Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
Modal # 253.748724400
Compresser comes on 5 seconds then cuts off, not cooling at all.
    Scholar:
  • 150 Answers
Check the start device. a supco rco410 3n1 will replace it
Posted on Aug 10, 2008
SOURCE:
1991 mercury cougar air conditioner compresser comes on but kick off and on every a few seconds...doesnt cool
Check the a/c oil level. When an A/C continuously turns on and off it is usually low on coolant oil.
Jul 03, 2014 | 1991 Mercury Cougar
Compressor on freezer running but not cooling
Dependingmon the length of run time will determine the problem. If the compresser cycles on and off within a couple of minutes then you are looking at a bad compresser. If it runs for 5-10 minutes then cycles off, you have a plugged off condenser or dead condenser fan motor, in which case do not run the fridge until the motor is replaced and cleaned. If the compresser runs for hour or so with no cooling effect then you may have a plugged off cap tube which means a repair man will need to take care of that. If the compresser cycles every 10-30min with a little cooling in the freezer then you are looking at a bad thermostat. Hope this helps
Sep 09, 2012 | Frigidaire Refrigerators
My Frigidaire Model # FRS26LF7DS7 is not cooling!
Could be a few problems. What I would do is check to see if the compresser is running by pulling out the fridge and pulling the back panel off and putting your hand on the compresser. If it Is vibrating then it is running. If it is not vibrating but very hot then the compresser is dead and needs to be replaced. If the compresser Is cool and not running I would say the thermostat inside the fridge is dead(bad contacts in the control). If the compresser is running but no cooling, the cap tube which is the metering device for the refrigerant into the freezer evaperator could be plugged off. Or if none of the lines off of the compresser are hot or cold then the valves inside the compresser are gone and compresser needs to be replaced hope this helps
Sep 06, 2012 | Frigidaire FFHT1817L Top Freezer...
Where is the defrost timer in a GE GSS22JET
Defrost timer should be located at the back of the fridge at the bottom around the compresser, it is usually a little black box. Is the evaperator in the freezer iced up? If it is not, I would check the thermostat for proper operation or the compresser. If the compresser is very hot and not running, your compresser is on its way out, but if it is running and there is a hot line and cold line coming off of the compresser then I would say you have a plugged cap tube ( the metering device that gos into the evaperator in the freezer). In which case a repair man needs to cut about six inches off of it and re fill the refrigerant.
Sep 06, 2012 | GE GSS22JET
A/c runs does not cool
I would add refrigerant to your A/c and go from there.
May 30, 2012 | Whirlpool Refrigerators
Refrigerator not cooling,compresser comes on but goes off after about 5 seconds
http://www.acmehowto.com/howto/appliance/refrigerator/check/compressorrelay.php
Nov 17, 2010 | Maytag MFD2561HE Bottom Freezer French...
The air conditioner cooled on the driver's side and heated on the passenger's side. Took it to the place where they replaced a new gm compresser 2 years ago and they tested and stated that it is an...
If the compressor cycles on and off very fast, you most likely are low on coolant and it needs recharged.
The cigarette lighter light is not on the same line as the lighter itself. Check your fuses.
You could have a problem with the damper in the vent system, giving you different temperatures on either side of the vehicle.
Jun 09, 2010 | 1998 Cadillac DeVille
Fridge not cooling contents
YOU DIDN'T STATE WHAT MAKE YOUR UNIT IS, HOWEVER IT SOUNDS LIKE IT IS THE OVERLOAD COMPONET THAT MOUNTS ON THE COMPRERSSOR TO START IT. TRY THAT FIRST IT IS THE MOST COMMON.
Dec 02, 2008 | Refrigerators
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
140 people viewed this question
Top Kenmore Refrigerators Experts
Fred Sops
Audrey Messer
Audrey Messer
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
