Question about Kenwood Car Audio & Video
I wired my kenwood 621 to a kicked solobarak l5 an the volts on th amp drop to 6-5.5 what is causing this issue?
  • 56 Answers
Grounding issue. Are you getting feedback on the neutral wire. If so then you need to find a more suitable grounding location
Posted on Sep 27, 2011
My Kenwood KAC 9152D Amp is hooked up to power and wont turn on.No light no nothing. Power going to it is good though.
Check your ground. Make sure you sand off any paint where you grounded the amp. Also did you hook up the remote wire? It's the blue wire on the back of your headunit. Some say remote wire, others say power antenna either one will work. Sounds like one of the two...hope this helps.
Mar 28, 2010 | Kenwood KAC-9152D Car Audio Amplifier
I have a kenwood kac-8452 4 channel amp that makes the speakers pulse after the volume gets turned up to 10. I also have a kenwood amp doing the same thing with my subs. any ideas?
Its not pulsing, its called clipping. The sound is being clipped due the amp being pushed past is power capacity and distorting the signal. This will damage your speakers very quickly. No amp should be turned more then 3/4 up. If its not loud enough you need to purchase a larger amp or be comfortable with the wattage it produces at 3/4 volume. You may also have speaker wires touching/crossed causing th issue.
Sep 10, 2009 | Kenwood KAC-8452 Car Audio Amplifier
Wiring for kac-622 car audio amplifier
http://www.retrevo.com/support/Kenwood-KAC-622-Amps-manual/id/479bh233/t/2/
Jun 12, 2009 | Kenwood KAC-749S Car Audio Amplifier
Amp is going out.
Have you tried replacing all of your fuses? If that does'nt work check your ground........ I would check all your connections also could be a connection shorting out causing your red light to come on.
May 10, 2009 | Car Audio & Video
The volume control on my KENWOOD TH-78A no longer functions
first of all check the volume control see if a wire broke off. but i suspect a cold solder joint on that volume control switch. if not check the board for a small crack.
Apr 10, 2009 | Kenwood PB-18,...
Amp cuts out but not in to protection
definately wireing wrong some amps dont like the 1.33 are you testing your wiring jobs with a volt meter! just set it to the resistance/ohms and verify that you are actually getting 1.33 or the ohms you want!
Feb 19, 2009 | Kicker KX1200.1 Car Audio Amplifier
Doesn't turn on
You need to confirm that the B+ voltage isn't dropping at the amp.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
May 21, 2008 | Kenwood KAC-9102D Car Audio Amplifier
Kenwood kac 9152D
Usually, protection mode is caused by one of these conditions:
  • Shorted speaker outputs.
  • Speaker output shorted to ground.
  • There is an internal issue, causing DC voltage to be present on the speaker outputs.
  • Amp overheats.
  • Ground connection is insufficient for amp or HU.
I'm not sure of the history or symptoms of your amp, but those are the reasons why the amp could go into protection mode.
Mar 13, 2008 | Kenwood KAC-9152D Car Audio Amplifier
My Kenwood KAC-X1R hooked up to (2) Kicker Solobaric L5's
first get a deck with 4 volt pre outputs or more that will help a lot then a battery in the back will help like a 1000cca or more
Dec 30, 2007 | Kenwood KAC-X1R Car Audio Amplifier
Kicker solobaric l5 12''
how to wire a kicker solo baric l5 12'' 4ohm down 2 and 1 ohm
Sep 25, 2007 | Car Audio & Video
Car Audio & Video Logo
24 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
