Question about HP Compaq nx6110 PC Laptop
Hp compaq nx6110 laptop usb power surg and usb not recognize problem please give me a solution in above mentioned problem
  • 52 Answers
Try other usb if same problem with other than go to device manager (controlPanel> System>Hardware> Device Manger) and delet all USB Contorollers from Universal Serial Bus Contorollers and restart your computer.
Posted on Mar 31, 2011
How can I fix this error "Powe Surge On Hub Port" which keeps on popping up on my HP Compaq nx6110 Laptop?
it is your widows problem you must uninstall service pack 2 operating system and install any other higher version operating system like service pack 3 or windows 7.
Sep 09, 2011 | HP Compaq nx6110 PC Laptop
Hp notebook Nx6110 having following problems (1) When it is powered on sometimes it fails to start and gives msg NON SYSTEM DISK OR DISK ERROR ...PRESS ANY KEY TO CONTINUE (2) its bluetooth device...
I will first try to restore the system first to the point when you had no such problems.
Then, run anti virus program like kaspersky. (Some programs catche virus or spyware well but don't fix well.)
If your problem stays same, there are two possible problems. (hightly possible first)
1) Motherboard Problem. (If your notebook were shut down due to any electric shock like sudden power down)
2) Power Problem. (Short power) - example bad battery
I hope it helps.
May 26, 2011 | HP Compaq nx6110 PC Laptop
Compaq nx6110 laptop hangs after 30 minutes, please help
It should caused by a power supply too weak or not stable problem.HP Compaq nx6110 PC always happen to this problem.
Feb 10, 2011 | HP Compaq nx6110 PC Laptop
I frequently receive the message power surge on hub port, in dutch "Stroompiek op de hubpoort", even though when no USB device is connected. It is very annoying. What to do? computer: Compaq...
Check whether there is any metallic debris in one of your USB ports.
If there is not, then there may be some something coming into contact with the circuitry leading to the USB ports that is causing the short. If that is the case, then you'll have to take the laptop apart yourself or take it in for service.
Dec 22, 2010 | HP Compaq nx6110 PC Laptop
Hp nx6110 laptop error power surge on hub port
OK if you have anything plugged into the USB Ports at bootup, unless Keyboard or Mouse, remove everything, and see if it boots normally, if it does, then the "Hub" you are using may be faulty, or a device you are using is drawing a lot of current at switch on and overloading the USB bus, that can only supply 500mA. If it still does it, and you do use a USB KB & Mouse, then remove them one at a time & reboot, between, and see if it was one of them causing the problem. If you have nothing attached then your internal USB bus is flaky.
Feb 16, 2010 | HP Compaq nc6120 Notebook
In capsule my nx6110 compaq hp hangs at bios(hp screen)
sorry boss i can get you problem.. please i guess you have not mentioned your problem.
Jun 14, 2009 | HP Compaq nx6110 PC Laptop
Power Surge on Hub Port
Don't Use existing USB Portn On your Comp if u want USB port then install PCI USB Card From the PCI USB card you can use your USB Device what ever you want to use
Thanks
Ankur
May 29, 2009 | Compaq NX6110 TFT XGA Notebook
Some USB devices draw excessive power from the USB port, especially USB scanners. When this happens you need a powered USB hub, connect this to your computer's USB port and connect the USB device into the powered USB hub, you should not have any further error power surge problems.
Apr 27, 2009 | Compaq NX6110 TFT XGA Notebook
I have Hp Compaq nx 6110 Laptop everything is ok boot system normal no any error but just laptop move any where then system stuck and only way of power off and second problem is "power surge on hub port: a...
1st prob. - I appears there is a loose connection problem somewhere - try reseating your RAN and hard disk.
Try to determine which part of the laptop is causing the problem, not moving the laptop around the room but by flexing different parts of the laptop and power cable etc. while it is on your table.
2nd prob -
Some USB devices draw more power than the USB port can provide and you get the error message - "exceeded power limit".
In these cases you will need to purchase a powered USB hub, connect this hub to the laptops USB port and connect the offending USB device into the powered USB hub.
Mar 31, 2009 | Compaq NX6110 TFT XGA Notebook
HP Compaq nx6110 PC Laptop Logo
371 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
