Question about JBL GTO 75.4II Multi-Channel Amp Car Audio Amplifier
I have 75.4 and have a pioneer 307 (Dual 2 ohm) bridged on 2ch. The AMP trips on low freqs. reason? would it be better to hook it up on a single channel rather then bridge?
  • 56 Answers
Yes
Posted on Sep 27, 2011
Total Power Bridged in 2 or 4 Ohms ?
Nice amp the specs say the following:
4 Channel 100W x 4 (4 Ohm)
4 Channel 150W x 4 (2 Ohm)
2ch Bridge 300W x 2 (4 Ohm)
But.... it tends to go into protection quite fast so i wouldn't go too low with speaker impedance.
Dec 28, 2010 | DHD NTX-3106 Car Audio Amplifier
Is this a good amp
I classify this as a sleeper of the car audio industry. it is powerful, well built, cheap, feature laden, sounds great! very comparible to the big names such as kicker, alpine, fosgate an all the rest. i would prefer this amp over any of them any day of the week! here are the specs for it incase u didn't have them.
  • Max. Power Output: 800W x2Ch.= 1600W @2 Ohms
  • Power Output:
    • 330W x 2Ch.(@2 Ohms) Less Than 0.5% THD
    • 220W x 2Ch.(@4 Ohms) Less Than 0.3%THD
    • Bridge: 660W x 1 Ch.(@4 Ohms) Less Than 0.5% THD
  • All Measurements Done @ 14.4V DC, 1 KHz Input Signal.
  • Dual VU-Meter
  • Dual Fan Cooling System.
  • LPF (Low Pass Filter) Variable 30Hz-250Hz
  • HPF(High Pass Filter) Variable 50Hz-l KHz.
  • Slope Adjustable 12-24dB.
  • Variable Bass Frequency(30Hz-120Hz).
  • Variable 0-18db Bass Boost.
  • High & Low Adjustable Level Input.
  • Dual LED Indicated Power Status (Protect/Power).
  • Mosfet DC-DC Switching Power Supply.
  • Built-in Protection Against Short Circuit, High Temperature & Overload.
  • Auto Power On/Oft By Remote (+12V).
  • Dimensions(mm) : 300(W) x 57(H) x 697(L)
Apr 04, 2010 | Rockwood 4224RTX Car Audio Amplifier
Ive got a 5channel zeus z7oo & im hooking up
if i were you i would put the switch to 4ch and the run one sub from ch1-2 bridged and then ch3-4 bridged. I would have to bet this amp is stable only to 4 ohms bridged with so many channels
Mar 19, 2010 | Hifonics Zeus Z700 Car Audio Amplifier
Kickers shut off
Has nothing to do with the sub's . This is an AMP problem. Best guess is you are running at too low of an impedance. Most likely (sight unseen) you are running a 2ch AMP @ 2 ohms bridged, or if the sub's Dual voice coil you are @ 1 ohm, and most amps frown on that.
Give me some specs..
Amp make, and model.
And EXACT model # of the sub's. Give me this info, and I will tell you how to make it work.
Aug 08, 2009 | Kicker DCVR122 -- 2 Ohm Dual 12in CompVR...
I have 1000 watt sony XPLOD amp and i just installed it today. with new monster cable&ground. the green light turns on& thumping goes for a little. i try to raise up just a little bit& after 2...
it isnt getting enough power and its tripping the internal switch on the amp and putting it in safe mode. either your wire isnt a high enough gauge. you might need a capacitor or you need bigger wire.
Jun 13, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Ccan it be bridged with a 5 ohm subwoofer?
Hello cameron_cran,
The information I found on the amp is that is a 2-channel and is bridgeable. It is stable in bridged mode to 4 ohms. You should be able to bridge a single 4 ohm sub without damage to the amp.
Hope this helps.
Apr 22, 2009 | Pioneer GM-X322 Car Audio Amplifier
How do i wire 10' kicker cvr
dual 2 or dual 4
dual 2 wire vc's in series for a 4 ohm load each. Hook each speaker seperate channels on the amp.
dual 4 wire vc in series for an 8 ohm load each. Hook both + to the right + on the amp and both - to the left - on the amp. or
dual 4 wire vc in parallel for a 2 ohm load each and hook each speaker to seperate channels on the amp.
Dec 18, 2008 | Kicker CVR12 Car Subwoofer
Problem with LEGACY BLUE DIAMOND AMPLIFIERS LA1080
never attemp to bridge your amps specially this type of amps. this are too very complicated. you may blow your amp if you will attempt it again.
Jan 22, 2008 | Legacy BLUE 4 X 250W CAR AMP Car Audio...
Car Audio & Video Logo
70 people viewed this question
Top JBL Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
isaac johny
isaac johny
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
