Question about Panasonic Televison & Video
Panasonic 29 inch Tv Tx-29GF10X Has started to get 2inch vertical line moving across screan from right to left. Is worse sometimes after being on AV channel and going back to TV, have to keep flicking through the AV channels to get it to settle or play a VHS tape sometimes works. Was a great TV before this started happening Please help.
techman
  • 3130 Answers
SOURCE: channnel keeps flicking like your changing channels with remote
when you say flickering??? are you saying the screen goes black and comes back on?? does the sound go out at the same time and comes bag on with the pic ? Is the sound there when this happens but is distorted. Is the pic blacked out or is it greying out with lines and twisting?? Need more info please as if its blacking out and the sound goes with it it may be going into shutdown. If the pic is getting kinda greyish with it twisting and the sound is there and ditorted then the tuner could be bad
Posted on Mar 25, 2006
techman
  • 3130 Answers
SOURCE: panasonic model TX-29GF10X, went on stand by
Your problem im afraid could be one of several things. Power supply problems,sweep supply,horizontal output transistor,standby power supply. The best thing for you to do , if your not a tech, take the set into a reair depot as these are solid state sets and have no user replaceable parts inside. Good Luck
Posted on Aug 28, 2006
chrispurs1
  • 372 Answers
SOURCE: Color line across the center of a black screen
Hi. this is caused by dry solder joints on the frame o/p IC. Resolder all legs of frame chip. Should sort that out.
Posted on Sep 12, 2007
redcrx
  • 7 Answers
SOURCE: panasonic tx-29gf10x image not filling screen
Hi there, I have the same model, and I had a simular problem , except my picture shrunk from each side of the screen into concave arc, if you know what I mean. I thought it might be a faulty horozontal output transistor, so I replaced that but did not fix it.
Eventually the picture quality dropped namely it became out of focus and i couldnt refocus it. Then it stopped all together and I heard a ticking sound, which I found was
coming from the line output transformer. A Tech friend told me it was probably a cracked or burnt out HV Capacitor, so checked them all and ofcourse they were all o.k.
So I have come to the conclusion that the Line Output Transformer is faulty, I hope I
am right as they are not cheap.
I think I have the answer to your problem which is a very simple one:
Adjust the "vertical picture height," and it will bring the picture down and fill the bottom of the screen. To do this adjust the VERTICAL CENTER SWITCH by pushing it forward towards the tube , this switch is on Board
TNP 107985 which is located right next to the AV inputs on the back of the TV, the switch is a round white component with a lever on it, and is located on the top of the board, push it to the max forward position, this should help, but might not fix it enough
depending on how much space u have at the bottom. There are no other vertical height adjustments on this Model so it would have to be a faulty component, like a HV
capacitor or burnt out resistor, or not enough HT drive voltage, which suggests dare I
say it--- Line output Transformer, could be wrong though.
Anyway good luck with your problem, hope what I suggested helps.
Posted on Feb 04, 2008
  • 56 Answers
SOURCE: 29"Colour TV ,Sound Normal ,No Picture a vertical line Appears
Fault in HZ Deflection Stage check yoke also
Posted on Aug 16, 2009
Why I have a thin line across the screen in my TV model Panasonic TC 21. After replacing the vertical IC the horizontal line across the screen reduced to few inches and not as it was earlier. vertica
First, You should to replace by original part, then you should check the voltages on power supply, and check the voltage for vertical IC based on datasheet, also check the voltages on vertical section including yoke and last you should check the ESR capacitors on vertical section.
Oct 13, 2014 | Panasonic TC-21PM10RQ 21" TV
Panasonic plasma tv th42px8ob 2 inche vertical line showing
do the proper isolation proceedure and try unhooking the Su from the SC board to see if you then get a normal picture all the way across the bottom half of the screen? I am assuming the Vertcal extends extends all the way from top to the bottom of the screen?
Aug 06, 2012 | Panasonic Televison & Video
Very thin black vertical line moving across tv screen left to right on tv
The screen voltage to the picture tube is more than normal. Adjust it by the help of screen pot-meter integrated with Line Output Transformer. Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy.
Aug 05, 2012 | Panasonic CT-20SL14 20" TV
Ive got a line down the left hand side of the screen when the tv is turned on the model number is panasonic viera tx-p42v20b
HI,
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
GOOD LUCK IN RECTIFYING THE FAULT, THANKS
May 13, 2011 | Panasonic Televison & Video
Intermittent 3 inch green vertical line-5 inches from right side
it you have a repair skills you need to open the TV and make sure all the ribon connectors around the circuit boards are proper connected
and if all seems to be ok, the DG board will need to be replaced.
If you dont have any repair skills I would recommend you to take you TV to a repair shop since this is complex repair
Jun 16, 2009 | Panasonic TH-37PX60U 37 in. Plasma HDTV
A white line has appeared on my desktop only
Two inch vertical line appeared.It sometimes is on the left and sometimes moves to the middle. It is only on the desktop.
Feb 20, 2009 | Microsoft Windows XP Professional for PC
Black horizontal line moving across screen with PS3
Loose connections in the AV board. Re solder . Did you try in video 2 or 3 ?....But Am suggested re solder AV board and connectors. I hope this help you I am here any time thank you!!!
Jul 21, 2008 | RCA P52926 52" Rear Projection Television
Red Vertical line across tv screen.
remove and reseat the system board if that doesn't cure it replace the system board part number AA94-15695A get it at www.vancebaldwin.com price $158.90.
this is what the board looks like
May 15, 2008 | Samsung TX-R3080WH 30" TV
Panasonic tx-29gf10x image not filling screen
Dec 13, 2007 | Televison & Video
Televison & Video Logo
46 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
