Question about Panasonic KX-FHD331 Plain Paper Thermal transfer Fax
How to keep auto answer mode - Panasonic KX-FHD331 Plain Paper Thermal transfer Fax
  • 1,719 Answers
Panasonic KX-FHD331 has Receive Mode Button (Just beside Display screen)at the top control pannel, as shown below: -
Press the button "RECIEVE MODE" Button and set the Fax to "FAX MODE ONLY" and the fax will automatically answer the calls in your absence. For further information you may refer to Page-52 of the Operating Instructions Manual.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck!
Don't forget to convey your feedback
CreativeTECH
Posted on Mar 31, 2011
How seup fax ring
Before selecting the ring to answer, under stand what it is..
Press Menu button, scroll to fax set up with help of arrow keys, press ok button, scroll to answering mode. Select desired "auto, manual, fax & tele/fax.
What are these?
Auto: Auto aromatically tele mode will coverts in to fax mode irrespective of selected ring count. suppose if ring count selected as 4, printer will ring 4 times then stops ringing & converts in to fax mode. It doesn't matter whether it's telephone or fax.
Manual: Printer always telephone mode. To convert in to fax mode, need to press fax button while ringing.
Tele/Fax: Printer detects the incoming call type as tele(analog)or fax(digital) accordingly its will act. If its fax , line converts in fax mode with out any ring(silent detection), prints the received fax.If its telephone,printer rings as tele phone.
* In auto mode only you need to select desired ring to answer(2-6 rings)
There fore first you need to select "auto"mode, then scroll to ring to answer, press ok then select desired ring count, press ok to confirm..
Aug 23, 2014 | HP LaserJet 3050 All-In-One Printer
Sharp plain paper ink jet fax ux-b750
to stop the fax automatically switching to fax mode you have to set it to manual to recieve calls and dissable the fax,there should be an auto/fax and call mode, therefore when someone calls it will go to your voicemail, but that means that you will not be able to recieve a fax. Normally auto mode, will first try the fax, if no fax is recognised it will switch to normal line ringer, then if no answer it should go to your voicemail if unanswered.
Oct 01, 2007 | Office Equipment & Supplies
I cannot receive faxes. I have a voicemail set up on my phone that is in use. I would like to use the 1050 as a phone and a fax machine only. I will settle if I could only use it as a fax machine. I have...
If you have a voicemail set on the same line then you may only be able to use either the fax or the voice mail if you want to the fax then change the rings to answer on the fax to 2 (setup button->basic fax settings->rings to answer->press ok on 2) keep the mode to auto mode. However if you want to use both the voicemail and the fax on the same line you might have to get a DRP (Distinctive Ring Pattern) from you telephone company.
Jun 10, 2010 | HP 1050 Plain Paper Inkjet Fax
Can't cancel Auto Answer mode
how to remove autoanswer from my LG phone
Apr 05, 2010 | Cell Phones
HP laserjet 3055 Have dial tone. With phone can call out and receive calls. When sending fax keep getting Result: No answer
Go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set. Make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Have a nice day and do not forget to rate please...!
Mar 13, 2010 | HP LaserJet 3055 All-In-One Printer
How is auto answer mode set
Hello
Press "Auto Answer" button on your OfficeJet printer to turn the light on or off. When the Auto Answer light is on, the device answers calls automatically.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
Thank you
TechSaver
Feb 15, 2010 | HP J3680 Officejet All In One Printer
The fax auto answer goes off when the 65oo is in
You could try these two suggestions from HP support. The semi-full reset will affect quite a few settings. Perhaps you should copy down these settings for reference later.
HP OfficeJet 6500 Auto Answer
Jan 08, 2010 | HP Officejet 6500 Wireless All-in-One...
Blur
It may be in macro mode. Check the settings or the buttons on the camera for a little flower icon or "Macro". Try putting the camera into auto mode, and make sure there isn't a flower icon on the display. If there's no sign of macro mode, and you're in auto mode, the lens could be damaged or jammed. This is one persons answer to a jammed lens problem on Yahoo! Answers:
I've had the same thing happen multiple times. Unfortunately I've always had to take the camera into the shop. In two occasions it was cheaper to have it replaced instead of repaired. The lens mechanism jams up and if you keep banging it it can break peices inside. SORRY! :-(
Dec 04, 2007 | Olympus Stylus 700 / 700 Digital Camera
Panasonic KX-FHD331 Plain Paper Thermal transfer Fax Logo
83 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
