Question about Konica Minolta Bizhub 222 Black and White Copier
When i print label in bizhub c360 i put the label on bypass tray and go to the computer and print but still is not printing please help what must i do?
  • 54 Answers
Make sure the bypass tray is set to the correct size in the drivers.
Posted on Apr 11, 2011
Sharp mx3110n printer won't use bypass tray? Trying to print on glossy paper using that tray and it won't, it automatically switches to tray 1. Or can I just put glossy paper in tray 1?
Hello Laura,
Here is the pdf that explains how to set up th bypass tray; http://support.appstate.edu/sites/support.appstate.edu/files/MX3110%20USE%20SPECIAL%20PAPER%20IN%20THE%20BYPASS.pdf
The text of it is as follows;
TO USE SPECIAL PAPER IN THE BYPASS
? Press either the picture of the copier or press
paper select
? Load paper in the bypass
? Make sure the correct size shows up under
bypass tray
? If paper is not just plain paper press type and
size
? Choose paper type
? If you are printing to the bypass from your
computer you must also tell the print driver
under the paper tab what type of paper is in
the bypass if its not just plain paper
? The copier and the PC must match paper
types
? Press the X button to Accept
Good Luck!
Rich Lilja
Feb 21, 2015 | Sharp Office Equipment & Supplies
I am trying to print labels on the Konica Minolta bizhub 250 from the bypass tray and my labels are printing in landscape on my label sheet
Its not in the copier. Its on whatever program your printing from. Try playing with the settings. Don't forget, you can use regular paper until you figure out your correct orientations.
Oct 20, 2014 | Konica Minolta bizhub C250 All-In-One...
Bizhub c200 giving message put paper in bypass tray
Check your default paper settings in your setup menu. Also, check the paper size is set correctly on you paper trays for the type of paper that is in them. Make sure that the documents that you are printing are set to proper paper size that is in your printer. All the issues, will cause this condition plus some. But those are the easiest, let me know if it continues. Good Luck
Jun 04, 2012 | Minolta bizhub 200 All-In-One Printer
How do I print index cards through my bizhub C203?
use bypass tray, you must use thick 3 or thick 4 and the size needs to be close to the size of index, the tray settings need to be set for thickness and size and color then the same has to be set in the driver in computer also, when you go to print hit properties and change the tray to bypass and thick 3 or thick 4 and then the same size you selected in the copier and it should work. if by chance it asks you load paper in bypass after you hit print then it didnt get setup correct. check to see if you got the driver saying the same as the copier tray. ask if you need help
Jul 28, 2011 | Konica Minolta Bizhub c203 Copier
My office has the bizhub c360, and when I put paper into the bypass tray, it prints from the main tray instead of the bypass tray. The settings on the printer are for bypass tray, the settings for my...
Hi the machine could be defaulted to print from the main trays if you have the same type paper being fed from the manual feed same size paper then it will automatically take it from the default trays
IF you take the paper out of the trays and put it only in the manual feed will it print and take it from the manual feed also you have to tell the machine when you use the manual feed what size and type of paper is in the manual feed once you tell it what paper and type of paper like card stock you then need to make sure when you go to print that it is set on your computer with manual feed and type of paper must match what is set on machine
Mar 09, 2011 | Konica Minolta Bizhub 222 Black and White...
Can I print envelopes on my Bizhub 250
BYPASS TRAY is sed when printing onto paper with a size not loaded into a paper tray or onto thick paper, overhead projector transparencies, postcards, envelopes or label sheets Can be loaded with up to 150 sheets of plain paper, 50 overhead projector transparencies, postcards, label sheets or sheets of thick paper, or 10 envelopes referred to as the "bypass tray" throughout the manual. (See page 2-60....ATTACHED )
ftp://207.18.56.26/software/BPG/Userbizhub200250350CopyOperPh2_5.pdf
Feb 15, 2011 | Konica Minolta bizhub 250 All-In-One Laser...
How do I print labels on the bizhub 222
Be sure to load label sheets so that the side to be printed on faces down and a maximum of 50 label sheets can be loaded into the bypass tray.
USER MANUAL page 2-64
http://kmbs.konicaminolta.us/productsattachments/manuals/bizhub362SeriesCopyOperationUserManual.pdf
Jan 06, 2011 | Konica Minolta Bizhub 222 Black and White...
We can duplex copy but not duplex print on the KM Bizhub 250. When printing from the computer, in the Konica Document Properties Window on the Layout tab, when the Print Type pull down screen is activated...
Hello
See if you have selected weight paper from the tray in the duplex mode.
Weight paper is selected in duplex mode only from the bypass.
So you check that the paper in the tray 1 or tray 2 must be plain paper and in duplex mode it can print normally.
Jan 29, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
Print error page Bizhub C351
Google the full error.
this sounds like a font realted postscript error.
Jan 05, 2010 | Konica Minolta bizhub C351 All-In-One...
Print labels
Have you put the blank labels in the bypass tray?
If you have, the unit is not seeing the media in the bypass tray
Aug 12, 2008 | Sharp SHP AM900 multifunction Printer
Konica Minolta Bizhub 222 Black and White Copier Logo
824 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
