Question about Paradyne BitStorm 2600 (2611-a1-430)
Price for this paradyne bitstorm 2600 ip dslam
I need to know if paradyne 2600 is ipv6 compatible
On bridge mode, DSLAM and modem are transparent to IPv6.
On routing mode, IPv6 is not supported yet.
Pls correct me if im wrong, tq
May 03, 2011 | Paradyne BitStorm 2600 (2611-a1-430)
My paradyne has no IP ADDRESS, HOW DO I PROGRAM THE IP ADDRESS INTO WINDOWS 7
start menu
-search programs and files
-run
-cmd - enter
-ipconfig (press enter)
-you'll see defult gateway, thats the ipaddress of you paradyne.
Apr 25, 2010 | Paradyne (6218-A1-200) Wireless Router...
How do I reset the Privilege password on a 2600? The former IT Manager left without telling us what it is, and now we're screwed.
you need a reboot and a serial console I'm afraid. Lots of places on Cisco that detail the password recovery process, it's quite complex so I'm not going to go into detail, but you need to be physically in the same room connected with a serial console cable (9600 baud) for it to work. Basically, use break to interrupt the startup, change the config register to ignore startup config, reboot , go to enable mode, copy run start, enter config mode and reset the password.
Mar 26, 2010 | Paradyne BitStorm 2600 (2611-a1-430)
How does one configure vlan based Quality of Service on Paradyne SDSL Micro dslam
It doesn not appear that the Paradyne SDSL Micro supports QoS (Layer 3):
However, it appears that it can be configured for CoS (Layer 4), even though the device doesnt support CoS itself it can pass that on in the packet header. This also makes sense considering that most DSLAMs hand off straight to an ISP that will use FIFO to deliver the packets to the internet.
Jan 26, 2010 | Computers & Internet
What is the default ip of the paradyne modem6381
The default ip is :192.168.1.1
The default User-name and Password is : Admin
Some model came with default ip 192.168.0.1
Subnet to use is 255.255.255.0
Ok make sure you are using an ip address with the same range.
That is you can set your ip 192.168.1.x where is 2 to 252
ok try this
Jan 22, 2010 | Paradyne 6381 ADSL2+/ReachDSL Router...
How to reset username and password on BITSTORM 4800 DSLAM switch
You need to hold the reset the device. Most hardware get back to factory defaults once they are reset . That should help
Thanks
Ranjit
Sep 24, 2009 | Zhone 6211-I3-200 Router
Paradyne 6218-I2 ip filter
If you are using multiple computers, and DHCP, then your IP's are probably changing, which is causing your issue. You need to manually assign an IP to a computer for the IP filter to be effective in the Paradyne.
Dec 28, 2007 | Zhone (6218-I2-200) Router
Is there anyway to do a remote reset of a dsl modem?
The answer "depends." If the DSL modem is in bridge mode, then NO. If you have opened up a WAN management port in the DSL modem, then YES. If the modem's management port is not open to WAN access, then do what I do. Remote into the site, past the DSL, then go backwards into the LAN portion of the DSL and reboot it. But..of course these answers are too easy and not what you are looking for, probably. The DSL provider can reboot the dsl modem. But there is no software or command I'm aware of that can reboot or resync a "fritzed out" modem. ZT3000 "Beta tester of "0"s and "1's"
Mar 27, 2007 | Paradyne BitStorm 4800
Paradyne BitStorm 2600 (2611-a1-430) Logo
91 people viewed this question
Top Paradyne Computers & Internet Experts
Michael Galve
Michael Galve
Are you a Paradyne Computer and Internet Expert? Answer questions, earn points and help others
