Question about Canon MultiPASS MP730 All-In-One InkJet Printer
I am getting a message "CM Ink Empty" can you advise what this means please
    Novelist:
  • 129 Answers
Hi there!
The message CM ink empty means that the cyan/blue and magenta/pink ink cartridges are empty and needs to be replace.
Hope this helps. Thanks
Posted on Mar 31, 2011
New ink cartridge in printer saying empty
Assuming you have a refilled or remanufactured cartridge there this is actually pretty normal. These cartridges have no means of checking for new ink in the cartridge so will continue to warn of empty. They will not however stop you from printing as a result.
If however you purchased the cartridge as a brand new cartridge, you may have been miss-sold the cartridge. In which case I would advise speaking to whoever it was purchased from.
Nov 20, 2012 | HP Photosmart C3180 All-In-One InkJet...
Tip
Error Code U163
[Although specifically written for an MX310, this should work for all MX and MP series Canon printers.]
If this Tip does not work for you, please notify me by accessing my profile page at here and using the Ask button to write me a note.
I can then help you with your specific problem.
Error Code U163 (Ink Cartridge Empty or Low)
First of all, Yes, this is a common problem.
When you open your printer up, by lifting the Scan Cover, you will see lights blinking for the cartridge that is low or is empty.
1.) A lamp blinking once every three seconds means your cartridge is low.
2.) A lamp blinking once every second means your cartridge is empty.
Using your printer with an empty ink cartridge is capable of harming your printer, according to Canon Engineers.
Until such time as you can replace the cartridge you can use the method described below to temporarily turn off the error message.
Press and Hold the Stop/Reset button for 6 full seconds and then release it? Use the one Mississippi method of counting.
The Scan cover must be closed completely and locked in place. And the ink cartridge must be firmly locked in place as well.
Please advise me of your results. There may be a more complex problem involved and it is important to have the necessary data in order to get you back to working again.
Regards,
Worldvet
NOTE: If this doesn't resolve your Canon problem and you want to try another Tip that may work, you can try this Tip written by Darklord. At least give it a read, it has been known to reset some Canon printers.
on Oct 19, 2008 | Canon PIXMA MX310 All-In-One Printer
Refilled hp 8600 ink cartridges and still says empty
With the hp printer you could very easily have a bad print head which will cause same message
Nov 01, 2012 | HP Hewlett Packard Officejet Pro 8600...
After printer said ink cartridge was empty I removed it & found it was not-I put it back in printer & now getting error message that the cartridge is used & needs to be replaced. How can I
your only option it to replace it with a new one . printer mfg's have chipped the cartridges and they can not be reused.unless the chip is recoded as new .
Aug 16, 2017 | Ricoh Aficio GX3050N Printer
Its showing "close ink cover"
Hi there!
The message "Close Ink Cover" means that the cartridge door is not closed securely.
-please open the ink cartridge cover and make sure all cartridges are installed correctly and then close the cartridge cover. That should clear the message on the screen.
Hope this helps!
May 08, 2011 | Brother DCP 165C Compact Color Inkjet...
I replaced an ink cartridge because the printer stopped working and showed a message that the old cartridge is empty. However after putting the new one in but the printer still refuses to work and shows...
maybe the cartridge is wrong, release it and clean the electrical contacts, put them again one by one, if notting happen, try this
Solution As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue. The Ink Cartridges Empty options are described in the table below: Ink colors out Option Print mode possible All Cancel None Black
AND
Cyan, Magenta, or Yellow (any or all) Black only Continue with other colors Cyan/Magenta/Yellow mode (composite black)
Text and photo quality will differ from those printed when all colors are available Light Cyan or Light Magenta (either or both) Cyan, Magenta, or Yellow (any or all)
(Black still available) Print with black ink only Grayscale
Apr 07, 2010 | HP Photosmart 3210 Printer
Lexmark X5150 printer (serial #10450991811): Error message reads "color cartridge missing." It is not. With the last cartridge, printing was light and scattered; could not print anything...
Went to online chat with Lexmark. FREE.
They offered to replace cartridges as they felt the ink was dried out in one, and the ink jets in the other were damaged.
Apr 18, 2008 | Lexmark Office Equipment & Supplies
Brother MFC 210C series ink replaced
The brother machines require ink in all the cartridges as it is always flushing ink through the heads to "clean" it. This means you must have ink in all cartridges at all times unfortunately or the brother will not work. Even if you could somehow get it to work it could damage your printhead anyway.
Good Luck
Please rate my advice, good or bad.
Feb 06, 2008 | Brother MFC-5840CN All-In-One InkJet...
Canon MultiPASS MP730 All-In-One InkJet Printer Logo
208 people viewed this question
old marine
old marine
