Question about Coby TF-TV1901 19 in. LCD Television
All of a sudden the remote will not work
I have replaced batteries????
  • 2 more comments
  • ldkempf Aug 05, 2008
    the television needs to by on standby for the remote to work, We need the remote to turn the television to standby. None of the buttons work at all on the remote. We have replaced the batteries. No infrared light..
    standby light needs to be on on the television in order for the remote to work, need renmote to put tv on standby...remote does not work at all. Could it be the infrared light on telev not working???
    cannot determine if it is the remote or television. Television needs to be on standby in order for the remote to work,,,but need remote to get telev on standby. The remote is not working at all,,, but not sure if the infrered light on television is the problem or the remote
    This is not a camera but a television.......!
  • 667 Answers
Hi be sure the batteries you placed in are good - do lights flash when buttons are pushed? Is it possible you accidentally switched the remote to another device and not the tv? Do any lights come on or is it totally dead? Thanks.
Posted on Aug 05, 2008
    Genius:
  • 1,011 Answers
Dear,
have you replaced the correct battery. if yes, then check was it working a little bit with the previous one.
if ans. is yes, then u have to change the battery of the same size eg.AAA or AA size cell or same type of battery.
if its not working with the previous one too. then its a remote fault. you have to see it keenly if there is any component leg is broken ...
the easy way to check your remote is camera either mobile camera.
just ON your camera and put your remote sensor in the camera range so that u can see the IR sensor of remote in the camera and press buttons one by one of remote.. u should see the emittion of light in the camera. if not your remote is faulty..
regards,,
dont forget to rate it plz.
  • Coby Master
  • 6,487 Answers
You're saying that the remote is not working even you already replace the battery with a new one? or you're asking if you need to replace the battery?
  • Mark Gil
    Mark Gil Aug 05, 2008
    If you can replace the battery that will be better so we can check if this only a battery problem, because if with the new battery still remote not working there can be some problem with the remote board probably some IC's are damage...
  • Mark Gil
    Genius:
  • 1,142 Answers
Please specify the exact problem you are facing.
  • Maanita Chadha
    Maanita Chadha Aug 05, 2008
    Hi ldkempf
    The best option i can tell you is that you need to open the case of the remote and check the infrared LED which might have been desoldered due to drop shock if the remote has been dropped on the ground. All you need to do is resolder it back on the pcb board and i am 100% sure that will resolve the issue because i have been fixing my remote for a couple of months now as my 2 year kid drops it very often.
My comcast remote was working with my Motorola dct700/us box and now suddenly stopped working
Put in new batteries or check that the battery contact points inside the remote are free of rust or acid build-up from leaking batteries.
Dec 06, 2013 | Arris DCT700 DTV Receiver
My remote for sony dvd player NS 590 p suddenly stopped working. I repleced the batteries but it didn't help
if its not batteries it will be a replacement remote. try cleaning the terminals and see if helps,
Dec 10, 2011 | Televison & Video
Suddenly remote don't work at all
other than batteries its a replacement remote. check and clean terminals see if that helps.
Dec 10, 2011 | Sony RMT-D166P Remote Control
My 373LM Liftmaster remote does not work suddenly. Other remote, wall control switch and my car door opener works perfectly. I am sure it is isolated to just this particular remote. I doubt it is battery...
I would replace the battery anyway. Even with no use batteries drain over time. That's the easiest troubleshooting step and more than likely the problem. Once that's eliminated we can try harder solutions.
Sep 07, 2010 | liftmaster Chamberlain Garage Door Opener...
Remote stopped working all of the sudden, please help
First check the batteries inside the remote? this is usually the first thing to do replace the batteries and try using the remote.
If the problem still persists clean the contact points in the battery. Usually the cause of problems to remote controls are when they hit against anything hard.
Hope this solution has been helpful?
Aug 23, 2010 | Sony (RM-DX500) Remote Control
Remote don't work properly
Remove the batteries, open your remote clean the pcb (with cotton ball slightly damped in rubbing alcohol) the one that is painted green as well as the carbon contacts the one behind the remote pads, let it dry and put it back, replace with a new batteries.
Jun 06, 2010 | Element Electronics PLX4202B 42 in. Plasma...
All of a sudden my systems remote doesnt work
Try replacing the batteries in the remote first. If this doesn't work it is very likely that you just need to replace the remote.
Aug 31, 2009 | Samsung HT-Z310T Theater System
Remote control has stopped working
If you have replaced the batteries with KNOWN GOOD ones, observed the proper polarity when re-installing the batteries AND made sure the remote is in DVD "mode" (if it is a multi-remote) when trying to use it, the remote is bad. Replace the remote.
Mar 25, 2009 | Panasonic DMRES15 DVD Recorder
Coby TF-TV1901 19 in. LCD Television Logo
145 people viewed this question
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
