Question about Microwave Ovens
Where can i buy food grade undiluted white vinegar in san antonio, texas?
    Brigadier General:
  • 8,909 Answers
Undiluted White Vinegar that has been brewed naturally is about 5% in strength. I should have thought that any Chemist Store, (drug store?) would stock or be able to get acetic acid, which is the acid produced by the brewing process if you require strong solutions.
Try ebay.com
Posted on Mar 31, 2011
THE WATER COMMING OUT OF THE HOLES AT THE BOTTOM OF THE IRON IS BROWN. HOW TO I CLEAN THE IRON
There is rust and sediment from using tap water inside. Try running white vinegar through it a couple of times with the iron on holding it level over the sink. If that doesn't clean it out, you will need to go to the hardware store and buy some CLR.
Sep 11, 2011 | Microwave Ovens
I have an LG Microwave. A Week back i mistakenly microwaved sausages for 20 min. They got burnt and the microwave also started stinking. i aired it out and microwaved a cup of water twice on separate...
Hi hafsahparkak,
Plz follow the steps below once again ...hope it works if not plz revert:
  • 1
    Unplug the oven and unfasten the cabinet body, using a screwdriver. The body should be attached along the back as well as along the sides or bottom.
  • 2
    Slide the cabinet body back slightly to clear any internal brackets, then lift it off.
  • 3
    Clean the oven, using a vacuum with plastic crevice attachment. Vacuum the fan and other internal parts, then vacuum the vents underneath the oven, on the back and inside the chamber.
  • 4
    Reassemble the oven and plug it in.
  • 5
    Fill a small bowl with a 50-50 mixture of water and white vinegar, then set it in the oven and turn the oven on high for 5 minutes. When the mixture boils, it will remove stubborn smells inside the vents and loosen food particles on the oven walls.
  • 6
    Wipe down the oven walls with a clean sponge.
  • Aug 22, 2011 | Viking DMOC205SS Microwave Oven
    My B30 is stopping up in 4 days after it is cleaned with white Vinegar. Is there any other cleaner?
    There are many coffee pot cleaners on the market, but white vinegar will normally do the job, if you do it thoroughly. If might take 3-4 passes through for all the minerals to be removed and then a once a month cleaning would be enough to keep it free flowing.
    Jun 30, 2011 | Microwave Ovens
    Keurig Coffeemaker says to descale. How do I do that?
    Hi, unplug the coffee machine and remove the cup.
    Turn the coffee machine upside down over the sink in order to fully drain it of water. Be careful of the plug and avoid getting it wet.
    Pour undiluted white vinegar into the reservoir up to the top edge of the viewing window.
    Place a ceramic cup under the machine, plug it in and press "Brew" for a large cup. Pour the cups of vinegar into the sink and repeat the process until the reservoir is empty.
    Remove the final cup of vinegar and empty it. Fill the coffee maker with clean water and allow it to sit for four hours, remaining on.
    Unplug the machine and dump the water into the sink.
    Fill up the reservoir with fresh, clean water and plug it in. Place the ceramic cup back on the drip tray and run multiple brews in order to rinse the machine of any remaining vinegar residue.
    Apr 28, 2011 | Microwave Ovens
    I can;t find manual and I want to clean my keurig coffee maker
    You may be able to find the User Guide for your Keurig machine here:
    http://www.keurig.com/customer-service/brewer-registration-and-support/user-guides-and-help
    Your brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar. Full de-scaling insturctions can be found here:
    http://www.keurig.com/customer-service/brewer-registration-and-support/~/media/FD69E91A51CA41BEBF4CCAA138325BBF.ashx
    Mar 26, 2011 | Microwave Ovens
    Just need general how to use and clean info
    Just fill a microwave-safe bowl with a mixture of half vinegar and half water, and nuke it for two minutes. Then, dip a sponge into the vinegar-water solution, and use it to wipe the food off of the walls of the microwave. It'll fall right off - no strong-arming required.
    No chemicals, cheap and works like a dream.
    Mar 09, 2011 | Microwave Ovens
    How do you desalazize kettle?
    If by desalazize you mean remove the deposits which build up from the minerals in your tap water, the easiest way to do it is with white vinegar (most vinegar will work but white is best for cleaning).
    1. Fill kettle with a mixture of white vinegar and water (about 50/50 but it doesn't have to be exact) until it covers as much of the deposits as possible.
    2. Heat the kettle until the liquid boils
    3. Let the kettle sit with the liquid in it for 3-6 hours
    4. Empty and Rinse
    5. Fill kettle with regular water, boil, and empty to get rid of any lingering vinegar taste.
    If the deposits are especially thick, you may need to repeat steps 1-4 before moving on to step 5.
    Mar 01, 2011 | Microwave Ovens
    I need 48oz of undiluted white vinegar to clean my coffee maker. where can I buy it in Glendale Az, area.
    You can buy vinegar wherever you buy your groceries and most convenience stores..
    Feb 23, 2011 | Microwave Ovens
    How do you defrost rfa52 polar white fridge freezer?
    Switch off the power and place all the contents in a thick bage inside a large cardboard box, to keep it cold. Place a tray to catch the thawed ice in the apropriate place and wait.
    When defrosted, wipe the surfaces down with an antibacterial liquid/spray of food grade quality and switch the power back on. Replace the frozen food, after checking the date codes, in the freezer
    Jan 04, 2011 | Hotpoint Microwave Ovens
    Inserted K cup and closed machine. Says Brewing but coffee machine only dispenses a few tablespoons of water...tried turning machine off and off, but same amount of water is dispensed each time, no matter...
    Sorry to read about your issue.
    The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
    Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
    Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
    If you taste vinegar..use more clean water, until the taste is ok.
    I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
    Jan 01, 2011 | Microwave Ovens
    Microwave Ovens Logo
    78 people viewed this question
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
