The TV is a Panasonic PT-53WX54J. The convergence chips in the TV went bad and were replaced shortly after. When aligning the screen up as instructed to do by the manual, the screen suddenly went black. The TV seems to power up fine, and when left on for a short while, the screen will get a rainbow effect, or rather red-green-blue fuzzy lines right up the middle of the screen, vertically. When the channel is changed, the rainbow lines seem to fade or get brighter on different channels. The power red light blinks five times in a row before pausing, then repeating the blinking again, and again until unplugged. I've read that the code for the blinking is (CODE IC4511). There's no help from the manual for this, so that's useless.
TVtechmaniac
  • 140 Answers
SOURCE: PICTURE WENT BLANK TV TURNED OFF
Replace the thermal fuse part# 1-910-006-44 You can verify this by jumping the connector where the fuse connects and the lamp will come on.
Posted on Aug 21, 2007
djchillsnyc
  • 152 Answers
SOURCE: red light blinks 9 times on Panasonic TH-42PZ77U
hello, panasonic plasmas have a safety shut down circut to protect the main panel when a short is present or internal circut panel is non functional some info i found in the service manual for 10th generation plasma
if your tv is still under warantee take advantage of the pany free service other wise it is a matter of exchanging the defective board then you will need electronic skills for this repair if you plan to do it yourself. it would be wise to have a skilled tech check it out and give you a estimate there are some techs that will come out and check it for free and give you a repair price.
here are some repair manual tips for blinking panasonic .. i didnt find 9 blinks on this manual i may be using a different manual but these are panasonic plasma blinking fault tips for 10th gen
becuase all models have different blinking codes you may need the model specific service manual
for 10th gen model some models 2008,2007,
8 Blinks SOS:
Pin 91 of the MPU IC9003 monitors the status of the SS board. During normal operation, pin 8 of connector SS23 outputs a low to pin 91. If the SS board becomes defective, a high is provided to pin 91. As a result, the unit shuts down and the power LED blinks 8 times.
9 blinks panel config sos
10 Blinks SOS:
The SUB5V and DT9V sources created on the A board are monitored by IC1100. If they are not present at pin 30 and 34, the MPU shuts down the unit. The power LED blinks 10 times.
10 Blinks SOS:
The F_STB_15V of the P board, as well as the derived SUB5V and DT9V sources are monitored on the A board for excessive current. If a short circuit is developed in one of the supplied lines, pin 114 of IC1100 receives a high. The SUB5V and DT9V lines are also monitored for excessive voltage. When an over-voltage condition is detected, a high is also output to pin 114 of IC1100. The DT9V is provided to a DC/DC converter to create the BT30V for the tuner. If the BT30V becomes excessive, a high is output to pin 114 of IC1100. A high at pin 114 of IC1100 causes the unit to shutdown and the power LED to blink 10 times.
hope this helps..
Posted on Dec 09, 2008
welcomejee
  • 10594 Answers
SOURCE: Sony KDF-E50A10 No Picture
4 times blink error shows that any FAN is not running in TV as there are 4 fans in this TV.
Please check fan connectors and make sure all are plugged securely.
Posted on Feb 14, 2009
Slinteriors
  • 8617 Answers
SOURCE: panasonic cinemavision pt-53wx54j
if the led is blinking one time its the 140 volt circuit. If its blinking a series of 3 blinks its the convergence circuit
Posted on Feb 16, 2009
  • 86 Answers
SOURCE: Sony Bravia KDL 46", no picture, standby light blinks 4 times
Since the TV is still receiving power, the problem is going to be with the TV's mainboard.  After you unplugged the TV and plugged it back in, you said the power light went out again, so I assume the standby light wasn't flashing again?  The flashing standby light is indicating an error code so my suggestion is to contact Sony for service options regardless if there is a warranty or not because service is the only solution to this situation.  Don't forget to provide them the error code or 4 flashes repeating.
Posted on Mar 25, 2009
I have a Panasonic PT-47WX53, this morning when i went to turn the TV on the picture was not align. The red and blue look aligned but not the green, i opened the back and when I coved the green light the...
This kind of problem occurs due to failure of convergence output chips located on main circuit board of tv and replacement of convergence output chips will hopefully solve your tv problem.
Soldering work is involve to replace these two chips so have local tv repairman for that job if you are not familiar doing so.
Thanks.
Jun 29, 2011 | Panasonic PT-47WX53 47" Rear Projection...
Replaced convergence chips in my 53" panasonic
If the chips are not fakes then check your soldering for shorts.
For all others who are having convervence failures this is a common problem. You can get all the parts from www.TvRepairKits.com
Your TV will commonly have one or more of the following symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio or Video
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 10, 2010 | Panasonic PT-53WX53 53" Rear Projection...
Vertical lines dont align and green tint
First do a convergence on your set go to menu select picture then scroll down to convergence then press select again. Next follow the on screen instructions for static convergence. If this doesnt solve the problem check all the capacitors in the convergence section of your TV. If problems persist replace both convergence chips. Please have tech do this for you.
Aug 13, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47WX54J - There are colors running down the middle of the screen while the rest is black. I cannot access a menu to make any changes.
Let me ask you an important question to resolve what I think your problem is:
Do you see a narrow band of light from top to bottom but no picture?
Does it take it a minute or so and is just to the right of center on the screen? It can be towards the far right---Is this what you are dealing with?
Respond by making a comment here or if you repost the question mark it in the title: ATTENTION SD TECH.
IF you have the problem I suspect you do it is a bad cap and I can tell you exactly how to get at it and replace it.
I am here to help.
REGARDS, SD TECH
Aug 13, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic cinema vision pt-53wx54j does not turn on. red power led blinks 3 times.
Hi
Thanks for using FixYa. 3 blinks means convergence output failure and to resolve this you’ll need to change the convergence chips which are located behind the black heat sink; you can see once you open the back off the TV. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 07, 2010 | Panasonic PT-53X54 53" Rear Projection...
I have a Panasonic PT-53WX54J that will not Converge
you need to replace or have professional convergence amplifiiers. If know how to desolder and solder you could repair yourself or in home professional tv repairperson will cost you $275-$400. The convergence adjustments via remote are half the battle the IC's loose clarity over time.
Aug 23, 2009 | Panasonic Televison & Video
Pow lite flashes three times it tries to turn on then shuts down
LED 3 times blinks shows problem with convergence out section in TV and may requires convergence out ICs replacement.
If you are familiar with TV repair and can solder parts on PCB then let me know to provide you more technical info.
Thanks.
Jul 23, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Adjusting the convergence after replace convergence chips
Hello fmnii,
Believe it or not the easy part was the replacing of the convergence amplifiers. Now for the hard part, static and dynamic convergence of the TV. To do this, what I usually do is not trust the onboard cross-hatch and alignment patterns, for this I use a signal/pattern generator to create the cross-hatch and alignment patterns. I follow the static convergence instructions first, and then the dynamic convergence instructions. This process taks about 6 - 12 hours (Yes 6 - 12 hours) if done correctly. I say use the instructions because each TV set is different. It sounds like you have your static convergence well in hand and you just need to do the dynamic.
If you can, try to get a signal/pattern generator (I use the VA62A).
I wish you well,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Feb 03, 2009 | Panasonic PT-47WX53 47" Rear Projection...
PT-53WX52
Your TV most likely has a Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
Dec 02, 2007 | Panasonic PT-53WX52 53" Rear Projection...
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
