When i print labels on bypass tray i am unable to print
tehnik_bdg
  • 91 Answers
SOURCE: print to bypass
Before printing click the property button, go to papar tab, under tray select, change from auto select to by pass tray
Posted on May 20, 2009
  • 24 Answers
SOURCE: Unable to print #10 envelopes on my Xerox
Although you can lie to the 76XX series machine and get it to print on envelopes, the machine clearly shows that it does not take envelopes on the tray pictures. "Only C4 (229 x 324 mm / 9 x 12.7 in.) and C5 (102 x 229 mm / 4 x 8.7 in.) sized envelopes can be used with this printer; Number 10 envelopes are not supported. Attempting to use any other envelope sizes in this printer could result in jams. or damage to the printer. Do not use envelopes other than what is supported. "
Insert them Face up, flaps closed, leading edge to the right. When it asks, tell it envelopes, and give the size.
In the Envelopes section, under Mailings, Options, choose face up, and the 5th picture. It should work, but the envelopes sure get wrinkled.
Posted on Aug 03, 2009
  • 68 Answers
SOURCE: Ricoh Aficio 2035 all-in-one laser won't print from Bypass Tray
there are two places to set the paper tray on the ricoh aficio 2035 print drivers first make sure you are using the PCL 5 drivers not pcl6 or rpcs then go to the printers folder and set the defaults by right clicking the printer and selecting properties printing preferences, then go into word and select print set up and properties then defaults for printer select bypass tray and select labels enter the correct sheet size for the labels from the drop down box click apply and you should be set.
if this resolves your issue please rate my anser accordingly
regards
Posted on Sep 14, 2009
wrinaldo
  • 185 Answers
SOURCE: error code 007-954 Unable to print labels from
I am sure you have reviewed the paper setting, so it may be a bad Paper Out Sensor 130E82190 or Actuator 120E11971
It's possible that the whole Tray 5 MPT 059K24801 may be bad
Whit
Item, Inc
Posted on Aug 20, 2010
  • 54 Answers
SOURCE: when i print label in bizhub c360 i put the label
Make sure the bypass tray is set to the correct size in the drivers.
Posted on Apr 11, 2011
Sharp mx3110n printer won't use bypass tray? Trying to print on glossy paper using that tray and it won't, it automatically switches to tray 1. Or can I just put glossy paper in tray 1?
Hello Laura,
Here is the pdf that explains how to set up th bypass tray; http://support.appstate.edu/sites/support.appstate.edu/files/MX3110%20USE%20SPECIAL%20PAPER%20IN%20THE%20BYPASS.pdf
The text of it is as follows;
TO USE SPECIAL PAPER IN THE BYPASS
? Press either the picture of the copier or press
paper select
? Load paper in the bypass
? Make sure the correct size shows up under
bypass tray
? If paper is not just plain paper press type and
size
? Choose paper type
? If you are printing to the bypass from your
computer you must also tell the print driver
under the paper tab what type of paper is in
the bypass if its not just plain paper
? The copier and the PC must match paper
types
? Press the X button to Accept
Good Luck!
Rich Lilja
Feb 21, 2015 | Sharp Office Equipment & Supplies
HOW do I get my printer to stop trying to print from the bypass tray?
check the printer properties in Windows Control panel and see if printer settings are set to bypass tray
Sep 19, 2014 | Xerox Office Equipment & Supplies
How can i avoid label sheets getting stuck in phaser 8560
1. Make sure you are feeding the labels from the bypass tray, not from the cassette.-
2. Make sure the labels are for Laser printers, not Inkjet printers.
3. Do not try and re-use a label sheet that only was half printed on.
4. When you put the labels in the bypass tray, set the paper type to labels...this slows down the print process so they won't get jammed.
Jun 02, 2014 | Xerox Phaser 8550DP Printer
I have Toshiba photocopier, Studio 455. i want to print one page label paper. Should i use a bypass, which i tried but did not work. Tell me how.
If you are printig labels you MUST use the bypass tray on the right side of the copier. You mst specify heavy or card stock/label paper so it will fuse properly. I can't tell you why the tray does not work? But labels must be run thru the bypass.
Good Luck and Thank You for using Fixya.
Sep 14, 2010 | Toshiba e-studio 455 Copier
regards
Aug 11, 2009 | Office Equipment & Supplies
Print to bypass
May 19, 2009 | Sharp MX-2700N Color Copier
Printing labels on Ricoh 1224C copier
Labels should only be printed through the bypass tray. when printing, go to "properties", "Paper" and change tray from "auto select" to "Bypass tray"
Jan 13, 2009 | Ricoh Aficio 450 Copier
Print labels
Have you put the blank labels in the bypass tray?
If you have, the unit is not seeing the media in the bypass tray
Aug 12, 2008 | Sharp SHP AM900 multifunction Printer
Can't print envelopes
Solution Title: How to print on COM10 envelops from the Bypass tray (PCL6) using a Windows 2000 O/S Resolution/
Solution
thumbsup.gif Fixed! thumbsdn.gif Did not fix. Resolution Role: Fix
Critical Message: The Envelope must be placed in the Bypass Tray face down (flap side up) and Long Edge IN. In Microsoft Word (Word 2000)
    1. Under the Tools tab, select Envelopes and Labels.
    2. Enter your Delivery and Return addresses.
    3. Click on Options
    4. Under Envelope Options; [Envelope size], select Size 10 (41/8 x 91/2 in)
    5. Under Printing Options, select Portrait (LEF) - Long Edge Feed
        • As Feed from, select Tray 5 (Bypass)
    6. Click <OK>
Within the WorkCentre Pro 123/128 print driver
After opening up the print driver [<Start>, <Settings>, <Printers>, double-click on the WCP 128 PCL6 driver], click on Printing Preferences under the General tab.
  • Under the Paper/Output tab
Set the following features as follow:
    • Job Type: Normal Print
    • Paper Size: COM10
    • Output Size: Same as Paper Size
    • Image orientation: Portrait
    • Image Rotation: OFF
    • 2 sided Print: 1 sided Print
    • Stapling: None
    • Output destination: Center Output Tray
    • Offset Stacking: None
  • Under Tray/Layout
  • Set Paper Source to Tray 5 (Bypass)
  • Click on Bypass Tray Settings
    • Paper Type: Heavyweight (1 or 2)
    • Feed orientation: Portrait
  • Click <OK>
  • " on Specify Paper Type and select Heavyweight (1 or 2)
  • " (Apply> and <OK>
  • " <OK> again
In Microsoft Word under Envelopes and Labels, Click <Print> to send the information to the printer.
Note: This setup represents one way of printing envelopes. Other ways setting up some features in a different manner will work as well.
Solution v1.3.20.0 312637.How to Print on COM10 Envelops From the Bypass Tray (PCL6) 2006-04-05 21:57:29
Nov 02, 2007 | Xerox WorkCentre PRO 128 Copier
312 people viewed this question
k24674
jasbo
jasbo
