ADF, check to make sure that the side covers are closed securely.
Jan 05, 2009 | Kyocera KM-1510 Copier
Adding workstations
a)What O/S are new wkst Pcs
b)Is there any network setup @ these offices
c)Extra Qs for you.Reply with some details & I'll set you straight
Nov 27, 2007 | Computers & Internet
Saeco Primea Cappuccino Touch Plus Coffee Maker Logo
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
