Question about Nokia 5800 XpressMusic Smartphone
The phone says offline done a factory reset don`t know how to turn online
    Novelist:
  • 129 Answers
Hi there!
On the home screen right below the word offline it shows date & time right? click on the date & time and it will open an option to change a profile. you can select general just to test it.
Hope it helps. Please rate if it works. Thanks
Posted on Mar 31, 2011
Need to cancel add-ons for an LG neon 2
Sorry, I don't have any experience with LG outside the KC910 however, you can generally remove programs and add-ons the same way you would on a computer. Find the file containing it then delete it. You may have to turn your phone off and then on to have this completed.
In a worst case scenario, you may have to do a factory reset. Just make sure that you don't have the unwanted programs on a removable memory card which will allow it to reload after you do this.
To do this enter 3845#*370# and select factory reset from the list. Should be about the 4th one down. If you have other than the GW370 model, just substitute your model number for the 370 in the code.
Hope this helps.
Nov 24, 2011 | LG Cell Phones
Phone is on offline mode. Don't know how to get it back online?
Go to settings of your phone. You will find this option there.
Aug 18, 2011 | Palm Pre Cell Phone
How to remove message saying "emergency calls
If "Airplane Mode" is activated, this could happen, otherwise there's no other settings to deactivate or activate the offline mode with this Model. The "Airplane Mode" is under Settings, make sure it's Off.
You can also check the Network Setup under "Settings" and make sure "Automatic" is selected.
I would also recommend you to try with another sim card. If the same problem persists with another sim card, try resetting the phone "Master Reset". There are two options to reset your phone, 1. Master Reset and 2. Master Clear. Master Reset will reset every the phone settings to factory default while Master Clear will reset the phone as well as clear all the data from the phone and will restore everything as it was when you bought (as a new handset).
To do Master Reset, open "Settings" then "Initial Setup" and "Master Reset", you'll be asked to enter the security code, type in 1234 and proceed, if 1234 doesn't work, then use 000000 (6 zeros).
Note: if you have changed the code, you should use that.
Even resetting doesn't help, then there must be Network Problem with your phone, perhaps, the Network IC. In rare cases, Antenna causes this issue. Or sometimes it's related Software. All these are to be checked/done at Motorola Service Center or at local Mobile Repair Shops.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Dec 08, 2010 | Motorola Mobility RAZR V3m Cellular Phone
How to fix cold rest on HP lazerjet 5100
Cold reset CAUTION: A cold reset will reset the HP Jetdirectcard, even if removed. Print the Configuration page before performing a cold reset. The customer must have the ability to reconfigure the HP Jetdirect card and be willing to accept this responsibility.
  1. Turn printer off.
  2. Hold the ONLINE key down.
  3. Turn printer on.
  4. Continue to hold the GO key until the printer reads Cold Reset .
  5. Release ONLINE.
    • Initializing appears.
    • Then, Restoring Factory Settings.
    • Followed by Offline.
  6. Press the ONLINE key to put back online.
    hope it helps, if so do rate the solution
Nov 29, 2010 | HP LaserJet 5100 Printer
I forgot the password to my phone after I changed it. How do I fix it since I can't get on the actual phone to reset the password. ??
I didn't know if this codes will work on your phone as that phone is new, but let me remind you that it will somehow lose your settings once successful factory reset has been done. you can try the code if you choose to reset it to factory setting and if you think that it is the last resort to your problem.
Try without sim : if it goes to offline mode
type the codes you may choose how to do it.
2945#*# and chose Factory Reset ...
47328545454 # or
2945#*88110# and factory reset codes
good luck
Mar 03, 2010 | LG Neon GT365 Cell Phone
My printer shows "offline". How do I get it online?
Did you recently change the ink cartridges=? Did you use third party or refilled cartridges?
If so, that may be the problem. Some printers have logic in them to drop offline if ink other that the manufacturer's is used.
If you are using factory new ink, please let me know and I/ll continue to try and assist you.
Don
Dec 14, 2009 | HP Office Equipment & Supplies
Printer offline
OPEN UP YOUR WEB BROWSER AND CLICK ON "FILE". SEE IF THERE IS A CHECKMARK NEXT TO "WORK OFFLINE".....IF SO, JUST CLICK ON IT AGAIN TO MAKE THE CHECK MARK DISAPPEAR AND BE ABLE TO WORK ONLINE AGAIN..........OR YOU CAN GO INTO THE START MENU, OPEN CONTROL PANEL, GO TO PRINTERS AND FAXES, FIND UR PRINTER,,,,RIGHT CLICK ON IT AND SEE IF PRINTER IS ONLINE OR OFFLINE..
Sep 22, 2009 | Office Equipment & Supplies
My phone will not turn on even though the battery is full. When it does turn on it is offline? How can I get it off offline?
Let’s try some tricks out here, see if that helps us,
1.) Check sim reader if it is ok.
2.) Make sure that when you power the phone you select the right profile. It ask you how you want to work "online or offline". you have to select online.
3.) Finally if the above is not heading us to the resolution, then we might have to “Remove the Sim IC & make the jumpers to 100%”… not sure if you could do that without a help from a phone tech.
Please let us know if that was helpful enough.
Good Luck & Thanks,
Shiv.
Aug 17, 2009 | Nokia N70 Smartphone
Offline Mode
Press power button once, then select "General".
May 20, 2008 | Nokia 6630 Handheld
Nokia 6120 shows offline how do i get it online
I just did it with a little help from the first response. However, exact steps are: Go to SETTINGS then go to PROFILES. My cel options are NORMAL, SILENT etc. Go to NORMAL then....gees, since I have it on line again, I can't remember if you go to ACTIVATE or CUSTOMIZE. One of those two options will tell you, "YOU ARE OFFLINE, WOULD YOU LIKE TO GO ONLINE" Of course you will choose ONLINE and VOILA!
Apr 26, 2008 | Cell Phones
Nokia 5800 XpressMusic Smartphone Logo
123 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
